It could have opened up on the contacts and so the switch needs to be replaced, As a last resort you can try using a SWITCH CLEANING OIL - use with the power supply taken off from the machine. After using the oil on the switch , try to work the switch few times so that if teh contacts are burnt and is failing to contact the poles , the oil could clean and reset the connection. If this wont work you have to replace the switch.
check for spares from:
http://www.espares.co.uk/search/kitchen-appliances/small-appliances/p/1036
