Toshiba MV13M3 / MV13M3W 13 in. TV/VCR Combo Logo
Posted on Jul 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the remote code for the toshiba MV13M3
Level 3:
Top Expert:
  • Toshiba Master 76,851 Answers
  • Posted on Jul 14, 2011
Toshiba Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
Hello
Universal remote setup codes for Toshiba TV/VCR combo are:
0260 0358
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
How do I Set-Up a Toshiba mv13m3 TV/VCR combo with a Toshiba VC-624 remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Can i conect RCA jack for video output on a toshiba tv/vcr combo MV13M3? if so were do i conect to on crcuite board
most televisions only brings these input connectors, for video output need a converter output coaxial input to rca
What is the remote code for a toshiba 55HX70 tv
Almost any Toshiba code for sets made around that time will work.
Google the model number for the remote you are trying to program for "manual" which will have instructions and a list of possible codes to try.
My remote won't work at all.
If no remotes work it is likely the remote receiver (ifrared and at front of set) is either dirty (lens) or bad.
A hint here is try original remote right up against the receiver--if works receiver is bad.
Note: original remote can be tested by a shop or even with most digital cameras--in a dark room the remote pointed at the camera and the lcd display will flash faintly when buttons on remote are pressed.
How to program tv manually
You need the original remote, a universal will not do this--
You direct enter a channel number and then in set's menu select in setup ADD---if auto program will not work you can direct enter channels one at a time and then add them into the memory of the set with the remote.
1helpful
DirecTV hookup to tv
If your TV is cable ready or HD tv ready you can hook up if not you can't hook up..
Thanks
Chester.
Have a Toshiba TV model Mv13M3. All of a sudden it turned off, with no sound and no picture and the word "line" in green on the upper rightn hand corner of the screen. Any suggestions?
Although I did not manage to find the manual for this combo set, to check it fully, it seems that maybe someone pressed the remote button marked "Input Selection" that selects each one of the audio/video inputs of the set.
Press it two or three times and check if it cycles the inputs till a TV channel shows on the screen.
Hope this info can help you!
MV13M3 TV/VCR Combo
What kind of universal remote do you have? Is it "One For All" ? Did you try the "Search for your Code" method?
Downlodable owners manual for Tosiba MV13N3
This is as far as I got
Click on this link
If you email them the model number, I'm sure they can print one from microfilm
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
