There is no power up there - best you get a schematic for the unit so you can figure it out. The site enclosed often has schematics for this type of appliance. All you need is an ac voltmeter and you are ready to start checking. Search Over 2 1 Million Appliance Parts
SOURCE: Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in
it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let
it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice
maker needs water. If the valve doesn't seal good because of sediment or wear
it will continue to drip and when the water reaches the ice maker supply tube
it will freeze. You can take the water
line off the valve and watch to see if it drips.
SOURCE: Electrolux Side-By-Side Refrigerator making really load noise
You have a defrost system issue! DON'T chip any more ice!! EEEKKS! You are lucky you didn't puncture the freon line! There is no repairing a punctured freon line!! We will send the correct parts to you if you will please provide your model number for this unit. Once you replace this defrost system. you will not have any more icing up issues. You must, however, defrost the unit out before you replace the defrost system. You can do this by unplugging your unit for at least a whole day and by placing a fan in front of the opened up unit to allow it to thaw out PROPERLY. BTW: I love the Electrolux Icon appliances. I hope this resolves your problem and I hope to hear back from you soon. We answer our phones from 7 Am until 9:30 PM CST.
SOURCE: i have an electrolux sisde
More than likely the microswitch for the water lever has failed or broken.
You'll need to access the dual water valve on the back of the unit to determine that when you press the lever - the solonoid on the valve is getting voltage.
If it is getting the turn on voltage - the solenoid is bad and needs replacing.
If it is not getting a signal voltage - the switch is bad.
CLICK HERE for all the diagrams to your unit.
Unfortunately - most parts on this unit are unavailable. I have checked 3-4 different vendors.
This unit also uses a electronic board controller instead of individual components that can be easily replaced.
The replacement module for this unit is $376 and can be seen HERE as part #38C.
The dispenser module (#8) is not available.
Contacting the Manufacturer may be your best bet in finding replacement parts or an authorized repair center that can access the parts.
CLICK HERE for their service locator.
Thanks for using FixYa!
Testimonial: "THANK YOU blueextc3221! Calll the service tech rt now."
SOURCE: I have an electrolux wave touch french door
pull the ice tray out, on the bottom of the left side there's a metal rod that needs to be repositioned into the tooth gear.
SOURCE: side by side refrig - ice maker and water don't
Removing a water filter from the inside of your Frigidaire brand
refrigerator:
Removing and replacing a water
filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built
side-by-side refrigerators are relatively simple to replace. Follow these steps:
Note: Replacing this type of filter is a quick process - there is no
need to unplug your refrigerator or shut off the water supply when replacing it.
Also, this filter should be replaced every six months.
