Philips Magnavox DVD/VCR Dual Player Logo
Anonymous Posted on Jul 19, 2011
I need the code for a magnavox dvd vcr combo. its the quick set up code or codes. its for little leaps learning steps. i cant find the manual for it.
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Jul 19, 2011
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
Hello
Setup codes for Magnavox DVD/VCR are:
0456
[0914 0286] [0969 0286]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
  • The Knight
    The Knight Jul 19, 2011
    Try these codes too. They are for philips. Proceedings are all same as above.
    0456 [0969 0286]
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1106
Points
Top Philips Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
