Canon NP 7130 Black and White Copier Logo
A
Anonymous Posted on Jul 23, 2011
EO error code on Canon NP 7130. Copier turns on, error code flashes and then copier shuts down. Any recommendation?
5 Related Answers
A
Anonymous
  • Posted on Jun 28, 2008
SOURCE: Canon copier NP 6216 all lights on!
it sounds like the controller board as gone
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Sep 16, 2008
SOURCE: Canon Copier NP 1020 - error code E0
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000" Heater lamp, Thermistor, DC controller "E001" Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller. "E010" Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
Anonymous
  • 318 Answers
  • Posted on Nov 03, 2008
SOURCE: CANON NP 7130
This is your drum unit or transfer unit that must be replaced.In what area are you?
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Nov 11, 2008
SOURCE: canon pc-6re error code EO 10
E010 Clock pulses fail to be generated or the PLL lock fails to be released due to a fault in the main motor, etc. Related drum drive unit and main drive unit
There is a problem with the motor of the drum or the main motor itself.
Anonymous
  • 8 Answers
  • Posted on Feb 04, 2009
SOURCE: my canon copier PC-745 won't power up it has error code EO
i think the problems is in the delivery roll,the rubber is need to be change with the new one
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
