SOURCE: we have a dreammaker spa, how do we drain it? the
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
SOURCE: I have a fantasy dreammaker spa that plugs into a
This is a GFCI and will trip at the least bit of water at the plug or at the wiring inside the spa controls. Just go through the system and make sure all is dry. Use a hair dryer in the outlet and on the controls and wiring. If you still have problems you may need to call an electrician.
SOURCE: when the spa and the
The valve(s) controlling water flow to all the features are not set correctly. You will need to increase the amount going back to the spa to keep it from draining. Depending on the valves in use they are not overly difficult to change the diverter settings. If you need help with that please comment to this post and include the valve brand and model number.
John
