RTO Cybex 520T Remanufactured Treadmill Logo
Posted on Jul 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
About 10 second upon start-up, the Cybex 520T Treadmill would abruptly stop and display in the consul is an Err3. We transferred the speed sensor of the unit to another Cybex treadmill and initially the Err3 was repeated but then after increasing the distance of the sensor with the flywheel target, the Err3 did not re-occur anymore. So right now, we are just confirming what is the equivalent of Err3 and what exactly are the parts that needs to be replaced in this case.
Sportsmith LLC
Level 3:
  • RTO Master 920 Answers
  • Posted on Nov 23, 2015
Sportsmith LLC
RTO Master
Level 3:
Answers
920
Questions
0
Helped
527891
Points
111994
Error 3 is an indication that the speed sensor signal has been lost. Check the speed sensor gapping on the machine you were initially having the issue on. If the speed sensor worked on another machine, I would think adjusting it when you reinstall the sensor, should fix your issue. A lot of times, gapping or a build up of lint, dirt or other debris can cause the speed sensor error to occur.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
3 Related Answers
joboo1
Jim London
  • 257 Answers
  • Posted on Mar 25, 2009
SOURCE: My Cybex 520T is comming up with Error 9 on the Screen
Hi, Error code 9 on your treadmill means the brushes on the motor need replacing. This is an automatic indication that is set for 100 miles of use to prevent damage to the motor. Replace both sets of brushes and this should Fixya!
Anonymous
  • 218 Answers
  • Posted on Aug 13, 2010
SOURCE: Need to download manual for cybex 530t treadmill. Can't find link
replace the console, you buy that part individually
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Aug 20, 2011
SOURCE: re: model cx455T cybex treadmill.
hi,
Every 9,000 miles (14,500 km) the unit will show "SVC" on the display. This will continue until the service is performed and the service odometer is reset.
1. Determine mileage.
A. While in Dormant Mode enter Test Mode by pressing and holding the Heart Rate and Level keys simultaneously for five seconds.
B. Press the Dist key. DIST appears on the display. Record Mileage. NOTE: Once the unit exceeds 999 miles or kilometers the odometer will use both screens. Example:
12,805 miles or km would be displayed as 12 805 . NOTE: To exit Test Mode, press the Pause/Stop key .
Every 5,000 miles (8,000 km).
? Check running belt tension and tracking.
? Move treadmill and vacuum underneath..
? Lubricate elevation pivot points.
(Watch the videos for tentioning and lubricating treadmill belt.)
Top RTO Exercise & Fitness Experts
Aron
John Mazmanian
John Mazmanian
Anonymous
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
