Posted on Aug 01, 2011
Can I get a remote control code for my sharp ht-dv40h home cinema. My remote was stolen
5 Related Answers
Anonymous
  • Posted on Nov 26, 2008
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
ginko
Ginko
  • 19396 Answers
  • Posted on May 04, 2009
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Anonymous
  • 24 Answers
  • Posted on Jul 22, 2009
SOURCE: ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Anonymous
  • 8619 Answers
  • Posted on Sep 15, 2009
SOURCE: I need to reset the region code on a samsung home
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray. 1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM) 2. Reconnect to mains 3. Turn on player with remote. 4. Press ENTER on remote. 5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2 6. Press ENTER on remote. (The tray will open and player will power off and close tray.) 7. Switch on power from remote. 8. Player is now Region Free. Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Anonymous
  • 5 Answers
  • Posted on Apr 04, 2010
SOURCE: when i turn samsung HT-TZ212 home cinema system on
Hi , your amp board need to replace , get one from ebay.
Top Sharp Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
