20 Most Recent Lathem Time Clock; Manual, Model 2121 Questions & Answers
Staples model 14346 older thermal pouch laminator. Instructions on using 14346 laminator please?
Question edited for a lot more clarity, add magic word. It is a bog standard pouch laminator. Put the sheet of paper into the clear acrylic laminating sheet. Then put that into the reusable lamination protective pouch. When the machine is heated up, insert the pouch into the front of the machine. When it comes out it is done. Don't try and use it without the pouch, the worksheet will wrap around the heated roller. This manual below is close enough. https://marketingassets.staples.com/m/567781ef0409b551/original/Instructions-1171104.pdf ..
7/31/2026 3:26:20 AM • Office Equipment... • Answered on Jul 31, 2026
2answers
Measuring for stair carpet
measure the length of the tread and riser, combined. Typically this will be 17 inches or so. Add at least an inch or two for good measure then, assuming all the stairs are the same, multiply by the number of stairs and, in most cases add for one additional riser. This is for straight stairs with no landings or turns. For pie-shaped stairs one needs to measure the longest points for the trad portions.
6/23/2026 7:28:48 AM • Office Equipment... • Answered on Jun 23, 2026
Flashing orange lights and it's saying F-05
"F-05" with flashing orange lights is used by many different appliances, so I need the brand and model to identify the fault correctly. Please send: Brand Full model number What type of machine it is (washer, boiler, coffee machine, etc.) A photo of the display/lights would help too.
5/7/2026 1:53:15 AM • Office Equipment... • Answered on May 07, 2026
How or where to download Digilex DA3016 printer driver please?
12 year old question resurrected by spam, now removed. Unfortunately nowhere, it only appears here on Fixya asking for Drivers.
https://www.google.com/search?q=digilex+DA3016
5/4/2026 10:05:02 PM • Office Equipment... • Answered on May 04, 2026
Ricoh Aficio MP W5100 Mono Wide Format MFP Printer Scanner. It shows ERROR J006?
Lots of information here plus Service Manuals. It is a Paper Jam or Transport issue. https://www.google.com/search?q=AFICIO+MP+W5100+ERROR+J006The Aficio MP W5100 error J006 indicates an original document jam in the Auto Document Feeder (ADF/ARDF), specifically often caused by a transport motor failure or binding in the drive belt area.Scribd +1Immediate Troubleshooting StepsClear the Jam: Open the ADF unit cover and remove any jammed originals.Check Originals: Ensure the documents are not folded, torn, or stuck together, and are suitable for scanning (not too thick or flimsy).Check Drive Belt (Technical): If the error persists, the ADF Idler Pulleys and Shafts may need cleaning and lubrication to relieve binding.Restart/Reset: Turn the main power off and then back on to clear the error.Scribd +3If the issue continues, the ARDF drive belt or transport motor may need professional service.
4/10/2026 6:14:57 PM • Office Equipment... • Answered on Apr 10, 2026
Need instruction manual ambico v-0650
I need manual for ambico model v-0655
3/22/2026 2:20:17 AM • Office Equipment... • Answered on Mar 22, 2026
Merch source projector wont show pix when laptop is pluged in
Are you using the HDMI output of the laptop? If so you need the HDMI drivers for it!
3/7/2026 7:42:45 PM • Office Equipment... • Answered on Mar 07, 2026
Bonjour j'ai un probleme avec mon Riso RZ 220 UI avec un code p--25 p-98
RZ220 Error code P98-025
- Copytechnet.com https://www.copytechnet.com > ... > Digital Duplicators Sep 25, 2012 - The code states "defective RF PCB (unsuccessful initial communication with RF PCB)". Try turning off the riso, then turning on while holding the reset key. Read more
3/3/2026 6:53:19 PM • Office Equipment... • Answered on Mar 03, 2026
What means error 4198 on GasBadge Pro?
Vibrating Motor Failure
2/20/2026 12:24:19 PM • Office Equipment... • Answered on Feb 20, 2026
3answers
Staples calculator manual for spl-290x
YES
1/22/2026 9:53:51 PM • Office Equipment... • Answered on Jan 22, 2026
Print fine but flashing red light what is wrong. I have a ink cartridge. Does need to be replaced?
A clue to make and model of printer, may help you get an answer.
11/24/2025 8:24:23 AM • Office Equipment... • Answered on Nov 24, 2025
2answers
BAD PCB
Do you know hqew.net? Know the pcb.hqew.net is the best PCB small batch customization supplier in China?http://www.aliexpress.com/store/233890orhttp://pcb.hqew.net/?s=544849Is custom PCB link
11/1/2025 4:53:47 PM • Office Equipment... • Answered on Nov 01, 2025
Error code9401+c-D291 for bizhub 654e changes lamp+ccd+power supp MFB installion firmwer K9
No need to use the parts cannon! The CCD is faulty. Replace the CCD only and re write the Firmware with the correct version. Contact Minolta for the correct firmware version otherwise it might not work.
9/8/2025 6:56:36 AM • Office Equipment... • Answered on Sep 08, 2025
6answers
Error code 51 on Rational combo master plus. Changed battery but error 51 still displayed
Error 51 I perform cleaning the steam generator and all source of water and I change battery also but still error is appearing to please give me solution
8/6/2025 2:55:18 AM • Office Equipment... • Answered on Aug 06, 2025
Lathem Time Clock; Manual, Model 2121 Logo
5 questions posted
Top Lathem Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
Adam Inlay
Adam Inlay
Level 1 Expert
Alex Kimuyu
Are you a Lathem Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lathem Office Equipment & Supplies
Most Popular Question
lathem 2121 time clock not printing
  • Office Equipment & Supplies
