20 Most Recent
Vetus Alexander Iii Electric Anchor Windlass, ALEX31210 Questions & Answers
Search Manual pdf model 137m667g515 master-craft 14.5 hp
I could not find a direct PDF owner's manual for model 137M667G515 Master-Craft 14.5 HP, but this appears to be an older MTD-built riding mower/trailer mower model. The model number format matches MTD equipment. ?
Genuine Factory Parts +1
You can try these manual lookup pages:
MTD Manual Lookup??
Genuine Factory Parts Lookup??
If the exact model does not appear, try:
137-M667G515
137M667
M667G515
Also check the serial/model tag under the seat or rear frame because one digit may be incorrect. Older MTD manuals are very sensitive to exact model formatting.
If you want, send me:
a photo of the model tag, or
the mower picture
and I can help locate the exact PDF manual.
5/7/2026 1:55:42 AM •
Boating
Answered
on May 07, 2026
I have 2007 Mercury Mariner 5hp 2 stroke engine. Do you know what the internal fuel tank capacity is?
The internal fuel tank capacity for a Mariner 5hp 2-stroke engine is typically 2.5 liters (0.66 US gallons).
Mariner 5hp engines also feature a connector for an optional, larger 12-liter (3.2 US gallons) external fuel tank for longer operation times.
Note that some information for other models, particularly the 4-stroke versions, indicates a smaller 1.1 liter capacity, but the 2-stroke models generally have the 2.5 liter internal tank.
Outboard Engine 5hp 2 Stroke Long Shaft:20" - Budget Marine
These truly portable models offer an incredible horsepower-to-weight ratio. The 2.5 or 3.5HP weights 13kg with its empty built-in ...Budget Marine
Mercury 5 HP Twostroke - Hi Tech MarineTable_title: Mercury 5 HP Twostroke Table_content: header: ' Propshaft Rated Horsepower ' 5hp (3.7kw) ' row: ' Propshaft Rated Hor...Hi Tech Marine
Mariner FourStroke Outboard Engine - 5 HP - Chastheboat.co.ukTable_title: Specifications - 5 Table_content: header: ' HP / kW ' 5 / 3.7 ' row: ' HP / kW: Engine type ' 5 / 3.7: 1 cylinder ' r...shop.chastheboat.co.uk
Show all
Show more
MODELS Mercury/Mariner 4 ? 5 ? 6 (4-Stroke)
elrincondepitagoras.es
http://elrincondepitagoras.es > MANUALES > Mer...
PDF
This service manual has been written and published by the Service Department of Mercury. Marine to aid our dealers' mechanics and company service personnel when ...
Read more
260 pages
12/20/2025 4:32:20 AM •
Boating
Answered
on Dec 20, 2025
1986 9.9 Mercury outboard. Are there fill plugs on 1986 9.9 mercy outboard please.
Yes, your 1986 Mercury 9.9 HP outboard has two fill/drain plugs for the lower unit gear oil.
These plugs are located on the lower gearcase (the "foot" of the engine that goes in the water) and are used to drain and fill the gear oil (lube).
- There will be a drain/fill plug at the very bottom of the gearcase.
- There will be a second vent/level plug located higher up on the side of the gearcase.
The standard procedure for changing the gear oil involves removing both of these plugs. You fill the gearcase with new oil through the bottom hole using a pump until it starts to come out of the top (vent) hole, ensuring all air pockets are removed.
When performing this maintenance, it is important to use new gaskets or O-rings on the plugs to ensure a proper seal and prevent water intrusion into the lower unit. You can purchase replacement plugs and gaskets from marine parts suppliers such as
Wholesale Marine or
eBasicpower.com.
12/20/2025 4:25:10 AM •
Boating
Answered
on Dec 20, 2025
Where is the bilge drain plug located on a 2002 glassport 17" boat
At the bottom of the transom, on the outside rear of the boat - centered and low, just above the keel line.
This is the main drain plug (sometimes referred to as the garboard plug), and it's used to drain water from the bilge when the boat is out of the water.
6/11/2025 5:34:26 PM •
Boating
Answered
on Jun 11, 2025
