20 Most Recent GE GSH22JFR Side by Side Refrigerator Questions & Answers
Refrigerator not cooling right
cabinet heater switch or timer if gone. Ice is building up and blocking the vent from the freezer to the refrigerator where the cold air has to travel.. Call the ge repair people.
2/18/2018 8:14:59 AM • GE GSH22JFR Side... • Answered on Feb 18, 2018
8answers
GE Side by Side refrigerator door handles yellowing
The brillant person posted the perfect solution. We just tried it this weekend. The plastic composite on the handles is not UV protected plastic, so it yellows or turns brown over time. You can't clean it, as it's a defect due to light exposure. We downloaded a diagram of our fridge and learned how to take off the handles. The top and bottom white portions pop off, but be careful when doing so. We gently lifted them off the metal backing and put a butter knife underneath so we would not damage the plastic. You can then see the clips that hold them in place. Gently pry them and they will pop out. You have to remove the top and bottom pieces first then it will expose the screws that hold the handles in place. You need a star type screwdriver-we found one at Home Depot. The metal strip is a simple backing and will just stay in place. Now, the key is the Krylon Fusion paint-Satin White, like the one person wrote. It's for plastic. Clean off the handles and make sure they are dry. Tape off the portions you don't want paint on and spray them outside with the paint. It dries quickly, but we waited about 8 hrs to put them back on. Just put them back on with the handles first and then the top and bottom portions-they cover the screws. Ours now look brand new! Cost? Only $6.50 for the can of paint and we got it at Walmart. If we had to replace them w/new handles? About $175. Thank you to whomever it was that shared this idea. It really works!
7/18/2016 4:08:41 PM • GE GSH22JFR Side... • Answered on Jul 18, 2016
2answers
I have a 7 year old GE model GSS25WGMD Side by
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
4/17/2015 8:00:48 PM • GE GSH22JFR Side... • Answered on Apr 17, 2015
Water dispenser not working-water getting to door but not up through line in door
Check to see, if the line is kinked. Are you sure, that the part, that is pressed, to release the water works? I'm not an expert on the model. I'm just asking general questions.
8/17/2014 1:57:13 AM • GE GSH22JFR Side... • Answered on Aug 17, 2014
0answers
What is % medical strenght hydrogen peroxide
The better "solution" is Westley's Bleech-White White Wall Tire Cleaner. Available at WalMart (or most any Auto Supply store) for about $7 for a 1/2 gallon or so. Is great stuff. Will clean all sorts of plastics, white or colors, and many other surfaces, too. Works great in and on plastic picnic coolers, especially - freshens them up and removes the stains. Be careful with it, it is a bit caustic. If you are hyper-sensitive to chemicals, use rubber gloves and open a door for a bit of fresh air when you use it.
1/31/2014 3:10:42 AM • GE GSH22JFR Side... • Answered on Jan 31, 2014
Gss25wgmd ice maker
Hi, Cycle the ice maker and check to see if it send power to water valve, if power is sent, replace valve, if not replace ice maker. Good luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
11/20/2013 12:30:09 PM • GE GSH22JFR Side... • Answered on Nov 20, 2013
0answers
GE GSS25VGMD freezer not freezing but fridge was
Do you see ice buildup on the back of the freezer wall?
10/12/2013 2:06:21 AM • GE GSH22JFR Side... • Answered on Oct 12, 2013
Owners manual for GE TFX 24 R
the lower hinge on the frig side is broken and you have to physical push the door close. would you know a part number. look like plastic thanks
6/8/2013 6:45:07 PM • GE GSH22JFR Side... • Answered on Jun 08, 2013
0answers
Tfx24r
Be the first to answer 2/2/2013 1:31:44 AM • GE GSH22JFR Side... • Posted on Feb 02, 2013Be the first to answer
Freezer/Frig will not get Cold
Check the compressor to make sure it is running. If not then check to make sure you are getting the proper electrical supply to the compressor.
1/28/2013 5:41:33 PM • GE GSH22JFR Side... • Answered on Jan 28, 2013
0answers
GE GSH22JFR Side by Side Refrigerator Logo
102 questions posted
Top Refrigerators Experts
vince
Mike McBirney
Level 1 Expert
Axel Gringmuth
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
ge side side refrigerator door handles
  • Refrigerators
