20 Most Recent Kenmore 40494 / 40495 / 40499 Electric Single Oven Questions & Answers
5answers
Kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
4/26/2022 1:46:39 PM • Kenmore 40494 /... • Answered on Apr 26, 2022
Kenmore electric range model 790.94359700 oven
It appears your heating element/coil has failed in this instance.
First - unplug the unit for 40 minutes and re-try.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
4/29/2019 5:53:12 PM • Kenmore 40494 /... • Answered on Apr 29, 2019
2answers
We are having a difficult
Passing on the solution. Some other blogger helped me, so I hope this will help you. Mine is a Kenmore Gas range, but the hinges might be similar. They are fixed on the door, not on the range. Get a couple sturdy nails or similar items and keep them in your hand. Use your foot to push the hinge all the way down, as if the door were fully open. You should see a hole in the hinge, in which to insert the nail to hold the hinge open. Repeat on the other hinge. Carefully lift the door in place and set the hinges so they hook onto the latches properly. You should be able to open the door a bit to take the tension off the nails. remove the nails, and that should be it. Even if your hinges aren't the same as mine, the principle seems to apply. My problem (maybe yours) was that I couldn't open the hinges and keep them open when trying to replace the door. They just would snap closed. Very frustrating.
12/29/2018 12:31:10 PM • Kenmore 40494 /... • Answered on Dec 29, 2018
4answers
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
7/9/2018 2:17:16 AM • Kenmore 40494 /... • Answered on Jul 09, 2018
10answers
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
4/23/2018 1:55:07 PM • Kenmore 40494 /... • Answered on Apr 23, 2018
I have a Kenmore oven
Articles on the internet suggest not using the self cleaning feature of modern ovens, becuase fuses and other parts may easily burn out due to the high temperature. Suggested methods to open a locked Kenmore oven at the artlcle at the link below: http://homeguides.sfgate.com/clear-oven-lock-mechanism-kenmore-stove-71754.html How to Clear the Oven Lock Mechanism on Kenmore Stove
3/4/2018 7:09:54 PM • Kenmore 40494 /... • Answered on Mar 04, 2018
2answers
Kenmore oven 790 model number, door locked, won't open
do you have a button with a small padlock symbol? yes hold for 10 seconds no..do you have start button? press and hold for 5 seconds no...how about a clear/off press and hold for a full 3 seconds. Sorry I'm at home and the teck guides are not here. So I gave it what I know from memory. last but not least try turning off the breaker to it for a minute. Hope this helps a little.
2/2/2018 1:28:41 AM • Kenmore 40494 /... • Answered on Feb 02, 2018
0answers
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
1/14/2017 4:52:02 AM • Kenmore 40494 /... • Answered on Jan 14, 2017
2answers
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
11/22/2016 2:42:04 PM • Kenmore 40494 /... • Answered on Nov 22, 2016
Not sure which model my oven its but it takes a
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
6/8/2016 10:40:35 PM • Kenmore 40494 /... • Answered on Jun 08, 2016
tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Replaced oven element still not heating up
The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off. Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced. Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter. You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges, the oven temperature sensor is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. Most modern ovens use an electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
4/10/2015 5:47:44 PM • Kenmore 40494 /... • Answered on Apr 10, 2015
Kenmore electric oven will not bake
4/10/2015 5:37:37 PM • Kenmore 40494 /... • Answered on Apr 10, 2015
Direct spark ignition wont fire on bake or broil
Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter. You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges, the oven temperature sensor is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. Most modern ovens use an electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
4/10/2015 5:36:49 PM • Kenmore 40494 /... • Answered on Apr 10, 2015
Small back elements only work on high settings
4/10/2015 5:32:22 PM • Kenmore 40494 /... • Answered on Apr 10, 2015
Why doesn't my gas oven work? Is there a brand of stove called Rose?
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary. 2.Power cord plugged in?Grab the plug and wiggle to determine a good connection. 3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires. 4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board. If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse. THINGS TO CHECK: the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage. If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off. Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced. Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter. You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges, the oven temperature sensor is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. Most modern ovens use an electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
4/10/2015 5:26:02 PM • Kenmore 40494 /... • Answered on Apr 10, 2015
Cost to repair oven temperature sensor probe
a simple process not to expensive
4/10/2015 5:24:38 PM • Kenmore 40494 /... • Answered on Apr 10, 2015
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
806 questions posted
Top Kenmore Ovens Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Ovens
  • Kenmore Ovens
Most Popular Question
change from c f
  • Ovens
