20 Most Recent Sun Java Studio Standard 5 (SSJI9501TL9M) for PC, , Linux Questions & Answers
3answers
Error 1335
Method 2: Change the memory settings for installation To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
By xIN3N
12/15/2017 7:41:58 AM • Sun Java Studio... • Answered on Dec 15, 2017
3answers
Jawa void
you should not use arguments in void function in java ... in java pertaining to void the compiler doesn't understand the arguments and treats that as invalid... in c it is ok
1/1/2015 8:45:28 AM • Sun Java Studio... • Answered on Jan 01, 2015
Java runtime enviroment
Please try Re-installing Java Runtime Environment (JRE) in your system. Please Uninstall you JRE if it is installed already and reinstall. Also Unblock Frostwire from Windows Firewall. Please find below the steps to unblock frostwire:
  1. Click "Start."
  2. Type Windows Firewall and click on the "Windows Firewall" in the search result.
  3. Click on the "Allow a program" option on the left-side of the Windows Firewall window.
  4. Click the "Change Settings" button.
  5. Click the "Allow another program" button.
  6. Select "FrostWire" from the list of programs.
  7. Click "Add" to unblock FrostWire from the Windows Firewall.
If these two steps does not work, uninstall and re-install frostwire!:)
11/16/2011 5:32:15 PM • Sun Java Studio... • Answered on Nov 16, 2011
How to make a javascript using numbers
Can you please give more details? :)
8/10/2011 5:34:37 PM • Sun Java Studio... • Answered on Aug 10, 2011
From what year java created?
java was developed in 1995
7/26/2011 12:20:32 PM • Sun Java Studio... • Answered on Jul 26, 2011
What is J2ME?
J2ME
Java Platform, Micro Edition (Java ME) provides a robust, flexible environment for applications running on mobile and other embedded devices—mobile phones, personal digital assistants (PDAs), TV set-top boxes, and printers. Java ME includes flexible user interfaces, robust security, built-in network protocols, and support for networked and offline applications that can be downloaded dynamically. Applications based on Java ME are portable across many devices, yet leverage each device's native capabilities.
Java Security
Java security technology includes a large set of APIs, tools, and implementations of commonly used security algorithms, mechanisms, and protocols. The Java security APIs span a wide range of areas, including cryptography, public key infrastructure, secure communication, authentication, and access control. Java security technology provides the developer with a comprehensive security framework for writing applications, and also provides the user or administrator with a set of tools to securely manage applications.
7/23/2010 3:18:11 PM • Sun Java Studio... • Answered on Jul 23, 2010
I still having trouble to
What kind of problem do you have to download the java software, what is the capacity of your hard drive and what is the size of the RAM on your system?
Makesure there are enough space on your system before you download the java software.
Moreso, you can download on a disc from another system and install on your system. if you need more clarification, you can drop your comment for me to follow up.
Take care.
6/17/2010 1:09:26 PM • Sun Java Studio... • Answered on Jun 17, 2010
Ee.... naka download naman p ko ng java pero ba't
Hi!
Depends on what you need. If you are programming you need the SDK. For just normal usage you need the JRE.
Try downloading the latest from here
http://java.sun.com/javase/downloads/index.jsp
If you are unsure download bothe the JDK and the JRE.
I hope this helps.
6/11/2010 2:10:52 PM • Sun Java Studio... • Answered on Jun 11, 2010
When i open a wesite which uses java then an
update you sun java virtual machine to latest version at www.java.com
6/8/2010 6:51:59 PM • Sun Java Studio... • Answered on Jun 08, 2010
I had try all the
Please elaborate your problem providing us with more detail
Thanks for using FixYa.
6/1/2010 1:01:57 PM • Sun Java Studio... • Answered on Jun 01, 2010
3answers
?Error 1335. The cabinet file
You can follow this steps in correcting the problem that you have.
Run the install locally by copying the installation files to your local hard drive:
1. Using Windows Explorer browse to the location of the installation files.
2. Copy all the contents of the installation location.
3. Temporarily paste them to a location on your local hard drive. For example, on the Desktop.
4. Run the install file.
5. If you still get the same error, re-download the package.
This error is sometimes caused by Anti-Virus software (e.g. Panda AntiVirus). Disable the virus protection software before you proceed with the installation.
5/24/2010 6:49:29 PM • Sun Java Studio... • Answered on May 24, 2010
0answers
I screwed up my Sun java
connect your PC to the internet and type the following
"sudo apt-get update " this command will first update your system.
then type
"sudo apt-get install sun-java6-jre "
1/22/2009 12:29:51 PM • Sun Java Studio... • Answered on Jan 22, 2009
Garmin 5212 sun spot on screen
4/17/2023 2:26:22 PM • Sun Computers &... • Answered on Apr 17, 2023
What is java programming language?
http://en.wikipedia.org/wiki/Java_(programming_language)
In order to understand the difference between high-level programming languages and lower level languages you might have to have a deeper knowledge of computers than you currently have, although I can try to the best of my ability to explain it simply.
Lower level programming languages are more directly related to the actual machine language that the computer ends up reading in the end. Higher level programming languages are less representative of the actual machine code, and as a result may require either a more advanced compiler or may require being compiled several times. Generally higher-level programming languages are easier for the user to write in than lower-level languages.
8/3/2022 11:03:54 AM • Sun Computers &... • Answered on Aug 03, 2022
Getting rid of sun spots on my face
1) You needed a hat 2) You needed to apply sun screen every couple of hours. 3) Not all sun screens are equal. 4) The primary way to avoid sun damage is to stay out of the sun light. One day, people will walk around under umbrellas because of that. 5) Putting aside all the fraudulent claims of skin lighteners (might as well try lemon juice), beauty therapists can subject you to several treatments of a laser like device. It will sting your wallet more than your face. But you have to keep out of the sunlight following treatment or you are wasting your time. If you think you will be able to wander around for half an hour directly exposed to the sun, you are dead wrong. It will undo any therapy. Other than this method and some self-discipline, you would have to resort to makeup, something like Thin Lizzy. Sun damage is such an issue in Australia that they have a slogan: Slip, slap, slop referring to preparation to go out in the sun. Hope you are wearing sun glasses.
12/13/2019 10:28:50 PM • Sun Computers &... • Answered on Dec 13, 2019
Sun Java Studio Standard 5 (SSJI9501TL9M) for PC, , Linux Logo
26 questions posted
Top Sun Computers & Internet Experts
Rob Hill
Rob Hill
Narseman
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sun Computers & Internet
Most Popular Question
error 1335
  • Computers & Internet
