20 Most Recent LG DLE2101 Electric Dryer Questions & Answers
LG Ground terminal block wire exploded. Need to replace entire harness and 4-prong power cord. Do I really need to replace the entire harness or can I buy a new terminal block and cut the black grou
you can buy a new block and you don't have to replace the whole harness if the wire just burnt at the block,you can cut it,put on another wire connector and reconnect it to the block with the cord,make sure when you're done all the nuts and connectors are tight so this doesn't happen again and use the metal cord bracket,if it's not on your cord buy one,it holds the cord in place so when the dryer moves it holds the cord in place,if you don't use it the cord could cut on the metal frame and the wire connectors on the block will come loose from the cord moving or vibrating with the dryer running
2/25/2018 2:30:36 AM • LG DLE2101... • Answered on Feb 25, 2018
Noise from vibration of the bottom panel
Take filter out and take a look with a flashlight and see if you see any coins, paper clips, etc. in the bottom of the filter housing.
1/16/2018 3:10:48 AM • LG DLE2101... • Answered on Jan 16, 2018
This is not a common thing to happen so, If that wire exploded the advice is to get first an electrician to check on the wiring of the house, secondly call a service technician to check on the dryer. Good luck.
4/22/2014 12:13:17 PM • LG DLE2101... • Answered on Apr 22, 2014
Does a diagram exist for the LG DLE2101W dryer
There is a service manual stick inside the dryer if you buy it new.
10/17/2013 3:41:21 AM • LG DLE2101... • Answered on Oct 17, 2013
Dryer beeps while drying
Most likely you have an excess of lint hampering air flow from the dryer. Vacuum out lint filter area, gently remove aluminum exhaust duct behind dryer and make sure it is clear and debris free. Also check exhaust duct port on back of dryer and that the vent going out of your house is clean and not stuck closed or clogged.
1/4/2013 2:12:14 AM • LG DLE2101... • Answered on Jan 04, 2013
0answers
Clothes are not drying, dryer does not heat up.
Hi wwilkiejr
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
9/6/2011 12:15:05 AM • LG DLE2101... • Answered on Sep 06, 2011
The dryers is 16 months old and it's taking
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
7/3/2011 1:36:17 AM • LG DLE2101... • Answered on Jul 03, 2011
The dryer is louder than
The rotating circle was just that someone selected "wrinkel care" as an option, which will turn the dryer on for a 10 second no heat tumble every 6 minutes after the regular cycle is done. It will continue that until the door is opened or power is turned off for up to 3 hours.
Noises could be drum support roller(s) or objects caught in the felt drum seal.
3/13/2011 4:57:46 PM • LG DLE2101... • Answered on Mar 13, 2011
2answers
Clothes Have a sour smell when dried
The moldy odor in this front loading washer (and most other front loaders, too) and the clothes washed in ti is due to the way the washer are built. There's almost always some water that doesn't get pumped out all the way. The water along with detergent residue left inside the machine is the perfect combination for mold growth between wash days.
First stop feeding mold. Stop using "regular" detergent in it. By regular, I mean anything that isn't an "HE" type. You've got to use the types designated as "HE" (High Efficiency). They suds up a lot less, and due to the significantly less water our front loaders use, actually leave less soap residue (that is a large source of the mold and musty smell) behind the tub of front loading machines. I use only about 1/2 of the HE detergent recommended on the bottle and get very good results.
Second, kill off existing mold. Run a clothes-less wash consisting of bleach and HOT water only 1 X week. This should be the last load run whenever the machine will be idle for a couple days or more.
Third, always wipe dry the inside of the tub, detergent & softener dispensing areas, the gasket around the door - particularly the bottom. Again, this is best after the last load is complete.
Fourth, leave all doors open or slightly ajar to allow for air circulation.
Some products that are designed to rid odors from your washer.
Finally, to remove the existing mold smell from the machine, one or two initial treatments (followed by regular treatments) of a product called "Affresh" (or equal) as directed. Some people have good luck with vinegar, too.
I hope this helps and good luck! Please rate my reply - thank you.
3/8/2011 6:19:04 PM • LG DLE2101... • Answered on Mar 08, 2011
Dryer making a humming noise, but drying fine
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
For this FREE answer, Please rate me
10/3/2010 7:51:13 PM • LG DLE2101... • Answered on Oct 03, 2010
Dtyer load and air not venting to outside vent
The blower motors on these dryers can be packed with lint. It is a fire hazard. The entire front of the dryer has to be removed.
7/4/2010 3:51:56 PM • LG DLE2101... • Answered on Jul 04, 2010
2answers
Leaking dryer, LG dlec855w, common problem? Any idea on how to fix?
Back flush the Drain hose off the machine using a hose attached to a tap and taped up or you will get soaked. The inside coats with fluff and may be partially blocked.
1/22/2026 9:28:06 PM • LG Dryers • Answered on Jan 22, 2026
4answers
My dryer stopped working. It is a LG Sensor Dry model number DLE 2101 W. Won't start at all. It stopped during drying, now will not run at all. Light doesn't even go on when you open door
Fuse, safety device or circuit board failure? Have you checked the power outlet on the wall to make sure there is power there?
12/16/2025 3:07:50 PM • LG Dryers • Answered on Dec 16, 2025
LG Artcool Mini Split A/C System. I am getting a CA error code on it?
You need a service call. It is overheating. All these sensor are in the outside unit, there are a lot less on the inside unit. Make sure the condenser fins on the outside unit are cleared of dust an debris from the winter. Plus the inside filters. Fault Code CA or 10 flashes This fault is caused by the compressor discharge sensor reading over 130?C or the discharge Thermistor being faulty.
Fault Codes for all LG wall mounted and Artcool split system
airfusion.co.uk https://www.airfusion.co.uk > fault-codes-all-lg-wall-mo... ..
6/24/2024 12:07:43 AM • LG Dryers • Answered on Jun 24, 2024
LG Gas Dryer. What does U0118:F0 mean, on an LG gas dryer please?
If it is a gas appliance it can only be worked on by a certified gas technician. They are too dangerous when they go BOOM! However, this says it is just a lint filter issue
LG Dryer - Error Code List ' LG USA Support
LG Electronics https://www.lg.com > support > help-library > lg-dryer-... Mar 28, 2024 - An F0 display code or flashing insert filter indicates that the lint filter is out. ..
5/1/2024 5:26:23 PM • LG Dryers • Answered on May 01, 2024
LG DLE2101 Electric Dryer Logo
Popular Tags
20 questions posted
Top LG Dryers Experts
Sudeep Chatterjee
Sudeep Chatterjee
gerbee gomez
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
dryer beeps while drying
  • Dryers
