20 Most Recent Minolta Maxxum 7000 35mm SLR Camera Questions & Answers
2answers
Minolta maxxum 7000 troubleshoot camera wont take pictures
There are several possible reasons, it could be the body or the lens. Check the shutter blades without film. Are they smooth and in place, (flat)? It could also be related to the film, a mis-load of the roll. The lens could have some failure, possibly try another.
3/4/2022 4:43:30 PM • Minolta Maxxum... • Answered on Mar 04, 2022
Camera shows no power with new batteriesAAA & Lithum
Is the camera turned on; okay simple question but sometimes that is all that is needed. Look in the battery compartment is it clean, does it have battery corrosion? Sometimes the wires in the battery compartment become corroded thus not making a connection. If so a CLA will be needed.
11/28/2016 2:36:13 AM • Minolta Maxxum... • Answered on Nov 28, 2016
Film advance motor
This camera is powered by a 6-volt 2CR5 battery. Check the battery, look at the camera battery condition indicator. If it is all black the battery is fully charged. If it does not show all black or partially black remove the battery and test it with a battery tester. If the battery checks good then look inside the battery compartment making sure it is clean without any battery leakage. Again, if the battery and battery compartment are clean as they should be then it may need a CLA.
11/28/2016 2:31:13 AM • Minolta Maxxum... • Answered on Nov 28, 2016
Maxxum 7d first frame
What about the first frame? We need more information!
1/6/2015 5:34:04 PM • Minolta Maxxum... • Answered on Jan 06, 2015
What year manufactured Serial # 11278766
7000s were made from late 70s to mid 80s
1/4/2015 3:21:29 AM • Minolta Maxxum... • Answered on Jan 04, 2015
Minolta maxxum 7000 flashing display
Shutter prob jammed and needs to be re-lubed, Common problem with this mode. Comes from lack of use.l
10/26/2014 3:33:43 PM • Minolta Maxxum... • Answered on Oct 26, 2014
HELP ON SCREEN
Try fresh batteries. Check for corrosion from leaking batteries on contacts and where battery compartment snaps onto battery door. Clean corrosion if there. If you do not measure over 6 volts at the two metal contacts on the door, then this is probably the problem (very common). Otherwise, failure of motor, loose screw in transport gearing unit on top
5/14/2014 12:43:49 AM • Minolta Maxxum... • Answered on May 14, 2014
Is it possible to get 35 mm film for camera?
Any camera store will carry 35mm film, color or black&white, transparency or negative. A narrower selection will also be available at many department or drug store, as well as some supermarkets.
5/10/2014 10:58:33 PM • Minolta Maxxum... • Answered on May 10, 2014
The camera isn't taking the picture
Batteries good? Contacts clean? If battery leakage clean and retest. Is the camera autofocusing? Did this start after you loaded film? Did the camera advance to 1?
1/21/2014 7:18:34 AM • Minolta Maxxum... • Answered on Jan 21, 2014
Old minolta camera service
Minolta Camera Repair (Konica) ' Authorized Service Center ...
www.precisioncamera.com/minolta-camera-repair.html - United States
3/31/2013 5:36:39 AM • Minolta Maxxum... • Answered on Mar 31, 2013
Stick lever impossible to move to indicate or obtain 4x4 advantage
You posted this question in the "Film Cameras" area of FixYa. Please repost in an appropriate area so that the proper experts may see it and give you an answer.
9/17/2012 9:41:28 PM • Minolta Maxxum... • Answered on Sep 17, 2012
I have a minolta maxxum 7000 that i just bought at yard sale and not sure where the off/on button is
There is no such button. Instead there's a slide switch on the top of the camera, to the right of the LCD screen, with three positions marked "LOCK", "ON", and "OFF". See this picture for the location of the "Main Switch".
7/9/2012 4:04:08 PM • Minolta Maxxum... • Answered on Jul 09, 2012
Minolta Maxxum 7000 35mm SLR Camera Logo
152 questions posted
Top Minolta Photography Experts
Ngoro
Are you a Minolta Photography Expert? Answer questions, earn points and help others
View Most Popular
Minolta Photography
  • Minolta Photography
Most Popular Question
need kno off button minolta maxxum 7000
  • Photography
