20 Most Recent Liebert UPStation GXT10000T-240X UPS System Questions & Answers
0answers
0answers
Need to monitor status of Liebert 150 KVA UPS
Try to find your manual here in this site. Choose your Product Category, Product Application, Application Type and Specific Product. After that you can download the manual. Hope this helps. "http://www.liebert.com/servicesupport_pages/ProductDocumentSelector.asp"
3/9/2022 9:09:22 PM • Liebert... • Answered on Mar 09, 2022
Liebert Gxt 10000T230 Service manual
Contact Liebert directly to request or order it.
3/3/2022 12:42:08 AM • Liebert... • Answered on Mar 03, 2022
2answers
Why software for clear fault on liebert ups nx 40 kva
The software allows you access the battery life monitor and reset it. It is the only way to clear the fault
4/28/2021 10:57:05 PM • Liebert... • Answered on Apr 28, 2021
0answers
Liebert gxt3 1500
staticbypass is actvated by the main control card via the press button swith,to transfter back to online mode its still the control card that do the timing for the transition to take place so i would suggest you test with another control card or try and be patient and see if it takes longer time to transfer back to online mode.
11/5/2015 12:15:13 PM • Liebert... • Answered on Nov 05, 2015
Battery over voltage
did you replace battery recently if yes,what is the ah of the new one you moved in,hope its the same ah with the one you moved out,if all batteries are new try to self drain batteries with battery tester and retest again with ups.
11/5/2015 11:45:53 AM • Liebert... • Answered on Nov 05, 2015
Why is my liebert thermostat show loss of power right after its turned on?
its capacitor problem change it with new one
3/30/2015 10:51:04 AM • Liebert... • Answered on Mar 30, 2015
WHERE DO I WIRE THE 24VAC CONTROL WIRING TO THE CONDENSER ON A LIEBERT 3000 air-cooled system at the condenser????? the manual is not specific
The control wires need to be connected to the power relay in the electrical box. The power relay is the switch that feeds hot 220vac to the cold side of the compressor and internals 220vac side. Hope this helps. Kind of generic but should be obvious after you open the electricals cover. There is probably a wiring diagram on the inside cover.
3/24/2015 3:06:32 AM • Liebert... • Answered on Mar 24, 2015
Do you have a manual for this UPS?
yes, which unit do you need?
1/10/2015 7:56:21 PM • Liebert... • Answered on Jan 10, 2015
Liebert gxt2-10000rt208 fault indicator and A + E LEDs on. Did anyone know this alarm?
I'm going to go on a limb and say the unit also has the bypass indicator on as well, is that correct? A=On bypass due to overtemperature condition & E=On bypass due to inverter failure. I can't see in the picture or hear it but is it beeping also? 1 second beep every 2 seconds? Thats on internal bypass. If none of this is true then you have a tricky problem.
1/10/2015 2:28:40 AM • Liebert... • Answered on Jan 10, 2015
Dear sir, For past two days, the battery indicator
replace batteries,low capacity or charge. cant hold charge
11/6/2014 2:06:47 AM • Liebert... • Answered on Nov 06, 2014
Liebert UPStation GXT10000T-240X UPS System Logo
6 questions posted
Top Liebert Computers & Internet Experts
Ngoro
t support
t support
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Liebert Computers & Internet
Most Popular Question
need monitor status liebert 150 kva ups
  • Computers & Internet
