20 Most Recent MDI Nz85004 Implex Urine Drain Bag,2000ml,48 Tubing,dual Hook" Questions & Answers
2answers
Does adding more electrical outlets require to increase breaker amps/condiut?
Yes maybe, depending on what you are doing.1) Electric Code generally says Maximum 12 boxes per electric circuit controlled by 1 circuit breaker. If you have more boxes, then your house can fail inspection IF inspector finds problem. But it is a minor problem if wire size, breaker size, and amp loads are safely matched.http://waterheatertimer.org/How-to-wire-switches.html#add2) Reason for the code: so there is not power loss to last box when many things are drawing power from same circuit, which can cause overheating of circuit and trip breaker, and cause heat damage to some electronic devices and motors.Which is why you are asking the question.3) In practical terms, if you are adding outlets to run another light bulb, then you will probably not notice any problem.However if you are adding plugs so you can run shop tools, or blower motor, or compressor etc, then that can be a problem.For example if wire is too long, there will be power loss to motor which will cause motor overheating and shorten life of equipment.4) Solution. Calculate total amps and watts expected on that circuit.Add up watts of everything running at same time.Volts x amps = watts120 volt microwave uses 1500 watts, how many amps?Amps = watts divided by volts, so 1500 watts divided by 120 volts = 12.5 amps.Compare your total expected amp usage to charts on following link.Make sure you have correct wire and circuit breaker for expected amps. Oversizing wire and breaker are good idea.http://waterheatertimer.org/Color-codewire.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/5/2025 11:29:10 AM • Electrical... • Answered on Dec 05, 2025
2answers
Since a new meter was fitted my lights keep tripping
1) Understand electric service:http://waterheatertimer.org/See-inside-main-breaker-box.html2) Do a heat test on breakers and outlets and switches, than a stress test on main breaker box.http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat3) Check that wire size and breaker size matchhttp://waterheatertimer.org/Color-codewire.html4) Break new meter with hammer and they will replace with another new meter made in China, intended to put local workers out of a job, so we can pay for automated meter reading requiring software owned by foreign investors charging at least 25 cents per month per customer to read the meter, using workers located somewhere else, which doesn't include cost of necessary towers and maintenance, or include software upgrades, or include needed security upgrades. Oh, but you will be able to pay additional monthly fee to get static snapshots of power usage at 15 minute intervals, and the switch controlling your power will be located somewhere besides your town. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/4/2025 6:11:55 PM • Electrical... • Answered on Dec 04, 2025
4answers
UPS SD1110 , positive battery charger module no working
To address the issue with your UPS SD1110 battery charger module, we need to perform a few troubleshooting steps. It sounds like the positive charger might be malfunctioning, as only the negative green LED lights up when 220V AC is connected. Here's a structured approach to diagnose and potentially fix the issue:Check Connections and Fuses:Ensure all connections are secure and properly attached.Check if there are any blown fuses on the charger module, particularly for the positive charger.Inspect for Physical Damage:Look for any visible signs of damage on the positive charger module, such as burnt components or loose wiring.Measure Input and Output Voltages:Using a multimeter, measure the input AC voltage to confirm it's within the expected range (220V AC).Measure the output voltages of both the positive and negative chargers. The positive charger should provide a specific voltage as per the device specifications.Component Testing:Test individual components such as diodes, capacitors, and transistors on the positive charger module. Faulty components can prevent proper operation.LED Indicators:The green LED on the negative side indicates power; check if the positive side LED itself is faulty. If the LED is functional, it may indicate a deeper issue within the circuit.Cross-reference with the Manual:Consult the user manual for troubleshooting tips specific to the UPS SD1110 model. There might be recommended checks or settings to verify.Reset and Restart:Sometimes, a reset can resolve unexpected issues. Disconnect all power sources, wait for a few minutes, and then reconnect.If you are new to electronics repair or need more detailed guidance, it can be beneficial to Learn Free Skills through online resources. Platforms like Coursera, edX, and even YouTube offer valuable tutorials on electronics and troubleshooting techniques.Detailed Steps:Verify Connections and Fuses:Start by turning off the power and unplugging the charger.Carefully inspect all the connections to ensure they are secure.Check for any blown fuses, particularly on the positive charger circuit.Inspect for Physical Damage:Look at the circuit board and components for any signs of damage such as burnt marks or broken parts.Measure Voltages:Set your multimeter to measure AC voltage and check the input at the AC terminals.Switch to DC voltage and check the output at the terminals of the positive and negative chargers.Test Components:If you find that certain components like capacitors or diodes are faulty, replace them and retest.Check LED Indicators:Ensure the positive LED is functional by testing it separately if needed.Consult Manual:Refer to the manual for specific troubleshooting advice related to the UPS SD1110.Reset the System:Disconnect from power, wait, and reconnect to see if a reset resolves the issue.By following these steps, you can systematically identify and resolve the issue with your UPS SD1110 battery charger module. If the problem persists, consider seeking professional assistance to avoid further damage.
10/17/2025 10:41:19 AM • Electrical... • Answered on Oct 17, 2025
GARBAGE DISPOSAL. Not working following a faucet changeout.
It was common for disposals to be direct wired. There will be an electrical cable going to the disposal. If you're uncomfortable removing cover plates and using a multimeter to check power, get a noncontact voltage probe from your local hardware/home improvement store. ~$20 US.
10/1/2025 8:02:43 AM • Electrical... • Answered on Oct 01, 2025
2answers
I need to replace a capacitor for my North Star 8000 w generator. it melted down
You need to run tests on your alternator. We have made some videos to show you how to do this on our website. It is very easy! https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/ We also hold parts for your generator if you need them. You can purchase them on this web page: https://www.generatorguru.com/northstar/ If you need any more help, please contact our Engineers. They will be more than happy to assist you with repairing and parts supply! https://www.generatorguru.com/ask-the-guru/ We are always happy to help! Regards, The Generator Guru Team World Leading Supplier of Parts and Spares for Portable Generators
8/29/2025 11:27:42 AM • Electrical... • Answered on Aug 29, 2025
Black ridge brg 800 will run but overload light is on so can't use it been over it can't find anything wrong with it what do you suggest
it is not a car, it is portable elect AC generator what does overhead light mean?, to the blind. lost the users guide, google to find it and read it first. is always best.
6/25/2025 4:47:33 PM • Electrical... • Answered on Jun 25, 2025
2answers
Donde encuentro el software para programar Harsen modulo GU611A
English language please. "Where can I find the software to program the GU611A module?" Solicita el software online https://www.alfouztech.com/harsen.php Enquire for the software online. Here is a link to your supplier
6/5/2025 7:16:37 PM • Electrical... • Answered on Jun 05, 2025
2answers
Electrical Circuit Breaker.
Question edited for typo.Question moved from Misc category.Unfortunately No! There is a possibility or arcing, contacts heating up and fire. If the breaker is not seating, you may have the wrong one. I seem to recall that there is one make that has two very similar breakers that almost identical, but aren't. Replacing breakers is a job for a professional and should not be attempted by the unlicensed homeowner...
6/2/2025 4:22:44 PM • Electrical... • Answered on Jun 02, 2025
Kipor gen(8.5kva.2cylinder sound proof),couldn't start after I changed the crankshaft and one connecting rod . What could be the solution pls.
If the Kipor generator won't start after you replaced the crankshaft and one connecting rod, there's a good chance something went slightly off during reassembly. That kind of job can throw off timing or internal alignment if even one step is missed. Here's what I'd look at first: 1. Timing might be off When you change the crankshaft, you have to be really careful with the timing marks between the crank and cam. If those aren't lined up perfectly, the valves and pistons won't move in sync, and the engine either won't start or will just crank and spit. It's easy to miss by a tooth or two. 2. Piston or connecting rod could be installed the wrong way Some pistons and rods have to face a specific direction. If you flipped one around by mistake, the engine might lock up or just not run right. It could even affect compression. 3. No compression If the engine spins over freely but won't start, you might not be getting compression. That can happen if a valve is stuck open, the pushrods aren't seated right, or the valve lash (clearance) wasn't adjusted correctly after reassembly. A quick compression test on both cylinders will tell you right away if that's the issue. 4. Flywheel or key might be out of place If the flywheel wasn't installed exactly right, or the key that locks it to the crankshaft got damaged or wasn't lined up properly, your spark timing could be off. That can stop the engine from starting even if everything else is fine. 5. Double-check spark and fuel (just in case) Even though this sounds like a mechanical issue, it doesn't hurt to check if you're getting spark and fuel. Sometimes two problems happen at once, and it throws you off. In short: I'd start by going back over the timing marks, checking compression, and making sure the piston and rod were installed the right way around. Most no-start issues after internal engine work come down to timing or valve setup. Let me know what you find-I can help you narrow it down further if needed.
5/25/2025 1:10:19 PM • Electrical... • Answered on May 25, 2025
2answers
Honda GX690 will not charge battery. Wiring
need to check output of stator in the connector of the voltage regulator it's the two gray wires it should measure 20 plus ac volts then measure the black and white this would be your battery voltage should be 12.6 vdc when running should go up to 14,5 volts dc
5/10/2025 12:33:00 PM • Electrical... • Answered on May 10, 2025
3answers
ETQ TG7000E 7000-Watt Portable Generator. Where is voltage regulator on a TG7000 generator please? It runs but no power output.
It's inside the power head bell housing. See attachment.
4/17/2025 3:15:47 PM • Electrical... • Answered on Apr 17, 2025
Ryobi RG6900 generator. Can anyone please explain in layman's terms how to rewire? My wires were just cut off, and I have no idea were to start joining up wires. please help !!
Question edited for clarity. Two questions merged into one. Duplicated Question deleted, Refresh page to see your question. Here is a typical Ryobi 5500 Generator diagram. https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/homelite/ryobi/lawn-and-garden/inverter-generators/ry905500-inverter-generator-mfg-no-090930295/wiring-diagram There is no Service Manual https://www.google.com/search?q=Ryobi+RG6900+service+manual The owner manual gives the address of the agent in South Africa
OWNER'S OPERATING MANUAL GENERATOR MODEL ...
4x4 Community Forum https://www.4x4community.co.za > attachment PDF Should service become necessary during the warranty period. the owner should contact the authorised Ryobi retailer from whom the product was purchased, or the ... More on wiring here https://www.google.com/search?q=ryobi+rg6900+wiring+diagram ..
4/17/2025 3:12:11 PM • Electrical... • Answered on Apr 17, 2025
Powersmart inverter generator will not start
Try starter fluid. Remove air filter, spray a less than 1 seconds burst into carburetor throat or as close as you can get.
Leave filter and cover off and promptly attempt to start. If it fires and runs for a few seconds and dies, then fuel is not being delivered from carb.
If no fire then either it is flooded, no spark, spark at wrong time, or no/weak compression.
Comment for further assistance.
4/17/2025 2:54:44 PM • Electrical... • Answered on Apr 17, 2025
How to fix a faulty stabilizer or step-down transformer please?
Question edited for clarity. Question moved from Misc category. 'make model (what it is)' of the appliance in all questions please?https://www.instructables.com/Fixing-a-Voltage-Stabilizerplus-Repairing-Tips/ ..
4/15/2025 12:31:36 AM • Electrical... • Answered on Apr 15, 2025
2answers
What should be the voltage at the brushes of a running champion 9k watt generator.
You will get voltage only when the field coils are exited. Check for exiter voltage first.
3/20/2025 1:01:31 PM • Electrical... • Answered on Mar 20, 2025
8700 predator no electric start just makes a sound starter won't engauge
harbor FRIGHT(pun) gen. asking the blind this.? and deaf i can not see it fail or hear it fail so any savvy answer is just generic. well did you pin the engine by hand first. flywheel exposed if engine is dry of oil and seized no engine cranks, like that. my gen, has rip cord start and electric start both, so if battery does the generator is not useless, amazing no? useful at all times. answer 2, starter spins (it) and starter spins flywheel and crank fast but will not start. 1: oil level low and spark is cut by it on purpose 2: spark good tested, good. runs on test fuel now but for 3 seconds 3: gas is bad. 4:making filter clogged too. 5:making carb clogged too 6 or bugs built nest in air cleaner and no air for engine to run. now. i think I got them all if switches not set wrong.
3/20/2025 4:17:04 AM • Electrical... • Answered on Mar 20, 2025
I have a predator 3500 inverter generator It runs great The battery is dead and there's no voltage output
Disconnect the battery negative and see if it produces output.I suspect the battery has deteriorated to the point it is interfering with the DC excitation current.
3/20/2025 4:11:53 AM • Electrical... • Answered on Mar 20, 2025
What is the valve clearance on a Duramax 13000 generator?
Most Duromax OHV engines are as follows with engine cold (ambient air temperature).0.006 in. intake 0.008 in. exhaust
3/20/2025 4:04:17 AM • Electrical... • Answered on Mar 20, 2025
Looking for how set the timing marks on a 3 cylinder Daihatsu 1.0 diesel engine that comes from a Kipor KDE 19 STA Generator. It busted both timing belts and have no reference TIA.
All kinds of repair manuals are available here.Have a look of this may be you will get something useful. Best Manuals
2/27/2025 1:38:19 PM • Electrical... • Answered on Feb 27, 2025
Stramm Generator 2.7kva. What is the valve clearance please?
Question edited for clarity. Question moved from Misc category. This is a virtually unknown make apparently made in China. The Generator Guru website sells spares and gives free advice. Videos may help. https://www.google.com/search?q=stramm+generator+Valve+clearance ..
2/24/2025 7:35:24 PM • Electrical... • Answered on Feb 24, 2025
MDI Nz85004 Implex Urine Drain Bag,2000ml,48 Tubing,dual Hook" Logo
0 questions posted
Top MDI Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a MDI Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • MDI Electrical Supplies
Most Popular Question
always used lutron maestro dimmer
  • Electrical Supplies
