20 Most Recent Powertec Functional Trainer WB-FT11-S Questions & Answers
2answers
Set my chevron digital timer EW32
Where did you purchase this?. They are excellent but I cannot seem to locate them in Australia
10/11/2025 4:32:54 PM • Hardware &... • Answered on Oct 11, 2025
Chevron Digital Timer EW-32. Is there a user manual Chevron timer EW-32 please
Question edited for clarity, add CAPS.Question moved from Misc to Timers.It is here, but terrible clarity.https://www.fixya.com/support/t17165923-user_manual_chevron_digital_timer_ew_32Some suspect websites here.https://www.google.com/search?q=Chevron+EW-32+manual..
4/4/2025 2:38:18 AM • Hardware &... • Answered on Apr 04, 2025
2answers
How Can I Easily Program a Noma Timer Model 052-8835-2?
https://sites.google.com/site/dyiu22/home/noma Quoting from web link:
NOMA
125V AC / 60 Hz OUTDOOR DIGITAL BLOCK HEATER TIMER 052-8835-2 Instructions Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on. To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above. To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm. Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
NOMA Dennis
3/24/2025 1:05:00 PM • Hardware &... • Answered on Mar 24, 2025
WIRING AN OLD WASHING MACHINE
Wiring an old washing machine can be a delicate task and should be done with caution, as improper wiring can lead to electrical hazards. If you're unfamiliar with electrical work, it's always a good idea to consult or hire a professional electrician. Here's a general guide on how to wire an old washing machine, but please make sure you turn off the power supply before proceeding.
Materials Needed:
  • Screwdrivers
  • Wire strippers
  • Electrical tape
  • Multimeter (for testing)
  • Wire connectors
  • Replacement power cord (if needed)
2/28/2025 11:58:09 AM • Hardware &... • Answered on Feb 28, 2025
Pope Aquazone 1010377 Duo-Timer. The system set for Zone A, 1 hour and Zone B for 1 hour ONLY which it does, but then it starts watering Zone A again. How do I stop the latter please?
Question edited for clarity. Question moved from Misc category to Timers. Replace the Internal batteries, use Duracell that are new and fresh. https://cdn2.toro.com/en/-/media/Files/Pope/1010377--AquaZone-Duo-Timer-Manual.ashx Videos that might be of interest, but probably not as there are so many models.
1/25/2025 2:42:07 AM • Hardware &... • Answered on Jan 25, 2025
How to set Westinghouse outdoor timer model 28486
All in this linkhttps://www.google.com/search?q=westinghouse+outdoor+timer+28486+instructionsThen click here and Download.https://thenccusa.com/docs/instructions/stanley/lighttimer-select-trio-sku-28486/And this site is good which lists every timer ever made!Westinghouse timers and manuals:Waterheatertimer.orghttp://waterheatertimer.org > Westinghouse-timers-and-m...Stanley 58485. Light-Sensing Indoor/Outdoor Timer. Buy: Woods at Amazon · Westinghouse 28485 at Amazon · 3 outlet mechanical timer. Resource: Stanley 58485 3-..
1/20/2025 11:57:44 PM • Hardware &... • Answered on Jan 20, 2025
Digital timer. Instructions for SMJ part no. DT2B1C DIGITAL TIMER please?
Question edited for clarity, CAPS and magic word.
DT4B1C Manual
Cromwell Tools https://static-content.cromwell.co.uk > pdfs > SMJ PDF Digital timer. Part No.: DT4B1C. Main functions. ? To pre-set specific on/off times. Specifications. ? 10 on/off cycles per day. ? Individual and daily on/off ... 3 pages ..
1/16/2025 6:23:54 PM • Hardware &... • Answered on Jan 16, 2025
Lost the manual, how do I program Globe on off power plug. 16ULW/ET-469036.
All question need FULL 'make model (what it is)' please. Question moved from Misc category to Timers. If it is this type, you need the Timer in one hand and the manual in the other. https://www.google.com/search?q=16ULW%2FET-469036 Google - make model manual https://www.google.com/search?q=16ULW%2FET-469036 ..
12/19/2024 10:23:52 AM • Hardware &... • Answered on Dec 19, 2024
2answers
Setting date and time on a Hitachi RAR-3U3 split system controller
hi Good News you can find Seiko Digital Watches Instruction manuals from http://SeikoDigitalWatches.com its very good site about Seiko Watches.
12/14/2024 9:27:19 AM • Hardware &... • Answered on Dec 14, 2024
Need instructions for setting up brinks timer
Copy following link for setting analog timers by experimenting with features.http://waterheatertimer.org/How-to-set-timers.htmlhttp://waterheatertimer.org/Woods-timers-and-manuals.html#BrinksAdd a comment and describe product in detail If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/3/2024 9:14:53 AM • Hardware &... • Answered on Dec 03, 2024
Woods E210007 TM-081 photoelectric timer switch. How to program the E210007 timer please.
Question edited for clarity, add magic word. This one? The number you gave comes in a few variations. https://www.manualslib.com/manual/1506235/Eco-Plug-Tm-108.html More here. https://www.lighting-gallery.net/gallery/displayimage.php?album=4648&pos=8&pid=201420. Woods e210007 tm-081 photoelectric timer switchLighting-Gallery.nethttps://www.lighting-gallery.net > gallery > display image Jul 30, 2021 - It is the easiest timer to set that I've ever used. You can't set it for specific times because it depends on the photocell to set the time. .. ..
11/30/2024 12:02:01 AM • Hardware &... • Answered on Nov 30, 2024
Stanley EM-502 outdoor timer. How to properly set the timer please?
Question edited for clarity, add magic word. Question moved from Misc. Not having luck with your model number. Look on the back from embossed instructions. They are not easy to see because black on black writing. There are some instructions here. https://www.google.com/search?q=stanley+em502+outdoor+timer+instructions No EM502 https://www.google.com/search?q=stanley+em502 ..
11/29/2024 11:03:26 PM • Hardware &... • Answered on Nov 29, 2024
2answers
Noma timer model N1505
11/27/2024 3:27:20 PM • Hardware &... • Answered on Nov 27, 2024
Noma ET525C Timer. I would like the instructions please?
Question edited for clarity and toss in some CAPS.
ET525C - UPM Marketing
upm-marketing.com https://www.upm-marketing.com > ET525C_E PDF This heavy duty outdoor timer is ideal for use with security lighting, seasonal lighting, patio and pond lighting, and for the block heater on your car. 1 page
UPM ET525 MANUAL Pdf Download
ManualsLib https://www.manualslib.com > ... > Timer View and Download UPM ET525 manual online. ET525 timer pdf manual download. ..
11/18/2024 11:27:14 PM • Hardware &... • Answered on Nov 18, 2024
How do I programme my geyser timer ISG1201
Step-by-Step Guide to Programming ISG1201 Geyser Timer
  1. Reset the Timer:
    • Before programming, it is often recommended to reset the timer to ensure it is in its default state. There might be a reset button that you need to press using a small pin or similar object.
  2. Set the Current Time:
    • Locate the current time setting on your timer. This is usually done by turning a dial or pressing buttons.
    • Set the correct current time by aligning the dial or using the buttons to set the hours and minutes.
  3. Set the On/Off Times:
    • Your timer will have settings for multiple on/off periods. Typically, this is done using small pins or segments that you can push in or pull out around the dial.
    • Decide the times when you want your geyser to turn on and off. For example, you might want it to turn on at 5:00 AM and off at 8:00 AM, then on again at 5:00 PM and off at 9:00 PM.
    • Set these times by adjusting the pins or segments on the timer. For digital timers, you will need to press buttons to set these times.
  4. Activate the Timer:
    • Once you have set the on and off times, ensure the timer is set to "Auto" mode. This tells the device to follow the schedule you have programmed.
    • There might be a switch or button labeled "Auto," "Timer," or something similar.
  5. Double-Check Settings:
    • Review the settings to make sure the current time and the programmed on/off times are correct.
    • Ensure that all pins or segments are in the correct position, or that the digital settings are accurate.
  6. Install the Timer:
    • Install the timer according to the manufacturer's instructions, ensuring it is correctly connected to the power supply and the geyser.
  7. Test the Timer:
    • Test the timer by manually advancing the time to ensure it turns the geyser on and off at the programmed times.
Tips:
  • Refer to the Manual: Always refer to the specific user manual for your ISG1201 timer model for detailed instructions, as there might be model-specific steps or settings.
  • Safety First: Ensure all electrical installations and adjustments are done safely. If you are not confident in doing this yourself, seek professional assistance.
  • Regular Checks: Periodically check the timer to ensure it is functioning correctly and that the time settings are accurate, especially after power outages or if the device has been reset.
By following these steps, you should be able to program your ISG1201 geyser timer effectively
8/23/2024 6:41:06 AM • Hardware &... • Answered on Aug 23, 2024
Programmed correctly but does not switch off even with the manual on and off. The red light stays off. What can be wrong? Tops TDDGT timer.
This brand only appears to be sold in South Africa. It is an electronic Timer with Battery. When did you last change the battery? If that doesn't fix it, you can try disconnecting the mains power and remove the battery for 15 minutes. Then replace the battery and reconnect the mains. That will effect a power reset to the electronics. If that doesn't fix it, ask the maker to repair or replace it. https://www.hellermanntyton.co.za/binaries/content/assets/downloads/za/manuals-and-operating-instructions/tddgt-email-instruction-manual.pdf https://www.google.com/search?q=tops+timer+tddgt+change+battery ..
8/21/2024 6:27:08 PM • Hardware &... • Answered on Aug 21, 2024
2answers
Setting Noma 8 outlet power bar with timer
Old question resurrected by the removal of an AI Answer. All in this link and video as well https://www.google.com/search?q=Setting+Noma+8+outlet+power+bar+with+timer ..
8/7/2024 5:58:26 PM • Hardware &... • Answered on Aug 07, 2024
Single outlet timer battery replacement 2 double A batteries
Replace it
8/5/2024 4:51:47 AM • Hardware &... • Answered on Aug 05, 2024
The timer on my model number b904ss is not working. What is the problem?
Without FULL 'make model (what it is)', this is what we have. Strangely, I use to live in Shirley, Solihull, West Midlands, age 4 to 19!
B904SS Baumatic 60cm Wide Built in Electric Double Oven
Appliances Direct https://www.appliancesdirect.co.uk > version Buy B904SS Baumatic 60cm Wide Built in Electric Double Oven from Appliances Direct - the UK's leading online appliance specialist.
Baumatic B904SS-B Cooker & Oven Spares
4baumatic https://www.4baumatic.co.uk > b904ss-b > catalogue Buy Baumatic Cooker & Oven B904SS-B Spares, Parts & Accessories at 4Baumatic. Choose from a wide range of Baumatic Cooker & Oven spares.
47 Companies in B90 4SS, Huskisson Way, Shirley, Solihull
Endole https://suite.endole.co.uk > explorer > postcode 1, Be Aerospace Holdings (UK) Limited. Fore 1, Fore Business Park Huskisson Way, Shirley, Solihull, West Midlands B90 4SS. ACTIVE, -, £117.28m ; 2, Page ...
Baumatic B904SS Cooker & Oven Spares
4baumatic https://www.4baumatic.co.uk > b904ss > catalogue Buy Baumatic Cooker & Oven B904SS Spares, Parts & Accessories at 4Baumatic. Choose from a wide range of Baumatic Cooker & Oven spares.
Huskisson Way, Solihull, B90 4SS - 192
192.com https://www.192.com > places Who lives in Huskisson Way, Solihull, B90 4SS? And what businesses operate in this area? How much are people paying for property in Huskisson Way?
07007122 b904ss-b top oven door glass w
Cooker Spare Parts https://www.cookerspareparts.com > cooker-part > b904s... 07007122 part from Cooker Spare Parts. B904SS-B TOP OVEN DOOR GLASS W cooker part for cookers and hobs.
Baumatic B904SS-B Built-in Oven User's Manual
Need Instructions https://www.needinstructions.com > instruction > 3414_b... This owner's manual describes the basic operation of controls and features inside the Baumatic B904SS-B Built-in Oven. Here you will be able to learn about ...
Map of B90 4SS postcode
Doogal https://www.doogal.co.uk > ShowMap Map of B90 4SS postcode in Solihull, England with local information, lat/long: 52.381962, -1.788751, grid reference: SP144760.
BuySpares https://www.buyspares.co.uk > ... > Cooker & Oven Buy Baumatic B904SS-B Cooker & Oven spares and parts with confidence at BuySpares - Baumatic Approved Dealer, Price Match Guarantee and Next Day UK Delivery . ..
7/13/2024 6:34:58 AM • Hardware &... • Answered on Jul 13, 2024
Powertec Functional Trainer WB-FT11-S Logo
0 questions posted
Top Powertec Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Powertec Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Powertec Hardware & Accessories
Most Popular Question
program noma timer model 052 8835 2
  • Hardware & Accessories
