20 Most Recent Weslo Cadence G 5.9 Treadmill Questions & Answers
How to fix noisy weslo cadence 5.9 when I run?
mine is making a loud creaky plastic sound when i walk or do anything on it loud and very annoying everything is tightened
6/22/2022 4:58:52 PM • Weslo Cadence G... • Answered on Jun 22, 2022
I bought a weslo cadence G 5.9 treadmill lastnight but it will not start what do I do
If it's new take it back...
3/5/2019 7:30:05 PM • Weslo Cadence G... • Answered on Mar 05, 2019
2answers
Treadmill will not power up or work
see the video and proceed according. and fix it. However you must test the c. breaker from your outlet box, put some lamp desk , and see if work, if does the problem is the machine for troubleshooting, and contrary case. Rsset the c. breaker.God bless you
3/1/2019 7:05:49 PM • Weslo Cadence G... • Answered on Mar 01, 2019
Does it need oiling
if you are using every day you can lube treadmill every 30 days
5/8/2016 11:32:47 AM • Weslo Cadence G... • Answered on May 08, 2016
How do I lubricate the walking belt
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH The following link will take you to a video on how to apply lube on a treadmill. How to Lubricate Treadmill Using Liquid Lube Video
2/22/2016 4:18:13 PM • Weslo Cadence G... • Answered on Feb 22, 2016
Worked fine for a year, now feels very strange walking on it, have tried lubricating but does not help, feels like bouncing or vibrating while walking, what can be done?
Treadmills often vibrate, just a common side effect of running on it. Location of your treadmill is key most of the time for reducing vibrations or noise due to impact. This impact is spread to the floor from the feet of the treadmill, which is a small surface area. You want to make sure that your treadmill is leveled and it is best that it is placed on a rubber treadmill mat. This will absorb the impact, as well as the sound and the shock of the vibrations. A thick rubber mat will act as both a sound and impact suppressor between you, the machine, and the floor. The thicker the mat, the better. If this does not fix the issue, we would be happy to help you further diagnose the problem by phone 888-713-2880 or by chat at www.sportsmith.net We also have rubber mats available for your treadmill if you need a new one! Otherwise, good luck on the repair :)
8/31/2015 6:57:31 PM • Weslo Cadence G... • Answered on Aug 31, 2015
Belt won't start
Does the incline work? if so, the controller is most likely bad.
3/6/2015 6:41:32 PM • Weslo Cadence G... • Answered on Mar 06, 2015
Replaced motor and motherboard board through warranty but belt still won't work. Not even the power noise will turn on.
The motor, or a connector to the motor, or the controller is faulty. If you can measure DC voltage at the motor (up to 90VDC), but the motor won't turn, and if you can manually move the treadmill belt with your hand or rotate the motor pulley (POWER OFF) with your hand, then the motor's dead. Even IF it was replaced under warranty. If you can't measure any DC voltage to the motor under any conditions, then the problem is in the controller or a connector. Try measuring directly at the controller board.
7/26/2014 10:54:29 PM • Weslo Cadence G... • Answered on Jul 26, 2014
Strange Clicking
You have a minimum 90 day warenty,normally one year.Take the unit back and get a new one.This is why you get a warnty with things you purchase,so if anything goes wrong,you can get it replaced.Or repaired,your option.
4/15/2014 12:22:36 AM • Weslo Cadence G... • Answered on Apr 15, 2014
0answers
0answers
0answers
0answers
0answers
Belt slips
Be the first to answer 3/24/2014 3:17:16 AM • Weslo Cadence G... • Posted on Mar 24, 2014Be the first to answer
Weslo Cadence G 5.9 Treadmill Logo
53 questions posted
Top Weslo Exercise & Fitness Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Weslo Exercise & Fitness
Most Popular Question
worked fine year now feels very strange
  • Exercise & Fitness
