20 Most Recent Kenwood KSC-37 Replacement Charger for TK-3230 Questions & Answers
Kenwood KSC-37 why does red light blink
In the manual, it states that if the LED is Blinking Red "The battery pack is defective or the battery pack contacts are not properly mated with those of the charger" Below is a link to the manual. http://www.buytwowayradios.com/products/resources/Kenwood/KSC-37-Owners-Manual-1.pdf
12/20/2014 1:22:17 AM • Kenwood KSC-37... • Answered on Dec 20, 2014
Charger will not charge radio, has red blinking light
If the radio will charge on one charger and not the other, the one with the blinking light is bad or has a dirty or defective battery contact. Check your charger for debris and clean your battery contacts with a pencil eraser and try charging again. If this fails, replace your charger. Best regards.
1/31/2014 1:30:45 PM • Kenwood KSC-37... • Answered on Jan 31, 2014
Kenwood TK7150 VHF / FM TRANSCEIVER RADIO. KPG-79D software for it please?
Kenwood KPG-79D(K) Radio Programming Software
American Communication Systems https://www.ameradio.com > Kenwood > Software Windows® Programming Software. For KENWOOD TK-7150, TK-8150 radios. Low Price! Qty Discounts, Worldwide Shipping. US$77.00 · 30-day returns
FTDI USB Kenwood TK-7150 TK-8150 Programming ...
eBay https://www.ebay.ca > Coax. Cables & Connectors FTDI USB Kenwood TK-7150 TK-8150 Programming Software KPG-79D & Cable KPG-46 ; Item number. 163238016588 ; Country of Origin. China ; Brand. Kenwood ; Accurate ...Read more
KENWOOD KPG-79D v1.01
radiosofty.com https://radiosofty.com > KENWOOD Download KENWOOD KPG-79D software for Kenwood TK-7150, TK-8150 models. Includes activation key & setup instructions. Easy installation.
KENWOOD Programming Software For TK7150 and Tk8150.
EPCOM https://www.epcom.net > KPG79D-KENWOOD-20812 Compatible With Kenwood TK7150 and TK8150 Radio Models; Intuitive Interface for Efficient Programming Workflow; Advanced Channel Configuration and Customization ...Read more
Kenwood Land Mobile Radio Programming Information
Repeater Builder® https://www.repeater-builder.com > kenwood > kenwood... Some of the earliest KPG DOS programs only support COM1 and COM2. Later on COM3 and COM4 were added. Many older laptops have a hardware COM1 connector.Read more
KENWOOD KPG-79D v1.10 PROGRAMMING SOFTWARE
Public Safety LMR LLC https://www.publicsafetylmr.com > product > kpg-79d Kenwood KPG-79D v1.10 Programming Software KENWOOD OEM KENWOOD KPG-79D v1.10 Works with the following radios TK-7150 TK8150 FOR WINDOWS 98 XP. US$40.00
Kenwood KPG-79D Programming Software for TK-7150, 8150
eBay https://www.ebay.com > itm Kenwood KPG-79D Radio Programming Software. Compatible with Windows 98 through Windows 11. Radio models this software is compatible with include: TK-7150, ...
Kenwood Comercial
K9ROD http://www.k9rod.net > Commercial KENWOOD COMMERCIAL SOFTWARE, USER MANUALS, SERVICE MANUALS FOR DOWNLOAD. (if you have any problems or need something not listed, please contact ...Read more
3/5/2026 12:46:34 AM • Kenwood Radio... • Answered on Mar 05, 2026
How to wire an Astatic D104 Silver eagle to a Kennwood 8 pin mic plug
Wiring an Astatic D104 Silver Eagle microphone to a Kenwood 8-pin mic plug requires matching the correct wires to the appropriate pins. Here's a step-by-step guide: ### Materials Needed - Astatic D104 Silver Eagle microphone - Kenwood 8-pin mic plug - Soldering iron and solder - Wire strippers - Small screwdriver - Multimeter (optional) ### Steps 1. **Identify the Wires on the Astatic D104:** - **Shield (ground)** - **White (audio)** - **Red (transmit)** - **Blue (receive)** - **Black (PTT switch ground)** 2. **Kenwood 8-Pin Mic Plug Pinout:** - **Pin 1:** Mic Audio - **Pin 2:** PTT (Transmit) - **Pin 3:** Down (optional for up/down buttons) - **Pin 4:** Up (optional for up/down buttons) - **Pin 5:** Mic Ground (common) - **Pin 6:** PTT Ground - **Pin 7:** (often unused, sometimes 5V) - **Pin 8:** (often unused, sometimes 8V) 3. **Wiring Connections:** ' Astatic D104 Wire ' Kenwood Pin ' '-------------------'-------------' ' Shield (ground) ' Pin 5 ' ' White (audio) ' Pin 1 ' ' Red (transmit) ' Pin 2 ' ' Black (PTT ground)' Pin 6 ' 4. **Soldering:** - Strip the ends of the wires from the Astatic D104. - Tin the wires by applying a small amount of solder to the exposed wire ends. - Solder each wire to the appropriate pin on the Kenwood 8-pin plug according to the table above. - Make sure to avoid creating any solder bridges between pins. 5. **Assemble the Mic Plug:** - Carefully reassemble the mic plug casing, ensuring no wires are pinched or shorted. - Double-check the connections to ensure they are secure and correctly matched. 6. **Testing:** - Reconnect the microphone to the Kenwood radio. - Test the microphone for proper operation, including audio transmission and PTT functionality. ### Notes: - If you experience any issues, use a multimeter to check for continuity and ensure that all connections are properly made. - Some variations in wiring might exist based on specific models or configurations, so refer to any documentation or schematics you have for both the microphone and radio. If you're uncertain or not experienced with soldering and wiring, it might be a good idea to seek help from a professional or someone experienced in radio equipment.
8/6/2024 8:20:41 PM • Kenwood Radio... • Answered on Aug 06, 2024
2answers
Kenwood TS-430s FM 430 board keys up but no modulation
First, clean all the connectors associated with this board. Over time they can get corrosion built up on them and they stop conducting. Use De-OXIT or Isopropyl alcohol to clean them. You may have to clean the deviation control on the board or replace C* and C10. I doubt if the microphone amplifier, Q1, is bad but if you can check the voltages around it, that might give you a clue. This problem shouldn't be too hard to fix as the rest of the radio is working. Good Luck! a2y9jgk34igeaaaaaelftksuqmcc
1/3/2024 8:50:38 AM • Kenwood Radio... • Answered on Jan 03, 2024
Kenwood nx- p500 / how to connect with no programming base or cable?
See Setting Mode of this manual on page 37. It may solve your problem. NX-P500_K (kenwood.com)
11/12/2023 11:53:05 AM • Kenwood Radio... • Answered on Nov 12, 2023
3answers
Programming a TK-5320 using KPG-112DN V.2.20 keep getting "LOC" in display before the name of the channel.
Yes, radio. Check your cable. Is it OEM? Try plugging it into the radio before launching the software. Then try after launching the software. Is it a USB or Serial cable? If serial, the USB adapters often do not work. I have one brand of radio where I need to restart the computer each time I program so it will read the Serial to USB correctly. Even then, I may need to go into device manager and enable/disable it 2-5 times. I do not know if the software is the latest, but if a radio is programmed with the newest software, you cannot go back to an older version 90% of the time.
7/5/2023 10:16:20 PM • Kenwood Radio... • Answered on Jul 05, 2023
I kenwood TK-2000 radios. when I read the radio, all the frequencies listed are vhf frequencies.but when I program a vhf frequency it says it is out of band it can only accept 400 to 440 mhz.
Based on the information you provided, it seems like the Kenwood TK-2000 radios you have may have been programmed with the wrong band split. The TK-2000 is available in both VHF and UHF frequency ranges, and it's possible that the radios you have are actually UHF models, despite being listed as VHF frequencies when you read the radios. To check if your radios are UHF or VHF, look for a label on the back of the radio that specifies the frequency range. If it says UHF, then the radios can only accept frequencies in the 400-440 MHz range. If it says VHF, then the radios should be able to accept frequencies in the VHF frequency range. If you've confirmed that the radios are indeed VHF models, then it's possible that the band split settings may need to be adjusted in the programming software to match the specific VHF frequencies you're trying to program. I recommend checking the manual for your programming software to ensure that you have selected the correct band split settings before programming the radios. If you're still having issues, it may be helpful to contact Kenwood customer support for further assistance.
2/26/2023 4:13:29 AM • Kenwood Radio... • Answered on Feb 26, 2023
Kenwood TK-3300 can I fix the speaker it is distorted?
You might have to replace the cone if there's not internal issues
12/8/2021 12:53:07 AM • Kenwood Radio... • Answered on Dec 08, 2021
Any idea to why my Kenwood TK-2360 FM Transceiver fully charged has a loud audible noise when turned on accompanied with a flashing red/orange light.
There are a lot of programmable features on that radio. The radio may have a battery that is failing and that could emit a tone, it may have lost the programming that it was set to. Etc. The best bet would be to contact a dealer or service center.
11/9/2021 2:05:59 PM • Kenwood Radio... • Answered on Nov 09, 2021
I have a Kenwood Protalk LT radio. Can hear others speaking clearly but they can not hear me. When press PTT and speak, red light goes on but no one can hear me. I have reset it but no luck fixing
Try opening it up carefully and checking for lose connections, especially the microphone. On second thought most radio communication devices don't allow you to do that so it may be difficult. To test and see if it's the microphone and not the transmitter circuit listen to another radio while you press the button if you hear static or a small pop that means it should be an easy fix if you can get inside. Also what kind of things have you tried already?
2/22/2021 12:36:36 AM • Kenwood Radio... • Answered on Feb 22, 2021
2answers
Servicemanual for kenwood tk 708
Took me 6.5 seconds to find. https://www.manualslib.com/manual/908400/Kenwood-Tk-705.html Really, are you even trying?
9/18/2020 7:13:36 AM • Kenwood Radio... • Answered on Sep 18, 2020
I reset my Kenwood TRC 70 and now it does not want to TX. Please help!!
https://www.scribd.com/doc/3203857/TRC-70-Instruction-manual
4/14/2020 2:41:09 PM • Kenwood Radio... • Answered on Apr 14, 2020
Where do I connect the output from a ctcss board on a kenwood tr9130?
You can connect it to the MIC input through a 10K resistor. That's the easy way. https://www.mods.dk/manual.php?brand=kenwood has a better method. Go to this website and look for the TR-9130 area and you'll find several files.
11/10/2019 8:53:14 PM • Kenwood Radio... • Answered on Nov 10, 2019
Kenwood KSC-37 Replacement Charger for TK-3230 Logo
Popular Tags
2 questions posted
Top Kenwood Radio Communications Experts
Frank Fernandez
Ngoro
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Radio Communications
Most Popular Question
kenwood ksc 37 red light blink
  • Radio Communications
