20 Most Recent Quantaray AF 70-300mm f/4.0-5.6 High Speed Auto Focus Zoom for Minolta Questions & Answers
Quantaray 70-300 zoom lens
The lens is for Minolta/Sony A mount and you are trying to use it on a canon body which has the contacts and mounting points in a different position so it isn't going to work as well as a lens with the correct mount for the body you are using if at all you will need to get the lens mount changed or an adapter built to allow the lens contacts to mate up in the correct order will be cheaper to buy a camera body to fit the lens or a lens that fits the canon mount lens
4/5/2017 5:04:03 PM • Quantaray AF... • Answered on Apr 05, 2017
How can I fix the autofocus on my Quantaray 7-300 lens.
Sorry to say but the lens needs to be sent in for repair. To repair or replace the AF motor is usually around the $200.00 range. Do not try to fix it yourself.
9/9/2014 11:13:05 AM • Quantaray AF... • Answered on Sep 09, 2014
Looking for a carring case and lens cap
If it is just a case and cap go to Ebay to save money
1/26/2014 6:59:25 PM • Quantaray AF... • Answered on Jan 26, 2014
After loading disc from camera into the photo
What do you mean, loading disk... you mean card?
10/25/2013 6:42:29 PM • Quantaray AF... • Answered on Oct 25, 2013
2answers
Image in viewfinder slightly unfocused, photo clear.
Either your viewfinder needs to be cleaned or your camera needs to be cleaned. Most of the time it is the mirror in the camera that is causing this issue and cleaning it will make everything better.
4/15/2013 6:44:12 AM • Quantaray AF... • Answered on Apr 15, 2013
Will this lense work with a Canon Rebel T31 ?
Quantaray makes their lenses with a variety of mounts. A lens with a Minolta mount will not fit onto a Canon camera. A lens with a Canon mount will work just fine on a Canon camera.
12/9/2012 10:35:08 PM • Quantaray AF... • Answered on Dec 09, 2012
Quantaray lense wont work on nikon D50
David - The lowest setting is the highest number; f22 is lower than f4. It's little counter-intuitive, but the lowest setting means the least amount of light - or the smallest aperture opening - not the numerical "f" value of the opening. Simply twist the aperture ring until the highest value "f" number is selected. Many lenses have a small tab or latch to lock them in this position - if yours does, you can use it to prevent this from happening again. You would use a command dial on most camera bodies to electronically change the aperture opening.Good luck!
5/17/2012 6:38:56 PM • Quantaray AF... • Answered on May 17, 2012
Will this lens work with a Canon 5d mkii?
Quantaray makes their lenses with a variety of camera mounts. A lens with a Nikon mount, for example, will not work on a Canon body. As long as you get the lens with a Canon mount, it will work with the 5D MKII.
3/9/2012 5:20:41 PM • Quantaray AF... • Answered on Mar 09, 2012
Will a Quantaray AF 70-300mm
Only if the lens mount is for the Olympus
3/23/2011 3:28:55 AM • Quantaray AF... • Answered on Mar 23, 2011
Quantary 70-300 1:4-5.6 LG, is it compatible with
Quantary makes lenses for a variety of cameras. A lens for a Minolta, for example, will not fit onto a Canon. Assuming you get the lens with a Canon EF mount, then yes, it is compatible with a Canon digital SLR.
1/28/2011 6:59:17 AM • Quantaray AF... • Answered on Jan 28, 2011
One of the gears in my 70-300mm Quantaray lens is
Fixing it could be at Least $ 75 to $100 and since the lens only sells for about $200 it may not be worth fixing. To sell it broken for parts will yeild you much less money. But if you can sell it and get enough money to keep it out of a landfill then it was worth it.
9/26/2010 7:46:10 PM • Quantaray AF... • Answered on Sep 26, 2010
Can the quantaray for Nikon
Yes, assuming we're discussing SLR cameras. It can also be used with most Nikon film SLRs.
9/12/2010 11:53:24 PM • Quantaray AF... • Answered on Sep 12, 2010
Communication error between lens and camera.
Having gone over a month with no response, I assume cleaning the contacts solved the problem.
9/11/2010 10:57:25 PM • Quantaray AF... • Answered on Sep 11, 2010
Will this lens (the Quantaray AF70-300) fit my new
It depends on the mount. Quantaray lenses are available for a wide variety of mounts. If you specifically buy the one with the Nikon mount, then it will work. If you buy one with, say a Canon mount, then it won't fit.
2/1/2010 12:36:40 AM • Quantaray AF... • Answered on Feb 01, 2010
How to use auto fouse
The D40 does not have a focus motor, instead relying on a motor in the lens. This lens does not have such a focus motor, and thus will not autofocus with the D40.
1/20/2010 11:28:38 PM • Quantaray AF... • Answered on Jan 20, 2010
Lense only focuses manually
its not junk, prob too expensive to fix. but makes a nice fixed focus lens. Quantray were on the same level as vivitar, sigma. So they are now that expensive to replace
1/18/2010 4:23:22 AM • Quantaray AF... • Answered on Jan 18, 2010
Hello i have a Quantaray 70-300mm DI f/4-5.6
Look at the writing on the lens. There is a number next to a circle with a line through it. The 70-300 is probably made by Tamron and sold under the Quantaray name. Probably a 62mm diameter.
lightspiritphotography.com
1/3/2010 4:04:57 AM • Quantaray AF... • Answered on Jan 03, 2010
I use thais lense on a cannon rebel xti and it takes black pic
Error 99 is one irritant in many Canon SLRs. In general, it means there is some problem with the contacts. So try cleaning the electrical contacts of the body and lens with a pencil eraser.Please take care to hold the camera upside down while doing this so that the residue does not fall inside. Also take out the battery and clean the contacts. Now re-attach everything and try taking the image. Also check if your lens has an aperture ring and aperture lock. If so, lock the aperture ring at the minimum aperture. If these do not solve the problem, try updating the firmware to the latest one.
12/13/2009 8:41:38 AM • Quantaray AF... • Answered on Dec 13, 2009
Is the quantaray autofocus af70-300 lens
It depends on the mount on the camera.
Quantaray is a 3rd party lens maker. They make the lens itself, then add a mount for each brand of camera lens mount. In some cases, you can have the mount changed at a camera shop.
But the only way to answer your question is to know what camera it was used on previously. If it was used on a Sony, then, likely, yes.
12/11/2009 1:44:52 AM • Quantaray AF... • Answered on Dec 11, 2009
Quantaray AF 70-300mm f/4.0-5.6 High Speed Auto Focus Zoom for Minolta Logo
Popular Tags
43 questions posted
Top Quantaray Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
View Most Popular
Quantaray Cameras
  • Quantaray Cameras
Most Popular Question
after loading disc from camera into
  • Cameras
