20 Most Recent
Seiki 55" LCD TV - SC552GS Questions & Answers
Tv will not power on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
How do i adjust the screen to 1080p?
If you are connected to a PC. Adjust the resolution from the PC to 1920x1080. If are using any media players ( Bluray, WD TV live, Apple TV) the screen will be automatically adjusted to the content you are playing.
How do I use a jump drive to display a power point presentation on my TV?
It means it is only for putting new firmware onto the tv. You won't be able to load anything through this USB port. The TV is looking for a specific filename to run and even if you named your powerpoint presentation the right name, the TV will not be able to display it.
Your next best option is to get a DVD player that has a USB port for MEDIA and load a slideshow of IMAGES. You'll have to export your PowerPoint as images first (obviously).
Seiki TV no picture or sound
hi test the large diodes on the power board these can stop the led from firing up, thanks, ps send me a picture of the power board i'll show you the diodes
shaun
I am trying to connect my Nintendo Entertainment System to my Seiki TV, but it's not working.
It's possible that the connection between your Nintendo Entertainment System and Seiki TV isn't properly set up. Here are some steps you can try:
- Ensure that your Nintendo Entertainment System is properly connected to your Seiki TV. You can use the red and white AV jack to connect the audio cables, and the yellow jack to connect the video cable.
- Once you've made sure that everything is connected properly, turn on both your Nintendo Entertainment System and Seiki TV.
- On your Seiki TV, go to the "Input" or "Source" button on your remote control and select "AV" or "Composite" as the input source.
- If your screen still flashes black and blue, try unplugging and plugging in the cables again, making sure that they are securely connected to both your Nintendo Entertainment System and Seiki TV.
- If you're still having trouble, try using a different set of AV cables, as the cables may be damaged.
If none of these steps work, it's possible that either your Nintendo Entertainment System or Seiki TV is not working properly. You may need to seek further technical assistance to diagnose and fix the problem.
How do I reverse an upsidedown picture on my SEIKI TV
To reverse an upside-down picture on your SEIKI TV, you can try the following steps:
Press the "Menu" button on your SEIKI TV remote.
Use the arrow keys on your remote to navigate to the "Picture" menu.
Scroll down to the "Picture Rotation" option and select it.
Use the arrow keys to rotate the picture until it is right-side up.
Press the "OK" button on your remote to save the changes and exit the menu.
If the above steps don't work or if you can't find the "Picture Rotation" option in the menu, you can also try physically rotating the TV screen by 180 degrees. This may be necessary if the TV was mounted upside down or if it was accidentally rotated.
Keep in mind that the location of the "Picture Rotation" option may vary depending on your specific SEIKI TV model. If you can't find the option, consult the TV's user manual or contact SEIKI customer support for further assistance.
How to I flip the picture on my SEIKI SE32HY10 LED TV
To flip the picture on your SEIKI SE32HY10 LED TV, you can follow these steps:
- Press the "Menu" button on your TV remote.
- Use the arrow buttons to navigate to the "Picture" or "Display" menu.
- Scroll down to the "Picture Mode" option and press "Enter".
- Select the "Flip" or "Invert" option from the list of available picture modes.
- Press "Enter" to save your changes and exit the menu.
If your TV doesn't have a "Flip" or "Invert" option in the Picture Mode menu, you can try accessing the Service Menu to see if the feature is available there. However, accessing the Service Menu requires specific codes and steps, and any changes made in this menu can affect the TV's performance, so it's recommended to do so only if you're experienced in TV repair or have professional assistance.
How do I reverse the picture on my SEIKI SE32HY10 TV
To reverse the picture on your SEIKI SE32HY10 TV, you can try the following steps:
- Press the "Menu" button on your TV remote to access the main menu.
- Use the arrow buttons on your remote to navigate to the "Picture" or "Display" menu.
- Look for an option called "Picture Orientation," "Mirror," or "Flip Horizontal/Vertical."
- Use the arrow buttons to select the option and press "Enter" or "OK" on your remote.
- Check to see if the picture has been reversed. If not, try selecting a different option if available.
If you are unable to find the "Picture Orientation," "Mirror," or "Flip Horizontal/Vertical" option in the Picture or Display menu, it's possible that your TV may not have this feature. In this case, you may need to contact SEIKI customer support for further assistance.
My 40in SEIKI TV turns on and the screen goes black but has sound
Here are a few suggestions for troubleshooting:
- Check the connections: Make sure that all the connections between your TV, cable box, or streaming device are securely plugged in.
- Check the settings: Make sure that the TV is set to the correct input, and that the cable box or streaming device is set to the correct output.
- Check the backlight: Some TVs have a backlight setting that can be adjusted. Make sure that the backlight setting is not turned off or set too low.
- Check for a firmware update: Check if there's any firmware updates available for your TV and make sure that it's up to date.
- Check the cable: If the cable that connects the TV to the wall outlet is damaged, the TV won't turn on. Try unplugging the TV, waiting a few minutes, and plugging it back in.
- Check the T-Con Board: T-Con board is a small circuit board that connects the LCD panel to the main board. It could be malfunctioning, which is causing the image not to display.
- Contact the manufacturer: If none of the above solutions work, it may be necessary to contact the manufacturer for further assistance, your TV may require repair or replacement.
