20 Most Recent Sunbeam 1964,1965,1966,1967 Tiger Badge/pin 64,65,66,67 Questions & Answers
Color code wiring on ford Telstar 2.0 fs distributor
Hi can somebody please send the ford telstar fs 2litre 1993 distributor module and coil colour code please 6pin and 3 pin
10/9/2023 12:00:31 PM • Sunbeam... • Answered on Oct 09, 2023
2005 Honda Odyssey Small Lights Fuse continues to blow. When I press the brakes the Hazard lights come on but do not blink. When I use the turn signal the Hazard lights come on but do not blink. The r
Have you checked the flasher relay. When the hazard switch is on and the breaks are pressed they will stop the hazard lights from flashing until the break is released in most cars. The turn signal only controls one side at a time and will not be effective when the hazard lights are switched to on.
1/29/2018 9:25:36 AM • Sunbeam... • Answered on Jan 29, 2018
0answers
0answers
How to rewire a renault 9 gtl '84 dash board
Start by getting a current schematic. If you are doing the whole dash, I would investigate several manufactures that have a pre-built wiring harness. Otherwise, buy some automotive wire and have at it.
5/6/2014 8:37:38 PM • Sunbeam... • Answered on May 06, 2014
0answers
I have a 1998 linccoln town car and it been giving me trouble its like its not charging my battery is new n my altenator is good what else could be
check cables and wiring to battery, engine, alternator, and body. Maybe you have a stray current draining the battery while the car isn't running. Grab some wrenches and test equipment.
3/31/2014 2:03:21 AM • Sunbeam... • Answered on Mar 31, 2014
O2 wiring for 2004 chevy Blazer
maybe a vacuum leak, a wiring issue, or a fuel delivery problem. What code is exactly coming up? Example: P0171 - o2 sensor too lean
3/31/2014 1:45:46 AM • Sunbeam... • Answered on Mar 31, 2014
Accessories and running lights stay on, ignition off
could be a stereo wiring problem. The illumination wire is obviously tied to battery voltage somewhere.
3/31/2014 1:02:12 AM • Sunbeam... • Answered on Mar 31, 2014
Free wiring diagrams
I have a 2001 buick century and the instrument cluster and tail lights are not working - my friend changed the instrument cluster and head light switch and nothing still works. What do I do next?
3/16/2014 5:57:55 PM • Sunbeam... • Answered on Mar 16, 2014
Sunbeam BL0750 electric blanket green light blinking
Sure, here are a few suggestions on where to find a replacement controller for your Sunbeam BL0750 electric blanket:
* **Sunbeam customer service:** You can contact Sunbeam customer service directly and they may be able to help you find a replacement controller. Their contact information is available on their website.
[Image of Sunbeam customer service website]
* **Online retailers:** There are a number of online retailers that sell replacement controllers for Sunbeam electric blankets. A quick search should turn up a few options.
* **Local hardware stores:** Some local hardware stores may also carry replacement controllers for Sunbeam electric blankets. It's worth checking with your local store to see if they have any in stock.
Once you've found a replacement controller, you can either install it yourself or have a professional do it for you. If you're not comfortable installing the controller yourself, you can take your blanket to a qualified electrician or repair shop.
Here are some additional tips for troubleshooting your Sunbeam BL0750 electric blanket:
* Check the power cord to make sure it's plugged in securely.
* Try using a different outlet.
* Check the fuse or circuit breaker to make sure it's not tripped.
* If you've tried all of these things and the blanket still doesn't work, you may need to replace the controller.
I hope this helps!
5/28/2023 7:35:05 AM • Sunbeam Heating... • Answered on May 28, 2023
Sunbeam 1964,1965,1966,1967 Tiger Badge/pin 64,65,66,67 Logo
86 questions posted
Top Sunbeam Heating & Cooling Experts
Paul Carew
john h
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Heating & Cooling
Most Popular Question
color code wiring ford telstar 2 0 fs
  • Heating & Cooling
