20 Most Recent
Motorola Mobility RAZR V3 Questions & Answers
Voice record!!!!!!!
Press the big side button on the right. Hold it down while the phone is flipped open. Then it should work, hope this works.
10/8/2022 3:06:07 AM •
Motorola...
Answered
on Oct 08, 2022
Voice recorder
the voice key is on the side of the display screen same side as pwr hold that
to record your voice let go when finished
9/23/2021 1:20:46 AM •
Motorola...
Answered
on Sep 23, 2021
Bootloader USB INIT
this happens to phones that have had water damage or something else and a way that might make it work is to take the battery out for no more than 60 seconds and put it back in and push the *,# and power buttons at the same time and if the blue screen comes up, while on the screen push the buttons and hold them until it goes normal. it worked for me
2/25/2021 9:22:31 PM •
Motorola...
Answered
on Feb 25, 2021
Blocking calls, motorola razr v3
Yes, sort of: go to Settings->Security->Enter lock code here if you've created one(otherwise ignore this step)->Limit Use->Restrict Incoming Calls
From this step, you'll have to choose to restrict incoming calls from anyone NOT in your Contacts . You'll still get the voicemails and notifications of who called, but unwanted callers will go right to voicemail and you can call them back whenever you are ready.
10/2/2020 5:07:50 AM •
Motorola...
Answered
on Oct 02, 2020
My cell phone screen dont work ...help
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
10/2/2020 5:07:05 AM •
Motorola...
Answered
on Oct 02, 2020
My phone displays 'unable to charge' or no battery icon?
I plugged my phone up and all of a sudden got the message "Unable to charge" on it. I changed chargers (i had an extra one), i changed batteries (i had an extra one), and i swapped every combination imaginable.
My solution....
My Razr's plug has an opening to plug the phone that resembles a person's navel, and it got dirt and dust bunnies in it while it was in and out of my pockets. I was able to take an old tooth brush (or your new one if your really desperate), and got a can of office duster that you use to clean keyboards. Turn the can of office duster upside down for a second while you are spraying it and liquid will come out as you are spraying the connector. Immediately after that, use your toothbrush to work it inside the dirty connector to free it from anything that will keep it from making good contact. Then, hold the can of office duster upright and it will only spray air... and blow the connector free of anything that you loosened with the brush. Repeat this process if after all this it still doesn't work... because you have a REALLY REALLY dirty connector if it doesn't work after the first try.
10/2/2020 5:06:34 AM •
Motorola...
Answered
on Oct 02, 2020
Motorola br50
you need to take the phone and have the mobile unlocked......or try mobile2mobile.net
5/1/2020 1:15:26 PM •
Motorola...
Answered
on May 01, 2020
