20 Most Recent Comdial 8012S-GT Corded Phone Questions & Answers
"No such station" message appears when I try to
It means there's "No Such Station" :-)
VM extensions are part of the system, usually the pilot number is the lowest of the sequence. If your button got reprogrammed and you're dialing a number that doesn't exist, you'll get that error.
Start by dialing like 22, 23, 24, 25 (4 highest ports in a 0816 DSU). Reprogram the button by Intercom **1 press the button and dial 6xx where xx is the VM pilot number.
Carl
6/23/2011 3:43:21 PM • Comdial 8012S-GT... • Answered on Jun 23, 2011
tip
Comdial 8012S Reference Manual Download
Download Comdial 8012S Reference Manual
Models: Impact 8024S, 8012S, 8324S, 8312S, 8324F
Would you like to review the features of the Comdial 8012S LCD Speakerphone?
Have you lost your Comdial 8012S LCD Speakerphone Reference Manual?
Would you like a digital, searchable, pdf version of the Comdial 8012S LCD Speakerphone Reference Guide?
Follow this link
(& click FREE) to download a pdf version of the Comdial 8012S LCD Speakerphone Reference documentation.
I hope that helps.
____________________________________________________________________
Comdial 8012S Station Manual Download
tip
Download Comdial 8012S Station Manual
Have you lost your Comdial 8012S LCD Speakerphone Station Manual?
Would you like a digital, searchable, pdf version of the Comdial 8012S LCD Speakerphone Station Guide?
Follow this link (& click FREE) to download a pdf version of the Comdial 8012S LCD Speakerphone Station documentation.
I hope that helps.
How do I set the clock on the Comdial
what is the system it is on
5/9/2010 11:28:35 PM • Comdial 8012S-GT... • Answered on May 09, 2010
How do I turn on/up the ringer on the Comdial
with the phone in its cradel hit the volume up button till you get the desired ringer volume
5/9/2010 8:34:17 PM • Comdial 8012S-GT... • Answered on May 09, 2010
How do I change the voicemail time stamp on DX80? I have
contact me at brcrory@buyrite.com and we can see if i can get remote access and change it for you
5/9/2010 8:19:14 PM • Comdial 8012S-GT... • Answered on May 09, 2010
How do I set the time on my phone?
Set system clock:
Press Intercom then *#746*
Dial 01
Dial 00 - 99 for year (10)
Dial 01 - 12 for month (01)
Dial 01 - 31 for day (04)
Dial 00 - 23 for hour
Dial 00 - 59 for minute
Press Speaker to end.
1/4/2010 10:46:24 PM • Comdial 8012S-GT... • Answered on Jan 04, 2010
2answers
How do I change the time/date stamp in voicemail
What type of vm is it, a key voice? If so what type of change do you wish to make. turning it on or off? or getting time correct?
dan
8/20/2009 7:13:06 PM • Comdial 8012S-GT... • Answered on Aug 20, 2009
Headset compatability
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
7/18/2009 11:21:13 AM • Comdial 8012S-GT... • Answered on Jul 18, 2009
COMDIAL PHONE
You cannot set the time directly on the individual phones, this is something that must be set for the entire PBX. You can find manuals for this series of phones here: http://home.maine.rr.com/sfg2/COMDIAL/index.html
3/13/2007 5:00:25 AM • Comdial 8012S-GT... • Answered on Mar 13, 2007
How to disable Comdial Impact headset
Put it on concrete and hit is with a large hammer. The will disable it. Lifting the handset will disable the headset for that call. Recorder mode records your call.
Comdial Digitech DSU Impact Telephones User's Guide
10/3/2023 5:18:17 PM • Comdial Lands... • Answered on Oct 03, 2023
Comdial edge 120 incoming call handling help
It seems like you're trying to configure a phone system or a specific phone to have incoming calls ring on multiple extensions simultaneously or forward to another extension if not answered. The exact steps can vary depending on the phone system or model you're using. If you provide more details about the phone system or model, I can offer more accurate instructions. In the absence of specific information, here's a general guide on how you might achieve this: **For Most Phone Systems:** 1. **Ring All Extensions:** - Log in to the phone system's administration interface. - Locate the call forwarding or call distribution settings. - Look for options related to "Hunt Group," "Ring Group," "Call Distribution," or similar terms. - Create a group that includes the extensions you want the incoming calls to ring on. - Assign the group a number or label. - Configure incoming calls to be forwarded to the assigned group number or label. 2. **Forward After Rings/No Answer:** - Within the same settings area, look for options related to "Call Forwarding" or "Follow Me." - Configure the settings to forward calls to another extension or voicemail after a certain number of rings or if there's no answer. **Example for Asterisk-based Systems (such as FreePBX):** 1. **Ring All Extensions:** - Log in to the FreePBX administration interface. - Create a Ring Group. - Add the extensions you want to include in the group. - Set the Ring Strategy to "Ringall" or "Ring All Available." - Specify the Ring Time (how long it should ring on each extension). - Save the settings. 2. **Forward After Rings/No Answer:** - Create a Follow Me setting. - Add the destination extension(s). - Set the Ring Time (how many seconds it should ring). - Configure the Follow Me List to go to the next destination if there's no answer. - Save the settings. Please note that terminology and options might differ based on your phone system's manufacturer and model. It's important to consult your phone system's documentation or seek help from your IT department or phone system administrator if you're not familiar with the settings or if you're dealing with a complex setup. Keep in mind that making changes to a phone system's configuration can impact its functionality, so it's a good practice to do so during non-peak hours or with proper testing to ensure everything works as expected.
8/26/2023 10:19:47 AM • Comdial Lands... • Answered on Aug 26, 2023
I need help resetting the password to my Comdial 7260 00 voicemail.
To reset the password on your Comdial 7260 00 voicemail, follow these steps:
  1. Dial the voicemail extension from your phone.
  2. When prompted, enter the default password. The default password is usually "0000" or "1234".
  3. Follow the prompts to change your password. If you are not prompted to change your password, press "9" for the mailbox options menu, then "8" for the password menu.
  4. Enter your new password when prompted. Make sure to choose a secure password that you can remember.
  5. Confirm your new password when prompted.
  6. Hang up the phone to save your changes.
If you are still having trouble resetting your password, you may need to contact your voicemail administrator or Comdial customer support for further assistance.
2/27/2023 6:11:10 PM • Comdial Lands... • Answered on Feb 27, 2023
2answers
Switch to Night Mode on the Comdial DX-80 system
I have tried the "Feature 6-3" like it says in the instruction manual, but it says "Code Unavailable." I have tried it from multiple extensions with the same result
10/18/2022 5:42:22 PM • Comdial Lands... • Answered on Oct 18, 2022
Comdial Edge 120. How to disable line 2 please?
Question edited for clarity. Phone your phone service provider. That isn't a problem with the phone it is a line fault outside the property. Normally wet or badly corroded contacts up the pole or in an connection box above or underground.. There is no way to disable a line https://www.telcotel.com/comdial/edge%20120%20userguide.pdf ..
5/3/2022 10:01:42 PM • Comdial Lands... • Answered on May 03, 2022
Comdial 8012S-GT Corded Phone Logo
31 questions posted
Top Comdial Lands Phones Experts
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Andrew
ADMIN Andrew
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Comdial Lands Phones
Most Popular Question
turn up ringer comdial
  • Lands Phones
