20 Most Recent Minolta C350 Printer Questions & Answers
3answers
How to clean LED on bizhub c350
Clean the frame of your LED TV with a soft, clean, lint free, dry cloth. To clean the screen, first try wiping gently with the soft, clean, lint free, dry cloth. If that does not work, spray ScreenClean or another screen cleaner solution onto the cloth. Never spray it directly onto your TV screen. House Office Carpet Residential Commercial Cleaning Geelong Commercial... clean-led-bizhub-c350-myplfqawnrmcm2yt4qrmmiwj-1-0.png
11/21/2015 11:25:34 AM • Minolta C350... • Answered on Nov 21, 2015
As a solution fails in minolta c350 code c-0060
Fusing drive motor failure, replace the fuser recently? (THE HOT PART) there is something jammed the fuser can't turn, orange looking rollers about 12" long, on the right side of the machine. above the transfer belt. Hopefully the motor is not burned out worse case the moor is burned out and that took the control board $$$$$$$$$$$. Open close the front door to reset Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/21/2015 5:27:48 AM • Minolta C350... • Answered on Nov 21, 2015
Misfeed detected but there is no paper jam have removed the paper
It is possible that a switch is stuck. Most commonly on that model it is the switch just above the fuser (the hot part of the machine ). This switch can get stuck or knocked completely out of the machine.
4/21/2015 6:19:06 PM • Minolta C350... • Answered on Apr 21, 2015
Image Transfer Belt Installation for Konica Minolta Bizhub C351
Transfer belt on this model is removed via left and right side of the machine two screws on the right side remove then the belt is pulled from the left side Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/1/2015 8:28:42 PM • Minolta C350... • Answered on Mar 01, 2015
Code c0208
check the black image unit. and reseat it, you mite have a bad one Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/22/2015 2:21:45 AM • Minolta C350... • Answered on Feb 22, 2015
My Konica-Minolta-Bizhub-C350-Color-Copier-Printer paper keeps jamming, why?
well could be several reason incorrect paper size incorrect paper weight are you running Thick 1 or Thick 2 to paper. Do you know how to read paper weight? on out side of the paper package is words 20lb or 36lb mite also see the something like 75 g/m2 that is the weight of paper in the metric world (Every one else except the GOOD OLD USA.:):):) we use the lb. system . select paper on the control panel and make sure the paper weight matches most paper copy are putting both lb. and metric but if it is only metric then use the control panel to figure it as you select the thick 1 or 2 you will see the g/m2 on the control panel, if you using paper off the shelve and don't know then call the company where you get the paper from and ask them. Are using the bypass tray make sure that you follow the icon on the screen when it says load paper in the by pass tray does the little icon show portrait or landscape. if you using legal size paper did you pull out the extention tray to allow additional sensor to come into play for the longer paper. Does you print properties on the computer screen match what is in the draws? IF the paper come wrapped an only has lb. # then you will not find it on the control panel you need to get your operation manual out in that manual will be a chart that show what lb. # equals what thick 1 or thick 2. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/19/2015 4:19:46 AM • Minolta C350... • Answered on Feb 19, 2015
The guides in tray b not set right
Some tray are hard set certain types of media (paper) other have moveable guides C350 has moveable guides for the first draw and second LCC (large capacity) as set for one size Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2015 4:45:12 AM • Minolta C350... • Answered on Feb 04, 2015
Duplex bizhub driver
In Printer Perfrances select back to back or double sided make sure you also select Binding Left for printing second side and you don have to flip the paper over or Top Binding like a lesson top lecture note book Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/25/2015 4:56:23 AM • Minolta C350... • Answered on Jan 25, 2015
C0016 retraction
Black Image unit Motor failure to turn. Remove the black image unit then shake side to side. what you want to do is spread the developer (Located inside the unit) along the entire length of the image unit. BET the image unit was stored up instead of flat, person just picked it up and installed it. All the developer was sitting at one end so the motor could not turn correctly. NEVER EVER STORE I/U UP always Flat!!!. Open & close front door to reset. If it comes back then you might have already burn out the motor, worse case the Control board went bad. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2015 10:19:11 PM • Minolta C350... • Answered on Jan 24, 2015
C350 driver
To offical konicaminolta website drivers are free. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/9/2015 10:02:41 PM • Minolta C350... • Answered on Jan 09, 2015
Image drum unit
Remove the image unit that the operating screen indicates then install the new one don't for get to pull the protective sheet once the image unit is installed Also en sure to shake the image unit There is what is called developer inside it shake I/U side ways to spread the developer along the hole I/u if not and all the developer is sitting at one end when the motor for that unit turns you will get a code or burn out the motor, Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/4/2015 4:51:57 AM • Minolta C350... • Answered on Jan 04, 2015
Konica c350 c0016
Sir/ Mam Your Black PC Drum Motor is failing to turn. 1. open close front door to reset. If that does not work remove the black image unit and shack it side to side we want the developer inside the I/u to spread out along the entire length of the I/u not all sitting at one end of I/u that make the motor have a difficult time trying to turn. All I/u boxes should be stored horiz. not vertical. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2014 9:22:53 PM • Minolta C350... • Answered on Dec 30, 2014
Recent Driver Answer
kmbs.konicaminolta.us In the top right corner you will find the downloads link. You will find all available drivers. The C350 is a older model and there my not be drivers available for newer version computers.
5/25/2014 2:09:58 PM • Minolta C350... • Answered on May 25, 2014
2answers
BIZHUB C350 code C-0208
You need to replace the drum-corona wire assembly. It is a consumable part, but it is a bit more complicated than just replacing a toner cartridge. You will have to determine which color the bad drum is associated with as well.
4/12/2014 6:38:31 PM • Minolta C350... • Answered on Apr 12, 2014
3answers
Error
That is a Fuser Unit pressure/retraction problem. Most likely a faulty unit. If not, then defective connection/motor/system control PCB.
7/8/2013 3:26:54 PM • Minolta C350... • Answered on Jul 08, 2013
Not making copying and show error code no c-0098
Try reset the error code.Turn OFF the copier,press and keep pressed the Utility key turn ON the copier wait to display appaire the Trouble reset message.Release the Utility key,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
3/26/2013 5:58:18 PM • Minolta C350... • Answered on Mar 26, 2013
My printer is printing double image on all colours why?
Color calibration needed.Call your service repr.
8/15/2012 6:45:41 PM • Minolta C350... • Answered on Aug 15, 2012
Hi guys i am saeid from iran.my problem is:i
Having got the details o the problem you posted, i would like to give you the detailed guided step by step clicks you carry out now to fix this problem and get the whole of your pc fast running again.
Its the COMPUTER HELP TEAM PROJECT
Follow up the experts detailed guide to ix the errors with your pc.
Access the platform for fixing all pc errors and optimizing your pc speed HERE
Step 1. success.
2/28/2011 2:06:58 PM • Minolta C350... • Answered on Feb 28, 2011
How do u fix a
Is this error shown when you try to print or when you try to copy? If it shows up when you try to print, then have you set any username and password to copy? Awaiting.
11/14/2010 6:32:26 PM • Minolta C350... • Answered on Nov 14, 2010
Minolta C350 Printer Logo
30 questions posted
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Minolta Office Equipment & Supplies
Most Popular Question
bizhub c350 code c 0208
  • Office Equipment & Supplies
