20 Most Recent Protron PLTV3250 32 in. LCD Television Questions & Answers
2answers
No signal using digital antenna
In some areas, it can depend on the antenna used. In areas close to the stations, you should pick up fine with just about any antenna. If you're out in the country or even thirty to forty-five minutes away from the station, you will probably need an outdoor antenna. Even with this in mind, in some areas, the antenna may need to be higher or lower than your neighbors antenna. As an example, I lived in an area where, with analog television, my outdoor antenna was on a twenty foot pole. When I switched to digital, I had to lower my antenna about five feet. A person, one city block behind me, had mimiced what I had done before and after the switch. Because of the job I had at the time, he showed up at my work and inquiried about the reason he wasn't getting anything. After telling him that I had to play with the height of mine, and that he might need to take his higher, he went to try it. Two days later, he came back saying that he was getting great reception, but he had to go the full extent of his thirty foot pole. That's just within a city block, but I've even talked with people in the country where some have been lucky enough to be able to use an indoor antenna and their neighbors had an outdoor one about twenty to thirty foot high. Some have even needed to go to a good fifty feet.
4/19/2016 4:42:12 PM • Protron PLTV3250... • Answered on Apr 19, 2016
How to adjust color
In all the TV's I have owned, you always push the MENU button on your controller and choose settings. In here you should find the controls for you color adjustments.
4/9/2016 3:06:20 AM • Protron PLTV3250... • Answered on Apr 09, 2016
Plug up and yellow light comes on but never turns Green, get No Picture - No Sound... Ordered new power pack, still same results!!G
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
3/25/2015 8:03:58 AM • Protron PLTV3250... • Answered on Mar 25, 2015
No Power
Get the power cord going into the TV make sure that it is plugged in you may have to move it a little bit once this is done try plugging in again
10/14/2014 2:09:09 AM • Protron PLTV3250... • Answered on Oct 14, 2014
I have a sound but no picture
Your backlight inverter is not working. This is the part that powers the fluorescent lights behind the screen You can either open the the TV and check the inverter for bulging and leaking capacitors or order a new one to replace it.
4/23/2014 10:48:39 PM • Protron PLTV3250... • Answered on Apr 23, 2014
My tv went off when i was watching it what went wrong?
remove the power lead, wait 2-3 minutes and try to power back on. If that fials - repair center it is ...
4/7/2014 9:40:53 AM • Protron PLTV3250... • Answered on Apr 07, 2014
0answers
Tv keeps loosing signal
Check and replace its tuner.
11/16/2013 12:08:42 PM • Protron PLTV3250... • Answered on Nov 16, 2013
Wont stay on one channel
If channel jumps by itself, the memory IC must replaced.
11/16/2013 12:08:25 PM • Protron PLTV3250... • Answered on Nov 16, 2013
Tv is stuck in cartoon mode
Try a hard reset to this TV. Unplug it from AC mains wall socket, and re-plug it back after 15 minutes or so. This must make it a hard reset. It it do not help you, a system reset may be. To make a system reset, you have to enter its service mode option. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many brand TVs are given.
10/27/2013 12:47:11 PM • Protron PLTV3250... • Answered on Oct 27, 2013
Change video board
Video board change is a skilled work. If you wish to get more details about this work, check this link. Pull up older posts there.
3/20/2013 4:56:26 PM • Protron PLTV3250... • Answered on Mar 20, 2013
Powers on no vedio
Hi aenayat6,
Do you hear the sound from the cable channel?
I need to know to assist you further.
Jdvillanueva
3/11/2013 5:01:40 PM • Protron PLTV3250... • Answered on Mar 11, 2013
What is the remote code number?
If your universal remote has a code search function (most do) you may have to try that. Allot of off brand tv's are manufactured by other companies. Check the back of the TV to see if there is a label that says "manufactured for Protron by ..." If a code search doesn't work post back with the brand of remote and we can try help you further.
1/19/2013 5:21:29 PM • Protron PLTV3250... • Answered on Jan 19, 2013
I have power to tv but the screen does not come on ???
No picture and sound
1/14/2013 5:30:37 AM • Protron PLTV3250... • Answered on Jan 14, 2013
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
11/26/2012 3:39:48 PM • Protron PLTV3250... • Answered on Nov 26, 2012
Tv turns on for a few seconds then turns off
Power supply issue is first, second is bad connection somewhere or shutdown circuit is being activated.
11/4/2012 3:51:39 PM • Protron PLTV3250... • Answered on Nov 04, 2012
0answers
Protron PLTV3250 32 in. LCD Television Logo
325 questions posted
Top Protron Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Protron Televison & Video
Most Popular Question
no signal using digital antenna
  • Televison & Video
