20 Most Recent Acer Aspire 5500 5570-2609 Laptop Questions & Answers
2answers
I recently updated to Windows 7 on my Acer Aspire
Make sure all hardware is Windows 7 compatible and that you are using Windows 7 drivers. http://www.microsoft.com/windows/compatibility/windows-7/en-us/Default.aspx
10/17/2021 10:43:51 AM • Acer Aspire 5500... • Answered on Oct 17, 2021
2answers
I am trying to burn a cd on my Acer Aspire
In Windows Media Player, click Library and then, in the List pane, click <List Name> List, and then click Burn List, as shown in the following screen shot.
  1. If you need to clear the list before beginning, click Burn List, and then click Clear List.
  2. Drag a folder from the Contents pane or songs from the Details pane to the List pane to create a list of songs to burn.
  3. In the burn list, drag songs up or down to arrange them in the order you want them to appear on the CD.
  4. Insert a blank CD-R or CD-RW disc in the CD drive.
  5. In the List pane, verify that the songs you have selected to burn will all fit on the disc. If necessary, remove songs from the list by right-clicking a song and then clicking Remove from List, as shown in the following screen shot.
It is possible that a song will not fit even if the total time exactly matches the CD length, because the Player inserts two seconds between songs when burning. Click the Start Burn arrow and verify that Audio CD is selected, as shown in the following screen shot.
lick Start Burn.As the CD is burned, you can check its progress in the burn list. Burning a CD will take some time.Notes It is recommended that you do not try to perform any other actions while burning a CD. For example, playback may be affected if you try to play a music CD while burning a CD.
You cannot burn additional files to a CD after burning is completed. If you are using a CD-RW, you can erase the entire CD before using the Player to burn files to the CD again.
3/28/2020 6:36:24 AM • Acer Aspire 5500... • Answered on Mar 28, 2020
2answers
ON MY ACER 5536 IT HAS A BLURAY STICKER AND SEEMS
If your laptop is still in factory specs (no extra added) then no, it can't because it doesn't have a blu-ray optical unit. That sticker is there to tell you that it's supported, as in you can replace your dvd-rw unit with a blu-ray one. In that case you will need a media player that can play blu-ray movies - the best one is VLC.
3/10/2020 3:08:25 AM • Acer Aspire 5500... • Answered on Mar 10, 2020
3answers
Windows media has sound no visual when playing
Your media player might be having problems getting the video feed from the USB. try copying the file to your local disk and play the movie from there.
10/31/2019 3:45:28 AM • Acer Aspire 5500... • Answered on Oct 31, 2019
2answers
How to play Blu-ray movie on 5536G?
Arcade Deluxe is nothing more than a **** media center with a useless media player in it - get rid of it. If you want to play BR disks there are 2 options: either install a good codec pack like http://www.free-codecs.com/download_soft.php?d=5748&s=775 an use WMP or install and use VLC http://www.videolan.org/vlc/download-windows.html
8/16/2019 2:33:24 AM • Acer Aspire 5500... • Answered on Aug 16, 2019
4answers
Where can i find Windows 2000. It drives me to
If the card is compatible with Windows 2000, it probably is compatible with Windows XP.
If not, access the manufacturer's web-site, and download the device-driver for Windows XP for the device.
7/1/2018 7:47:56 PM • Acer Aspire 5500... • Answered on Jul 01, 2018
Aspire one AOD270 cmos battery removal instructions
u can read manul book acer regard http://www.supportlaptop.com/
3/8/2018 3:35:27 AM • Acer Aspire 5500... • Answered on Mar 08, 2018
Hv acer aspire 5532 laptop
I suggest you take it to a computer shop so either the keyboard can be cleaned or replaced.
2/5/2018 1:23:08 PM • Acer Aspire 5500... • Answered on Feb 05, 2018
Acer aspire 5535-5452 black screen
Many users who updated their older operating systems to Windows encountered various problems. One of the most popular ones is the so-called black screen which may appear both after installation of the new version and in the middle of the updating process. While more advanced users can fix the problems with little effort, beginners face a certain challenge. However, do not give way to panic and call an expert home, because there is a very simple way to cope with the problem, though it requires some work to be done.Very detailed article about it: https://hetmanrecovery.com/recovery_news/windows-10-for-dummies-why-black-screen-appears-and-how-to-solve-the-problem.htm
1/3/2018 8:25:11 AM • Acer Aspire 5500... • Answered on Jan 03, 2018
3answers
Windows Movie Maker is Pixelated
Try this..
Open Movie Maker
Goto TOOLS - OPTIONS
Open the Compatibility Tab
Remove the ticks from ALL filters EXCEPT the Microsoft ones.
If there are only MS filters, the remove the tick from those also.
Post back the results please =)
12/30/2017 4:00:00 AM • Acer Aspire 5500... • Answered on Dec 30, 2017
Acer Aspire 5532 touchpad not working properly
There are free software programs out there to disable touchpads when typing for example When I had a laptop I used a free program called 'touchfreeze' Worked well for me http://touchfreeze.net/
10/19/2017 11:16:28 AM • Acer Aspire 5500... • Answered on Oct 19, 2017
MAKE CHANGE TO ACER ASPIRE 5516 BIOS
You cannot chan ge SN of your laptop. SN of the laptop and SN of the motherboard are not supposed to be the same as for every component in your laptop has it's own SN being produced by different manufacturers even for one single laptop, and the laptop, as a machine built from those parts has it's own. SN is not changable in any way.
8/4/2017 3:46:26 PM • Acer Aspire 5500... • Answered on Aug 04, 2017
Restore my acer aspire 5742 back to factory settings w/out disk
Step 1 Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop. Step 2 Click "All Programs," then the "Acer" folder. Step 3 Select "Acer eRecovery Management" to open the utility. If a Windows prompt asks for permission to run the program, click "Yes." Step 4 Click the "Restore" button in the pane on the left side of the program window. Step 5 Click "Completely Restore System to Factory Defaults." Step 6 Select the "Yes" option in the dialog box that asks you to confirm the action, and click "Start." Step 7 Click "OK" in the second confirmation dialog box to restart the computer. Step 8 Click "Next" in the warning window that appears after the computer reboots. This confirms that you realize restoring the computer deletes any data stored on your hard drive. Step 9 Click "Next" again in the Restore Destination window, and click "OK" in the popup that gives you one last warning about deleting your data. The restoration process will begin. Step 10 Click "OK" when the utility lets you know that the restoration is complete. The computer will restart, and Windows will finish the recovery process.
5/22/2017 12:37:19 AM • Acer Aspire 5500... • Answered on May 22, 2017
I have an Acer Aspire6930 and a Belkin router. My
u mean to say, u r using wireless for internet access right.
Well if u r using XP, and if u r having some trouble in accessing internet, then there might some problem with the components of wireless card. so if u want to fix them, u can fix them with a simple trick.
Go to My Computer's Properties
Go to device manager,
open the tab named NETWORK ADAPTER.
u'll see ur wireless adapter listed. select it & select Uninstall.
Dont worry, just continue reading.
when u click on uninstall, u'll be asked whether u r sure to remove the device from ur computer, meanwhile u'll be given a marking space named UNINSTALL THE DRIVER FOR THIS HARDWARE.
Dont remove the driver, simply uninstall the wireless adapter.
Now its removed.
Now restart ur system, after it starts ur computer shows a ballon named, NEW HARDWARE FOUND and it will automatically install ur wireless adapter,
So ur wireless adapter is fixed by now.
and if u r using Vista, its quite easy there.
go to NETWORK & SHARING CENTRE
go to NETWORK CONNECTIONS u'll find 2 connections.
one will be named as Wireless something.
ENABLE it & click DIAGONISIS
after its completed, select RESET ADAPTER
Its done.
Hope it worked u out.
Thanks..
4/24/2017 8:00:39 AM • Acer Aspire 5500... • Answered on Apr 24, 2017
I have disk read error on my laptop -acer aspire 5520
dear sir
5570z driver winxp download parmistion.
thanking
abhishek mohan
3/10/2017 6:19:12 AM • Acer Aspire 5500... • Answered on Mar 10, 2017
2answers
How can I upload photos to Facebook from the camera roll?
Uploading photos to Facebook is an easy way to share with your family and friends. Facebook offers several options for posting photos, including your profile pictures, photo albums and photos posted to walls. Facebook lets you choose files to upload from your computer or take a photo directly from your webcam. If you want to post photos to Facebook from your webcam, you must first allow Facebook permission to access your webcam. Navigate to Facebook's website and log in to your account. Click "Photo" under the "Share" heading in the center column of your Facebook homepage. Click the "Take a Photo with a webcam" link. Click "Allow" when prompted by Facebook to allow access to your webcam. Check the "Remember" box if you want to automatically allow Facebook to access your webcam in the future. Click the "Close" button. Click the "No Filter" link in the top-left corner of the webcam preview window if you want to apply a filter effect to your photo before posting and choose a filter from the drop-down menu. Click the "No Filter" link if you want to remove the filter. Click the blue camera icon to take a photo. If you want to retake your photo, click the gray "X" in the upper-right corner of the photo window. Enter any text regarding the photo into the "Say something about this photo" field. Click the "Share" button to post your webcam photo to Facebook. You can also post a photo from your webcam directly to your profile wall by clicking the "Photo" link under the "Share" heading on your profile page
12/27/2016 8:17:45 AM • Acer Aspire 5500... • Answered on Dec 27, 2016
2answers
Wi-Fi and Windows Vista Upgrade problems
Concening the wireless connection....if you dont have a router of your own then you must have been sccidently connecting to someone elses that had no security.
What exactly did you do with the upgrade disk and what disk is it?
11/21/2016 8:43:26 AM • Acer Aspire 5500... • Answered on Nov 21, 2016
Acer Aspire 5500 5570-2609 Laptop Logo
2,452 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer aspire 5315 windows vista home
  • Computers & Internet
