20 Most Recent GE 1.4 cu. ft. Countertop Microwave in Black JES1456DSBB Questions & Answers
0answers
JES1456DSBB
Be the first to answer 2/7/2014 11:45:42 PM • GE 1.4 cu. ft.... • Posted on Feb 07, 2014Be the first to answer
2answers
GE Microwave. It will start beeping all by itself.
Ancient Question.Try a power reset. If that doesn't fix it, professional repair or replace.https://www.google.com/search?q=GE+Microwave+will+start+beeping+all+by+itself+flashes+ac+1%2C2%2C3%2C4%2C5%2C6%2C..
5/1/2026 7:33:41 AM • GE Microwave... • Answered on May 01, 2026
How do I dry a microwave that has been rained on?
I would suggest taking the cover off and put a fan on it to help dry it out quicker. You definitely need to make sure that the circuit board is dry before you plug it in. Hope this helps!
1/27/2025 4:12:32 PM • GE Microwave... • Answered on Jan 27, 2025
General Electric microwave not working
Could be many things, but they are too dangerous to work on.Internal fuses, the main capacitor is the most dangerous, the magnetron also dangerous, and any of the many safety interlock switches, or the control panel that operates it all. https://www.fixya.com/support/r29874712-repairing_microwave_ovens..
12/27/2024 7:57:01 PM • GE Microwave... • Answered on Dec 27, 2024
I've got a GE Advantium 120/Model ZCS1001KSS01, the display will get lines thru it, and comes in and out of view, and will always finish its cycle. however, when you go back to use, it is dead.
The problem with your Display of your GE Microwave/Speedcooker is not the Digitron WB27X10856 display board? The flickering and ultimately failure over of the display is due to the WB27X10861 GE microwave control board which is a rebranded (LG 6871W1A417/6871W1A417A board) which GE then sells as a markup. The princple purpose of this board is to convert (i.e. rectify) AC to DC at various voltage levels needed by the rest of the microwave to run their control circuits in the microwave. A portion of the GE microwave is always on so the AC/DC supplly is always on. Overtime the electrolytic capacitors in a section of the board fail or degrade to a point they the DC suppy starts to produce ripples in the DC power supply which results in circuit board failures. These ripples produce deep spikes of voltage of 120 Hz that the other circuits are sensitive too. I just exmined a failed WB27X10861 board and measued the capacitance of each of the seven electroylic capacitors. Of the 7 capacitors, 2 had failed over time. The others 5 have degraded 10 to 15 percent but still within their design spec. The two that failed, C07 - 1000uF 25 V had a measured value of 207uF and the other C08 - 220uF had a measured value of 13uF. There was no visible bloating on either SAMWHA SG capacitor. Nomally, these capacitors are rated at 2000 hour at 85 degree C. 2000 hr is only 83 days, but since the voltage is less and the temperature is probably 40 to 50 degrees inside the capacitor these capacitors may last 10 years. They harder they work the shorter the lifespan. There are two solutions, either purchase a new replacement control board or replace the failed C07 and C08 capacitors within the failed board with better ones. You can easily buy 10,000 hour , 105 degree C rated capacitors for probably 25 cents more than 2,000 hour capacitor. Most people don't have the resouces to repair a board so buying a new board is their only solution. Don't buy a used board on ebay because a used board is probably on the verge of failure.
4/8/2024 10:50:08 AM • GE Microwave... • Answered on Apr 08, 2024
3answers
I need a manual for a GE Spacemaker model 7-4290 . Or access how to set the clock time. I can't find it anywhere online.
Take model # to searspartsdirect.com. They typically have manuals in parts listings.
3/17/2024 6:18:10 AM • GE Microwave... • Answered on Mar 17, 2024
2answers
Can the GE 3-in-1 Countertop microwave be installed inside a cabinet?
No, because it is an Air Fryer and Broiler as well. It would generate too much heat and no where for it it escape. You would need to use it on a counter as described or buy an over the range model.
GE 3-in-1 Countertop Microwave Oven, Complete With Air ...
Best Buy Canada https://www.bestbuy.ca > ... > Countertop Microwaves GE 3-in-1 Countertop Microwave Oven, Complete With Air Fryer, Broiler & Convection Mode, 1.0 cu. ft.1,050 W, Essentials for the Countertop or Dorm, Stainless ... Rating: 4.5 · ‎ 2,370 reviews · ‎ $447.99 · ‎ In stock
3/15/2024 8:00:45 PM • GE Microwave... • Answered on Mar 15, 2024
Can you just repair GE door switch
No Microwave Oven are just too dangerous. The switches and interlocks have to be correctly aligned for safety. Plus the inside has heart stopping voltage waiting to jump to anyone with a half inch away! https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
2/11/2024 9:44:06 PM • GE Microwave... • Answered on Feb 11, 2024
Burn mark on plastic film of microwave door, can I patch with peel and stick plastic? GE MODEL JVM3670SK06
I would not risk it. Your better finding out why there is a burn mark there. The plastic film with the burn mark will be a specific one for microwave ovens. Basic peel and stick plastics could be the wrong type and it could also melt when the microwave gets hot.
12/12/2023 3:37:42 PM • GE Microwave... • Answered on Dec 12, 2023
GE Microwave Model JVM1752SP2SS shuts off after use. Has to be re-booted.
That issue sounds like it it likely to be the control board, or maybe a bad connection to it or a dry joint. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
9/28/2023 2:06:52 AM • GE Microwave... • Answered on Sep 28, 2023
I'm tryiing to remove an old GE Spacemaker Microwave JVM140-001.
it should lift out once you it tilted. page 5 this not your exact model, but they are mounted the same way https://documents.designerappliances.com/Installation-Instructions-JXA019K.pdf
9/11/2023 12:26:57 AM • GE Microwave... • Answered on Sep 11, 2023
How to replace handle GE WR17X 11574
9/6/2023 8:43:15 AM • GE Microwave... • Answered on Sep 06, 2023
GE Profile Convection/Microwave Oven PVM1790SR1SS lights up but won't work
Ck here.... https://www.appliancepartspros.com/repair-help/general-electric-microwave-pvm1790sr1ss-repair/pvm1790sr1ss-wont-start.html But before throwing parts at it give them a call #877#. I'm NOT affilated with them. Best to you.
8/7/2023 7:29:33 PM • GE Microwave... • Answered on Aug 07, 2023
My GE space maker model JVM240BL001 the power is on the digital display reads Enter NORM SOUND 2
Hello, friend! It is noteworthy that if the GE Spacemaker microwave model JVM240BL001 is displaying "Enter NORM SOUND 2" on the digital display, it indicates that the microwave is in the programming mode for adjusting the sound level. To exit this mode and return to normal operation, you can try the following steps:
  1. Press the "Clear" or "Cancel" button. This should clear the programming mode and bring the microwave back to its normal state.
  2. If pressing the "Clear" or "Cancel" button doesn't work, you can try unplugging the microwave from the power outlet for about a minute. Then plug it back in and see if it resets the display.
  3. If the issue persists, consult the user manual for your specific model. The manual may provide additional instructions or troubleshooting steps to resolve the issue.
7/2/2023 5:15:49 PM • GE Microwave... • Answered on Jul 02, 2023
GE 1.4 cu. ft. Countertop Microwave in Black JES1456DSBB Logo
1 questions posted
Top GE Microwave Ovens Experts
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
burn mark plastic film microwave door
  • Microwave Ovens
