20 Most Recent Smeg FAB40PS Top Freezer Refrigerator Questions & Answers
Hi My freezer works fine but my fridge does not
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/24/2011 10:35:30 PM • Smeg FAB40PS Top... • Answered on Aug 24, 2011
How do I defrost freezer compartment without
There should be a hole behind the temp controls in the refrigerator top, you insert a large flat head screw driver in there and turn until you hear a click, then you will hear the fan stop, This is defrost mode. It will advance on it's own if everything is working properly. Tip: Hold the screw driver even and flat to make contact with both edges of the slot when turning.
5/19/2011 10:21:19 PM • Smeg FAB40PS Top... • Answered on May 19, 2011
Frige conparment is not working but the light
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
3/31/2011 8:34:53 AM • Smeg FAB40PS Top... • Answered on Mar 31, 2011
My Smeg FAB40PS fridge has started to freeze the
going the wrong way to make it warmer.
2/22/2011 9:32:31 PM • Smeg FAB40PS Top... • Answered on Feb 22, 2011
Smeg Fab40 fan stopped working - there is a build
There is an upgrade kit for the FAB40 to prevent ice build up which falls under the warranty for the FAB40. I've had it installed and it basically replaces the entire back of the inside of the freezer. Following the upgrade, my FAB40 would ice up completely, plugging the ducts to lead cold air to the fridge below. You can spot this syndrome by the water dripping throught the grate at the top of the fridge compartment. This is melted ice from the freezer ducts. SMEG has now sent their top guy, a drunk and pretty rude guy who replaced the whole backside again, and I'm hoping it will improve.
The bottom line is, SMEG is just ****. Very, very expensive ****. I invested about 10.000 dollars in SMEG equipment three years ago, and every single piece of machinery in my kitchen has broken and needed repair during that time. I deeply regret having bought stuff from them and next time I will definitely go with something different.
5/10/2010 4:27:50 PM • Smeg FAB40PS Top... • Answered on May 10, 2010
SMEG CB300U Not Cooling Top Shelves
could be dirt or rubbish buildup in the small ducts that take cold air up to the top of the fridge.
6/4/2023 2:11:03 PM • Smeg... • Answered on Jun 04, 2023
SMEG FAB28ASR1 freezer working but not fridge
possible bad temp sensor
4/9/2023 9:21:23 AM • Smeg... • Answered on Apr 09, 2023
Can I replace steel hob on a Smeg upright 90cm?
Although the description is vague, (they all have model numbers) I can tell you that all cabinet parts can be sourced on a hob that is only 3 years old. Do it now rather than later. https://www.smegspares.co.uk/ https://www.google.com/search?q=Smeg+90cm+hob+parts ..
11/19/2022 4:42:17 PM • Smeg... • Answered on Nov 19, 2022
2answers
Prevent SMEG fridge from dripping on floor
Hi, please make sure that food isn't being pushed against the evaporation plate Also, please make sure that the outlet pipe isn't blocked with food debris. Thank you.
10/28/2022 2:09:13 AM • Smeg... • Answered on Oct 28, 2022
Smeg Sr620x ice malfunction
defrost all that and try again or get it service\d.
7/24/2022 12:00:08 PM • Smeg... • Answered on Jul 24, 2022
Smeg FAB40PS Top Freezer Refrigerator Logo
21 questions posted
Top Smeg Refrigerators Experts
Sudeep Chatterjee
Sudeep Chatterjee
Kirk Augustin
Kirk Augustin
ADMIN Andrew
ADMIN Andrew
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Smeg Refrigerators
  • Smeg Refrigerators
Most Popular Question
smeg fab40ps fridge started freeze
  • Refrigerators
