20 Most Recent Individual AnyTime Organizer Deluxe 9.0 for PC Questions & Answers
2answers
Anytime Organizer Problems
You could try using 'map network drive' to create a drive letter reference for your network file location. I don't know what operating system you're using, but you should be able to find this option in Windows Explorer.
Select a drive letter that you're not likely to use for anything else (such as X), and enter the path to the file you're trying to use.
( //<your server>/.../ ).
Once this is done you can refer to the file as X:/<your file name> instead of //<your server>/../<your file name>
I hope this helps, let me know if you need any more detail on this!
8/30/2023 8:05:44 PM • Individual... • Answered on Aug 30, 2023
How to convert ATW 'Version 2.0' databases to work in 'Version 9.0' ?
Same answer as before. Get in touch with the maker, but probably cant be done
5/28/2014 7:52:59 PM • Individual... • Answered on May 28, 2014
How convert existing "ATW" files for a new AnyTime Version
The only way to find out is to contact their website Support section. I fear the answer is probably 'No!'
5/28/2014 7:48:19 PM • Individual... • Answered on May 28, 2014
How to convert older "atw" files for a newer "AnyTime Organizer version"?
This often happens when you step up several versions at one time. A suitable workaround is to load your old version, EXPORT the data from the unsupported version and then IMPORT into the new version. Individual Software, the manufacturer of the package has great technical support--if this doesn't meet your needs, please contact them directly! http://www.individualsoftware.com/support/
5/26/2014 3:30:02 PM • Individual... • Answered on May 26, 2014
The font on my organizer
go to vue or edit and enlarge it that way
9/11/2011 3:37:52 AM • Individual... • Answered on Sep 11, 2011
3answers
We downloaded all the holiday and did not download
I dont think that this is an issue about what product you downloaded..but about what choices you've made when you installed it ..Probably you need to uninstall the software ..(assuming that you still have the product key ..and the installer to do the operation again ) ..and after that reinstall the program ..and make the choices for American holidays only ..during the installation .. or ..if there will be no such choices you have to download it again ..and choose the correct one ..
To uninstall it ..just get to control panel ..add remove software ..and choose the program in the list ..and click remove ..
For windows 7 ..and vista ..get into control panel ..(set it to category ..cause it is much easier..) .choose programs ..(uninstall programs )..and select it from the list ...and choose remove from the buttons on top ..THis will remove the program ...and you will be able to reinstall it like you need it ..
1/7/2011 8:31:38 AM • Individual... • Answered on Jan 07, 2011
How can I disable the auto start feature
If you want to disable the program starting with windows do the following
Goto Start
Run
type : msconfig
Click the startup tab
Unclick the program you wish NOT to start with windows
Apply
Reboot
And there you go
5/21/2010 3:23:33 PM • Individual... • Answered on May 21, 2010
After turning on the computer AnyTime is frozen on
press ctrl, alt and delete buttons at the same time. It should lead you to a window where it has an option for you to select "task manager". Choose it and you should see your programs under applications. Select the program you want to end and click "End Task".
5/21/2010 3:22:05 PM • Individual... • Answered on May 21, 2010
hi
say pls what run instrartup
i thnk your os missing some files
if u get my doc in startup
then
go type cmd in run then
sfc /purgecache then
sfc /scannow
put your xp cd in rom
then restatrt sys
3/24/2008 4:21:26 PM • Individual... • Answered on Mar 24, 2008
5answers
Good afternoon. I have N5810PRO
Hi, this is Robert with Geeks On Command computer repair. It's tough to say without doing a full diagnostic on your network, but... It seems like your N5810PRO network storage has some limitations when it comes to folder management from a connected computer. Here are some things you can try: Update to the latest firmware: Check if there is a newer firmware available for your device that may have improved the folder features. Use the file management interface on the device: Log into the web admin panel for your N5810PRO and see if you have more file/folder controls through the interface there. You may be able to create folders there. Map it as a network drive: Map the storage as a network drive letter on your computer (like drive X:). This may allow better drag and drop support. Just keep in mind there may still be restrictions compared to a local drive. Use a third party app: Some apps like NetDrive or WebDrive may provide better integration and control over sftp/webdav network storage devices beyond what your native OS supports. Check if the device supports FTP: See if your device has a FTP server option. Connecting via FTP client may give you better folder control than over http/https. Unfortunately it seems like some consumer NAS devices intentionally limit folder/file manipulations from computers for security or simplicity reasons. But trying the above may help improve folder management capabilities somewhat.
11/30/2023 7:05:07 PM • Individual... • Answered on Nov 30, 2023
2answers
What is the full effect of double taxation?
Less disposable income for the average taxpayer, which causes less buying power, which decreases the expansion of the economy.
8/28/2019 10:09:55 AM • Individual... • Answered on Aug 28, 2019
How do I make or get wifi without an ISP
i am correctly facing this type problem i found searching from goole and visit this site all problem solve just few minute thanks for this site. https://www.epsonprintersupport247.com/epson-l355-wifi-setup/
7/5/2019 5:49:31 AM • Individual... • Answered on Jul 05, 2019
Need to start saving monthly .my work do not have a profident fund.can I become a member as an individual
Go to www.troweprice.com A Roth IRA is probably your best bet - up to $6,000/year max unless you're over 50, which has a $7,000/year max. Your investment earnings are tax-free FOREVER. Look for their Target Date Funds - pick a year when you'll be 70. They do the fund allocation and balancing for you -- on auto-pilot. Just start a $500 (or what you can afford) auto-transfer from your checking account and you're all set. If you can save more than that, you can also invest in any of their funds on an after-tax basis, including target-date funds.
3/31/2019 4:49:25 PM • Individual... • Answered on Mar 31, 2019
My dragon touch tablet is not giving me an option to sign in to my Xfinity account using my email and password. I need an option to log into MY individual account. It is not connecting and I have not been able to use it.
have you tried using a different device to sign in on ? this will prove if problem with your tablet or the Xfinity site, if is a problem on other device as well go to Xfinity site and seach for contact details, FAQ's, etc
1/20/2019 10:56:29 AM • Individual... • Answered on Jan 20, 2019
Individual AnyTime Organizer Deluxe 9.0 for PC Logo
Popular Tags
23 questions posted
Top Individual Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Anonymous
Level 1 Expert
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Individual Computers & Internet
Most Popular Question
convert existing atw files new anytime
  • Computers & Internet
