20 Most Recent
Ipcw 2000 Chevy Camaro - All Camaro models - Headlights Questions & Answers
Measuring for stair carpet
measure the length of the tread and riser, combined. Typically this will be 17 inches or so. Add at least an inch or two for good measure then, assuming all the stairs are the same, multiply by the number of stairs and, in most cases add for one additional riser. This is for straight stairs with no landings or turns. For pie-shaped stairs one needs to measure the longest points for the trad portions.
Flashing orange lights and it's saying F-05
"F-05" with flashing orange lights is used by many different appliances, so I need the brand and model to identify the fault correctly.
Please send:
Brand
Full model number
What type of machine it is (washer, boiler, coffee machine, etc.)
A photo of the display/lights would help too.
Ricoh Aficio MP W5100 Mono Wide Format MFP Printer Scanner. It shows ERROR J006?
Lots of information here plus Service Manuals. It is a Paper Jam or Transport issue.
https://www.google.com/search?q=AFICIO+MP+W5100+ERROR+J006The Aficio MP W5100 error J006 indicates an original document jam in the Auto Document Feeder (ADF/ARDF), specifically often caused by a transport motor failure or binding in the drive belt area.Scribd +1Immediate Troubleshooting StepsClear the Jam: Open the ADF unit cover and remove any jammed originals.Check Originals: Ensure the documents are not folded, torn, or stuck together, and are suitable for scanning (not too thick or flimsy).Check Drive Belt (Technical): If the error persists, the ADF Idler Pulleys and Shafts may need cleaning and lubrication to relieve binding.Restart/Reset: Turn the main power off and then back on to clear the error.Scribd +3If the issue continues, the ARDF drive belt or transport motor may need professional service.
