20 Most Recent Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd Questions & Answers
tip
How to fix a fuse bulb
Fixing a blown fuse bulb should be a very simple task provided one is cautious and has the right tools. I will give you step by step guide on how to go about it: Put Safety First: The power in the circuit with the blown fuse bulb must be off. In most cases, this is done by flicking the correct switch in your circuit breaker panel. Get Your Tools: Some of the items that you may need include; screwdriver, replacement fuse bulb and pair of gloves if necessary to protect your hands. Find The Fuse: Open the fixture or device containing the blown light bulb. This may involve removing a cover or panel. Take Out The Dead Bulb: Gently unscrew the dead fuse from its socket. If it does not come out freely, shake it lightly to loosen it but do not break it. Check The Socket: Inspect for any damages on or inside its socket. Also, if there is damage to that socket you may have to get another one. Install The New Bulb: Screw it into place firmly but don't tighten too much. Power Up Again: Turn back on at circuit breaker and test new light bulb Final Check-Up: Ensure everything is working properly and safely. Dispose of dead bulb properly.
3answers
Looking for a supplier of BRIGHT LED lights for
Go to this site.
http://www.oznium.com/led-flex-strips
Those LEDs are great. They are encased in a water tite package and have the pullup resistors built in so all you need to have is a DC voltage handy. They are made for what you want to do.
12/9/2020 5:47:32 PM • Pyle Pl1157rd... • Answered on Dec 09, 2020
Brake light switch we put a switch and the brake lights are not working
check for ground problems at the tail lights and at the brake light switch
11/22/2016 10:07:35 PM • Pyle Pl1157rd... • Answered on Nov 22, 2016
Why does a fuse keep blowing out for the brake lights?
Look at the fuse when its blows again. If the fuse element in black and lots of spray inside the fuse you have a dead short to ground, work from the lights back towards the switch, follow the wiring looking for any signs of blackened and burned wires and/or black burn spots on the body metal. If its just melted but still a clean break it indicates the circuit is being overloaded at some point. Try disconnecting all items in the smae circuit, plug each in one at a time, once it blows you found which one is casing the problem.
8/11/2014 3:32:18 AM • Pyle Pl1157rd... • Answered on Aug 11, 2014
THE PROBLEM HAVING BRAKE LIGHT ON 2001 CHYSLER CONCORDE STAY ON BEFORE YOU PRESS THE BRAKE
You might want to look at the filaments in the affected bulb. a broken filament can touch the brake filament and cause it to light the brake lite to come on. Test it by turning on the lites and observe the light bulbs . If the brake lites are on replace the bulb. Next ..turn off the lites and check the lites again. If all are off step on the brake pedal once and recheck the lites. If they are on the switch on the brake pedal is bad.
7/17/2014 4:19:57 AM • Pyle Pl1157rd... • Answered on Jul 17, 2014
Why won,t my brake lights on my vauhall agila come on
Check the fuse box. Also check the brake light switch.
6/5/2014 12:21:44 PM • Pyle Pl1157rd... • Answered on Jun 05, 2014
High mount brake light works, but tail brake
I'd check the bulbs and wires on tail lights. Sometimes bulbs go out of place and wires corrode. In my car (not a mercury though) I had to give a little smack on the light to get it working. Of course, eventually I cleaned all wire connections (including ground wire) inside the light and all works now. I had a problem with one light though so if both tail lights are out it might be wires broken/shorted on the way from splitting point where one section heads to the high mount brake light and other to the tail light. Would be good to check the fuses too, they might have different ones. If blinkers and reverse also don't work then it's more likely wire problem like I stated before.
1/17/2014 9:49:18 PM • Pyle Pl1157rd... • Answered on Jan 17, 2014
No dome light inside the car 1998 chevy cavalier,
Is there 12V at the fuse or at the door pin switch?
10/16/2013 11:52:28 PM • Pyle Pl1157rd... • Answered on Oct 16, 2013
1973 buick dash brake light on dash stays on in blinking noise
The brake light switch needs to be readjusted or replaced,
12/3/2012 8:12:28 AM • Pyle Pl1157rd... • Answered on Dec 03, 2012
The left one quit working about 6 weeks ago today
Hello! a device called the Tail Light Relay; Located in the under dash fuse/relay box is the likely culprit...It controls the left/right brake lights but not the middle brake light...Also check that the L/R brake lights have a solid ground...Use an ohm meter...Zero ohms to negative battery terminal...
Guru........saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
5/1/2010 1:37:42 AM • Pyle Pl1157rd... • Answered on May 01, 2010
My brake lights won't work i checked fuses bulbs
Worst case scenario: Wiring is bad. Not too bad if you can run the wires by yourself, but dealerships and auto shop fees for this can get pretty large.
4/15/2010 2:13:28 AM • Pyle Pl1157rd... • Answered on Apr 15, 2010
Brake lights are staying on on my 1995 f250
make sure you have the right switch,right bulbs,and your flasher module my be bad
3/26/2010 12:17:26 AM • Pyle Pl1157rd... • Answered on Mar 26, 2010
My bulb socket for the brakes light is not good
you can go to any parts house and they should have some light sockets that are a direct replacement and a few universal ones just tell them what kind of light u have. u can go to advance auto parts, auto zone, pep boys, napa, carquest or a local mom and pop shop. also u can try the dealership which is the best option or possibly a junk yard for that matter.
10/21/2009 10:14:19 PM • Pyle Pl1157rd... • Answered on Oct 21, 2009
Brake light allwas on and gas gage moves alot
Make sure that you ground the brake at the end of the vehicle with the supplied wire then check if it is still on look at the switch at the pedal that activates the light as for the fuel gauge it may just need a new sending unit if everthing is attached right at first
4/24/2009 11:28:13 PM • Pyle Pl1157rd... • Answered on Apr 24, 2009
1995 buick regal custom brake lights don't work
you may have grounded them out with the turn signals if not you may not be getting the required power for the light according to the manufacturer ,otherwise it possible they need a different power source from the stock oem power But all in all check the ground and make sure your getting 12 volts with a volt meter
4/24/2009 5:27:18 AM • Pyle Pl1157rd... • Answered on Apr 24, 2009
Direct wiring or hard wired advice for brake lights on 2000 tacom
installed the right tail light assembly
3/24/2009 9:47:59 PM • Pyle Pl1157rd... • Answered on Mar 24, 2009
Changing Brake lights on my 2001 honda civic Ex
on some of the newer cars they still will have a foam seal around the perimeter of the tail light that will be very difficult on removal. Do you think you have all the screws removed? If so, try putting some pressure on the tail light, with one hand on one side of the light and one hand on the other side. Not to much pressure just enough to see what is holding it in place and preferably near the corners and work your way around. If you have a hidden/missed screw this will show you without damaging areas.
3/24/2009 9:38:27 PM • Pyle Pl1157rd... • Answered on Mar 24, 2009
Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd Logo
41 questions posted
Top Pyle Car Audio & Video Experts
woodzowl307
Steve Sweetleaf
Steve Sweetleaf
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pyle Car Audio & Video
Most Popular Question
brake light allwas gas gage moves alot
  • Car Audio & Video
