20 Most Recent Jet 3 Ultra Power Chair Questions & Answers
2answers
Troubleshooting
htttp://www.strege.com/BlueDoc I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
12/29/2023 3:33:34 AM • Jet 3 Ultra... • Answered on Dec 29, 2023
Pride Jazzy Jet 3 Ultra Electric Wheelchair. Fuse keeps blowing I was given a Jet 3 Ultra for my mom .. I bought new batteries and installed them.. charged them over night ..
Question edited for clarity. You have a dead short somewhere. You need some electrical knowledge and a digital multimeter for testing. Take all the covers off. Look for wiring that has rubbed through and touching or melted. Disconnect one of the motors and replace the fuse. If it still blows, reconnect that one and disconnect the other motor. If one motor doesn't blow and the other does, you know you have a faulty motor. If neither stop the issue, then you move up to the controller and look up there. With a meter you can check for shorts within the motors, as well as grounds. Or just take it to a Service Centre and have it repaired and serviced properly. Basic troubleshooting
INFINFB2045 Jet 3 Ultra Troubleshooting
Pride Mobility https://www.pridemobility.com > pdf > infinfb2... PDF troubleshooting instructions for the Jet 3 Ultra Power Chair. This information is to be ... A blown charger fuse can cause the charger inhibit to activate.
5/16/2023 4:54:40 PM • Jet 3 Ultra... • Answered on May 16, 2023
Power on , no flashing lights. 3 red 4 yellow, no green. Battery measures 24.6vdc, amp meter always at zero, why no green lights This is a Jet 3 Ultra power chair
Hi u cant rely on battery voltage it won'tell u the condition of the batteries.... The BATTERY'S HAVE TO B LOAD TESTED ONE AT A TIME WITH A 12 VOLT LOAD TESTER AVAILABLE ON E/BAY COST APROX $30 THIS WILL GIVE U A GOOD INDICATION ON THERE CONDITION....cheers img_20190520_194914-gixt1e0noyfjaoejvk4go4o3-2-0.jpg
6/6/2019 9:16:06 AM • Jet 3 Ultra... • Answered on Jun 06, 2019
Need a wiring diagram for jet 3 power chair
Look here: http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_ultra_om.pdf
3/9/2019 12:05:56 AM • Jet 3 Ultra... • Answered on Mar 09, 2019
2answers
JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
7/11/2018 6:02:21 AM • Jet 3 Ultra... • Answered on Jul 11, 2018
2answers
Battries are discharged and now charger does not operate
The batteries will discharge below the reference voltage required for the charger to "see" the batteries if left uncharged for more than a month or more. You have to carefully bring the batteries back up to about 12 volts each for the charger to see them. The easiest way is take them to a qualified battery shop that has a step charger for sealed batteries. If you attempt to use a car charger on sealed batteries, you will ruin the batteries or even blow them up as the cases are sealed and the gas from charging has no way to escape. Some people have used a standard car battery charger on low only, applying a charge to one battery for about 15 minutes, then the other for 15, etc. until the batteries are back up to 12 volts, but again, using a car charger is dangerous and could cause the battery to explode.
5/23/2018 2:54:23 AM • Jet 3 Ultra... • Answered on May 23, 2018
2answers
The lights are flashing and i cant get the chair t...
The flashing lights is a fault code. Count how many lights are flashing, and let us know, then we can tell you what the fault is. Check that both free-wheel levers are in the correct place. Good luck. Neil.
4/23/2018 9:29:25 AM • Jet 3 Ultra... • Answered on Apr 23, 2018
I was chargeing the jet 3 over nite, next day it
Maybe charger took a surge and fried it I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 7:13:00 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
Where can I find E & J Xcaliber manual?
ask everywhere hard to find! I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 7:11:20 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
Jet 3 Power Chair shows a full charge, drive about a block and the lights indicate almost dead. I turn it off and then back on and it shows more bars and I drive it back home. I've tested both bat
the motors may have won brushes or the brakes are hanging up causing high battery usage I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 7:10:49 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
Can lawn mower batteries be used in Pride Jet 3 scooters?
not a good idea, they are different types, the liquid is acid and it will cause alot of problems with the framework. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 7:09:21 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
Jet 3 ultra serial number
go to pride mobility site and lookup serial number finder I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 7:06:26 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
2answers
How to remove seat
There is a latch under the seat, some are on the posts some ar in the middle some are on the side I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 7:06:19 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 7:02:08 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
How to put the right wire on the battries
red to red and black to black one of each color on each battery I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 6:58:56 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
How to change batteries
check the user manual, is a great place to start I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 6:58:00 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
I want to donate a jazzy jet powerchair. its in good worling condition, just need new batteries.
The batteries range from 160- 500 bucks, look in paperwork for correct size and call around for best prices I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 6:52:47 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
Chair won't start. Peeps once and then displays 3 red, 4 yellow and 1 green. Would like to try to fix myself, as I am handy with these kind of things. Any ideas?
Sorry but it sounds like a controller fault, need new controller Strege Mobility I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 6:49:09 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
Turn it on. it beeps, all the lights turn on for a second then go out. the horn works.not the chair.
unplug the charger. Make sure your battery is good. Strege Mobility I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
10/10/2017 6:42:31 PM • Jet 3 Ultra... • Answered on Oct 10, 2017
Jet 3 Ultra Power Chair Logo
419 questions posted
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Anonymous
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
Jet Health & Beauty
  • Jet Health & Beauty
Most Popular Question
controller light flashes but wont work
  • Health & Beauty
