20 Most Recent
American Bath 60 Inch Windsor Cast Iron Clawfoot Bathtub by American bath Factory with 7... Questions & Answers
A slow daring dathtub
put a part fill in the tub( about 1" deep) with the plug attached to a bit of wire
pour about 1/4 cup of draino ( sodium hypochlorite ) into the water and stir with a broom handle or suitable stirrer pul the plug out and the mixture will dissolve any hair, soap and grease that is blocking the system
NOTE
SODIUM HYPOCHLORITE IS CAUSTIC ( BURNS THE SKIN AND EYES ) SO USE RUBBER GLOVES AND SAFETY EYE WARE AND USE EXTREME CARE
FLUSH THE BATH WELL WHEN DRAINED
Install whilpool tub steps
Generally I will make the entire front skirt of the tub removable. You need to make sure your access is located so that you can remove the pump if necessary.
Access to the plumbing is advisable also but usually not required by code as it can be serviced from the top side. I am a licensed bath contractor and available to help with any problem you may encounter through premium service or live chat. I can save you many hours of frustration and 100's of dollars on this project.
Angle base cracks in factory seams
contact manufacture ask for replacement as it is most likley defect substandered matriels thay may be intrested in the fault in there product and may give you discount on new if you use there product again.
thank you for useing fixya please rate me
I am having trouble removing
It sound like you are having a thought time with the baffle plate removal from your Ultimate Wood Heater! Here are a few steps you can try to help get that last bit out:
1. Check for Obstructions: Ensure there are no other components hindering the baffle plate’s movement, such as debris or residual ash.
2. Gentle Tilting: Carefully tilt the baffle plate forward while pulling it out. Sometimes changing the angle can help clear the lip.
3. Lubrication: If the plate is stuck, a little lubricant (like WD-40) on the edges might help it slide past the lip more easily.
4. Pry Carefully: Using a flat tool like a screwdriver, gently pry at the lip to create more space while you pull the plate out.
5. Check for Warping: Inspect the baffle plate for any warping that might be causing it to stick. A bit of bending might help it clear the opening.
6. Seek Help: If possible, have someone else assist you, as an extra pair of hands might make it easier to maneuver.
If these tips don't help, consider consulting the manufacturer's manual or contacting customer support for specific guidance related to your model!
7/10/2026 6:30:56 AM •
Home
Answered
on Jul 10, 2026
What do you do first in a bathroom remodel?
first of all you need to make a plain of where you want bath or shower, sink,toilet and any vanity cubbards,and radiators to be placed, then you need to make sure all walls are square (wich might mean plastering) floors are sound (no movement), and work out the cost before you start, all the best.
7/7/2026 1:08:57 PM •
Home
Answered
on Jul 07, 2026
Which is best, Tiles or PVC panels for bathroom
Old question that just had spam removed which brings it back to view on the homepage.I expect you have already decided, but PVC Panels are fast to install and provide a good watertight seal over showers and baths. They are easy to clean and require little to no maintenance.Tiles are more durable and give you endless colour ways, sizes and styles. Some maintenance (grout cleaning) is required if they are in an environment that gets wet.
https://www.google.com/search?q=Tiles+or+PVC+panels+for+bathroom..
5/11/2026 5:48:30 AM •
Home
Answered
on May 11, 2026
I made soup in my Seb pressure, but now I can't get the lid off. What do I do?
Light colors like white, beige, and soft pastels can make a small room look bigger by reflecting more light and creating an open feel. Avoid dark colors on all walls, as they can make the space feel smaller. ?? Learn more here:https://www.housebeautiful.com/room-decorating/bedrooms/g2231/small-bedroom-design-tips/
3/25/2026 6:45:41 AM •
Home
Answered
on Mar 25, 2026
How to Fix my house so it look more attractive to customers?
Selling a home is a huge step, involving various modifications, the search for an excellent real estate agent and finally managing to negotiate a reasonable price for your home. Aside from all that, you'll need to make a few more steps to make your house attractive to potential buyers and sell it quickly and at a high price.
- Light it up
- Don't show off pets
- Hire a good real estate agent
- Improve the exterior
- Make the house show-ready
3/16/2026 1:20:42 PM •
Home
Answered
on Mar 16, 2026
