20 Most Recent JUMP START SYSTEM Questions & Answers
2answers
How long to recharge a peak portable power system 450 plus
  1. Using an AC Outlet (110V):
    • The system can take approximately 24-36 hours for a full recharge when connected to a standard household outlet.
  2. Using a DC Outlet (12V):
    • When connected to a vehicle's DC outlet (cigarette lighter), the recharge time is usually longer, often around 30-36 hours.
Steps for Recharging:
  1. Turn Off All Outputs: Ensure that all output switches are turned off to avoid drawing power during the charging process.
  2. Connect to Power Source:
    • For AC charging, use the supplied AC adapter and plug it into a wall outlet.
    • For DC charging, use the supplied DC adapter and connect it to the vehicle's cigarette lighter outlet.
  3. Indicator Lights: Check the indicator lights on the unit to ensure it's charging. The light may change color or turn off when fully charged.
Battery Maintenance Tips:
  • Regular Charging: To maintain the battery's health, recharge the unit every three months, even if it's not in use.
  • Avoid Full Discharge: Try not to let the battery completely discharge before recharging.
Manufacturer Instructions: For precise instructions and maintenance tips, refer to the user manual provided with the Peak Portable Power System 450 Plus. If the manual is not available, you can usually find a digital version on the manufacturer's website or contact their customer service for assistance.
7/3/2024 4:22:54 PM • JUMP START... • Answered on Jul 03, 2024
Where do I get parts for my Vector 350, 200 wt veco29acy ?
To find parts for your Vector 350, 200 wt veco29acy, you have a few options:
  1. Manufacturer: Start by contacting the manufacturer of the Vector 350 equipment. They may offer replacement parts or direct you to authorized dealers or distributors who can provide the parts you need. You can check the manufacturer's website for contact information or support resources.
  2. Authorized Dealers or Distributors: Search for authorized dealers or distributors of Vector 350 equipment in your area or online. These dealers may stock replacement parts for the specific model you have and can assist you in purchasing the parts you need.
  3. Online Marketplaces: Explore online marketplaces such as eBay, Amazon, or specialized industrial equipment marketplaces. Sellers on these platforms may offer replacement parts for Vector 350 equipment, including the specific model you have. Be sure to verify the compatibility of the parts with your equipment before making a purchase.
  4. Equipment Repair Shops: Local equipment repair shops or service centers that specialize in food equipment may have access to or be able to source the parts you need. Contact them and inquire about their ability to provide replacement parts for your Vector 350 equipment.
When searching for parts, make sure to provide as much detail about your equipment, including the model number (Veco29acy) and any specific part numbers or descriptions if available. This will help ensure that you get the correct parts for your equipment.
4/9/2024 7:46:19 PM • JUMP START... • Answered on Apr 09, 2024
Where can I get a manual for Vector vec012 jump start system?
hello u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store for free the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
1/24/2019 9:25:52 AM • JUMP START... • Answered on Jan 24, 2019
I have a Power on
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything someone on fixya recommended it to me and I thank him even today They have full manuals free
1/22/2019 10:48:20 AM • JUMP START... • Answered on Jan 22, 2019
Jump stavec012c
I live in Brunswick Ga, can you tell me where to find a replacement ac charging plug and the cigarette lighter plug for my Vector Jump Start 450 amps,(VEC012c).Thank You Mr. Prior
10/7/2018 8:29:53 PM • JUMP START... • Answered on Oct 07, 2018
Need power cord where to
I cannot see the manufacturers name. If you get me the manufacturers name and the model number then I'll be able to find out where you can get the power cord.
1/20/2018 2:14:00 AM • JUMP START... • Answered on Jan 20, 2018
My SCA starter pack is not charging, has been on 240 volt for two days
How old is the starter pack? The battery(ies) die after 3-5 years. FWIW I replaced an AGM-type battery in a starter pack and found out later it was almost as expensive as buying a new one from COSTCO or Uncle Sam's. Sounds like you're in Oz so COSTCO might not be available.
10/22/2017 8:02:08 PM • JUMP START... • Answered on Oct 22, 2017
Does a B&D jump charger and inflator have a charging fuse 500 amp ?
Not to my knowledge, usually the charging fuse will be a low value in relation to the voltage output and the wattage. Maximum would be 10amps or so and the unit would charge all night to come up to charge.
9/14/2017 7:58:00 PM • JUMP START... • Answered on Sep 14, 2017
I have a Vector VEC012CBD
Contact Black and Decker at 1 (800) 231-9786
1/8/2017 10:10:18 PM • JUMP START... • Answered on Jan 08, 2017
2answers
Where can I purchase a power cord for model# VEC012POB.Thanks
https://www.savingology.com/ProductDetails.asp?ProductCode=Black-VEC012BD-VEC012C-AC-EGR&click=2&gclid=CJXoxsmemc0CFZA2aQodCwEGXw
6/23/2016 5:55:40 AM • JUMP START... • Answered on Jun 23, 2016
3answers
I changed the starter in my 2009 pontiac g3 and its acts as it the battery is dead with no charge. I starter sounds as if its trying to start jus not strong enough. What else could be the problem. The
I suggest you keep trying to start for 3 or 4 ten second bursts with ten seconds between each. Dragging current through a poor connection will tend to cause heating of the connection. Immediately feel each battery connection and each connection along the battery leads to the starter motor not forgetting where the earth leads connect to the bodywork. Using a voltmeter to measure the volt drop along the leads would be an easier way to check the leads and connections. Pay particular attention to terminals that are crimped to the cables rather than being soldered. Sometimes there is a dirty connection inside the crimp where it can't be seen or cleaned and the only cure is to cut it off and replace it with a more conventional type of soldered terminal. It might be a good idea to start with to test the new starter to ensure it is good....
5/10/2016 9:52:38 PM • JUMP START... • Answered on May 10, 2016
Want charge was showing full charge after 1month went to use no power and want charge also has tire compressure to pump up tires model #vec012pob purchased from sears
Battery could be bad. A bad battery can sometimes show a surface charge (voltage) on monitoring system, but when you go to use it nada happens because it has no current.
2/15/2016 2:08:02 AM • JUMP START... • Answered on Feb 15, 2016
Power cord vector start it VEC012
Here's a link to the power charger I needed, its a Black & Decker Replacement A/C Charger. I ordered it at the following: http://www.amazon.com/Black-Decker-5140045-42-Replacement-Charger/dp/B002V6VIZW/ref=sr_1_1?s=hi&ie=UTF8&qid=1445366598&sr=1-1&keywords=Black+%26+Decker+%235140045-42+Replacement+A%2FC+Charger
10/20/2015 6:44:42 PM • JUMP START... • Answered on Oct 20, 2015
2answers
Can I plug in a cell phone or any other device through the cigarette lighter type connection to run or recharge?
yes, assuming you use the correct adapter.
8/17/2015 3:17:36 PM • JUMP START... • Answered on Aug 17, 2015
2answers
Can I leave my Power Pro; Autopower 300A; starting power, plugged in all the time?
You can but it will shorten the battery life.
6/18/2015 11:35:08 PM • JUMP START... • Answered on Jun 18, 2015
2answers
How do you recharge the system
What kind of battery are you asking for? Get yourself a good battery charger and follow the directions found in the box. It will explain everything you need to do.
4/10/2015 11:03:05 PM • JUMP START... • Answered on Apr 10, 2015
2answers
I need to buy wall charger for my power on board
For replacement parts (charging adapters, etc.), contact Technical Support, toll free
at (866) 584-5504. Here's the owners manuel. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/VEC012POB.pdf
Good luck.
3/29/2015 6:27:21 PM • JUMP START... • Answered on Mar 29, 2015
2answers
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
3/26/2015 11:29:57 PM • JUMP START... • Answered on Mar 26, 2015
WHERE CAN I GET THE BATTERY
battery plus or e-bay better price
3/16/2015 9:02:50 AM • JUMP START... • Answered on Mar 16, 2015
JUMP START SYSTEM Logo
484 questions posted
Top Vector Vehicle Parts & Accessories Experts
jdthefixer
john h
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Vector Vehicle Parts & Accessories
Most Popular Question
leave power pro autopower 300a
  • Vehicle Parts & Accessories
