SOURCE: Ice Maker Isn't Working Anymore
yes the door dispenser and the ice maker have separate valves it could be the ice maker valve isn't working properly could be the motor module is bad on the icemaker its self get a 10 gauge piece of wire about three inches long strip about 3/8 to1/2 in off each end pull the front off the icemaker and you will se a bunch of little holes they will have letters on them put the wires in the holes marked t and h kind of wiggle it side to side and watch the ice maker if it does nothing then replace the motor module on the front of the icemaker (you don't have to buy the whole icemaker you can buy the module separate ) if the ejector blades move then when they get to the bottom pull the wire out wit for it to complete its cycle see if it fills if it doesn't then change now if your ice bucket is in the door that can be a whole different animal reply to me and let me know what you find and if you have the icemaker in the door dont buy anything till we check it out as a mater of fact if you pull the bottom kickplate off there should be a tech sheet in it or in a plastic bag under the fridge
SOURCE: I have a kitchen aid side by side refrigerator.
try part # ap3182816 it is a whirlpool part #
SOURCE: Model KSRS25FG cracked/leaking filter housing,
I found 2 different part numbers for this housing, but I suspect that they are actually stock numbers for the different stores. Partselect.com calls it their PN PS328166. Appliancepartpros.com calls it their PN AP3085317. Take your pick from whom you want to buy it, or look for another vendor. I did an internet search for appliance parts to find these two vendors.
SOURCE: Coffee Lid
www.shopkitchenaid.com
You will probably need to buy the whole thing (jar and lid) for about $25.
