Microwave Ovens Logo
Posted on Sep 06, 2011
I need to replace my GE Microwave Oven Model JEB1090BV001 Serial number GM920277S with a new GE Microwave oven with the same dimensions. Is model GE PSB1000NBB the same?
5 Related Answers
Anonymous
  • Posted on Dec 24, 2008
SOURCE: I need an installation guide for a General Electric Model JVM130K
I have the same model and the instructions at this site on how to remove it will help you. The owner's manual is useless. Good luck!
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 03, 2009
SOURCE: GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Anonymous
  • Posted on Jun 08, 2009
SOURCE: bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jul 05, 2009
SOURCE: WHat part number for this GW Microwave oven thermostat?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
It will tell you where each one is located and what it's called, and should have the part numbers.
Three of them should read normally closed and one should read open.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you still need help, let us know.
David Hanks
  • 178 Answers
  • Posted on Sep 14, 2009
SOURCE: Need a users manual for a Panasonic Dimension 4
http://www.retrevo.com/samples/Microwave-manuals.html
Hope this helps!!
Top GE Microwave Ovens Experts
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
