Computers & Internet Logo
Posted on Sep 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 51031 on my wii - Computers & Internet
Anonymous
Level 2:
Scholar:
  • Expert 114 Answers
  • Posted on Sep 07, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
114
Questions
0
Helped
33915
Points
276
Just moved and trying to set up my nintendo wii. im haveing a hard time to get it my internet on there i keep putting my SSID BUT IT KEEPS GIVING ME ERROR CODE LIKE 51031?
    The following Wii error codes all have the same possible solutions, which you can read below this list of codes...
  • All Wii Error Codes between 51000 and 51099
  • All Wii Error Codes Between 54000 and 54099
  • All Wii Error Codes Between 51300 and 51399
  • All Wii Error Codes Between 52100 and 52199
  • All Wii Error Codes Between 52200 and 52299
  • All Wii Error Codes Between 52400 and 52499
  • All Wii Error Codes Between 52500 and 52599
  • 51130This is a General Troubleshooting error code and does not have any one specific cause. You'll need to try the following steps to try to solve the problem.
    1. Your wireless router sends out an internet signal using a specific "channel" (much like a radio broadcasts over the airwaves). You can change the "channel" that your wireless router uses to broadcast the internet signal manually. Nintendo suggests setting your wireless router to either channel 1 or 11, as these are supposed to be the fastest channels for download speed.
    The Nintendo website has a guide that shows you how to change the channel on your wireless router.
  • https://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
  • 2. In addition to the broadcasting channel, there is also a broadcast setting. This can be set to either "G", "B", or "Mixed." Nintendo suggests that the "Mixed" setting gives the best network connection, but you might need to try all three settings to get the best network connection.
    3. Home appliances and other devices that are near to your console, like microwaves and cordless phones, might cause interference with your wireless network connection, so try turning these off. Other wireless devices like keyboards and computer mice can also interfere with your network connection.
tip
Nintendo Wii Error Code 51031 This error code means that the wireless network...
<span>Nintendo Wii Error Code 51031</span><br /><br /><span>This error code means that the wireless network within range is not configured or is not compatible with your Nintendo Wii.</span><br /><br />-Make sure the router you are using is compatible. You can see a list of compatible routers by clicking <a href="http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp">here</a><br /><br />-Make sure the SSID(network name) you enter into the Wii settings matches the SSID of your router. This includes making sure capitalization, spaces, or special characters match exactly.<br /><br />You can log in to your router by going to the gateway address of the router(usually 192.168.1.1 and type this into your internet browser), and going into the wireless settings section. Check what the SSID is. This is what you should set on the WII.<br /><br />You can view my tech article on connecting and changing Wii network settings by clicking <a href="http://www.fixya.com/support/r9198848-connect_nintendo_wii_internet">here</a><br /><br />-In your home network, your router may not be assigning an IP address to your Wii console. Power cycle the equipment. Turn off all devices(modem, router and Wii). After 10 seconds turn on the modem, after 30 seconds turn on the router and after 30 seconds turn on the Wii. Try to connect online.<br /><br />If you are not using DCHP but instead have your home network setup to assign a IP address manually, you will need to setup the Wii with the IP/DNS addresses. You can set your manual settings in the Wii network settings menu. See the link above to my tech article.<br /><br />-Your router firmware may need to be upgraded. Visit your router manufacturers website and see if any updates are available.<br /><br />If after all the above steps you are still having trouble, you may want to reach out to Nintendo Technical Support at 800-255-3700<br /><br />I hope this article was informative!<br /><br />-G33k<br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /><span style="font-weight: bold;">Nintendo Wii Error Code 51031, Error Code 51031, Wii 51031</span>
on May 25, 2011 • Nintendo Wii Console
I can't get connected to Netflix.All that pops up is error code 51031
This problem is usually associated with trying to connect a Wii game console to Netflix. If this is the problem you are experiencing go to this site and you'll find the answer on how to connect your console.
http://www.nintendo.com/consumer/systems/wii/es_na/windows/error51030.jsp
Dec 30, 2014 • Netflix
Why can't I connect to Netflix?
Your not connected to the Internet!
What is error 51031
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51031&system=Wii&locale=en_US
My wii is showing me the 51031
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
I keep getting error code 51031
This error means that the router within range is not compatible or not configured properly. Please see my tech article I wrote by clicking below, It will go over the steps needed to fix this issue.
Error Code 51031 Nintendo Wii
Regards,
G33k
Error code 51031 my wii won't connect to my wireless internet
Sadly, it looks like the wifi you are using is not compatible with the wii.
For more information please take a look here
Error code 51031
I dont know the details about this error code, but i will give you a best idea that will fix your problem......
there is one repair guide that is only created to fix the problems caused y nintendo wii console.
click here to download nintendo repair guide.......
19helpful
2answers
Error code 51031
Error Code: 51031 - I had same problem. Worked one day, not the next. I went into Wii Settings/ Internet/ Connection Settings/ Conection 1,2 or 3/ Clear Settings. Then click 'Search for access point'. Click on your your home internet (Sky, Virgin, O2 or whatever), input WEP (written on base of router) or private password if you changed the WEP when you first got broadband installed in your house and it should connect.
Did for me.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
