HP Mini 1000 Netbook Logo
Anonymous Posted on Sep 19, 2011
Hi, When I try to run Windows Update, it tells me that updates KB973688 and KB954430 failed to install. They can't be deleted and then reinstalled because they never actually installed in the first place and therefore don't show up under Installed Updates under Programs and Features in the Control Panel. Windows Update tells me that it's error code 643. Then when I try to manually download the two updates, I get an error message when I click Run that says "Error opening installation log file. Verify that the specified log file location exists and is writable." The computer is a brand new Sony Vaio, running on Windows 7, 64x and I have no idea what else to do to fix this.
Amrit sahni
Level 3:
  • Master 283 Answers
  • Posted on Jul 13, 2015
Amrit sahni
Master
Level 3:
Answers
283
Questions
0
Helped
140863
Points
1835
Microsoft has stopped providing XP users with security updates, forcing them to either upgrade to another, newer operating system, or gamble with their safety. While the latest usage figures show that a large portion of users are moving away from XP, there's still a sizable number of users who aren't -- or can't.
If you're an XP user, or know some XP users, there's a trick which makes it possible to receive security updates for the aging OS for another five years -- right up until April 2019.
The workaround makes use of updates for Windows Embedded Industry (formerly known as Windows Embedded POSReady). This is based on Windows XP Service Pack 3, and the security updates which are being released for it are essentially the same ones Microsoft would have pushed out for XP, if it was still doing so.
You can't simply install the updates -- that would be too easy -- and you'll receive a version mismatch error if you try. But a simple registry tweak is enough to fix that.
Create a text document, and call it XP.reg. You'll need to make sure .reg is the proper extension -- so not "XP.reg.txt". If it's not showing up as a registry file, open any folder, go to Tools > Folder Options, select View and uncheck 'Show hidden files and folders'. That should fix the problem.
Right-click the file, and select Edit. Paste in the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001Save it, and then double-click the file. That will make that change to the registry. That's all you need to do. Windows will now automatically fetch updates designed for POSReady 2009, ensuring XP remains protected for the foreseeable future.
This trick only works for 32-bit editions of XP, but there's a workaround for 64-bit versionshere.
Naturally, there's no way of knowing how long this trick will work -- Microsoft could put a stop to it at any moment. Also, because you're installing updates for a system other than Windows XP, there's the possibility that not all updates will work as intended. But it's still worth a shot.
Anonymous
Level 3:
  • Master 356 Answers
  • Posted on Sep 19, 2011
Anonymous
Master
Level 3:
Answers
356
Questions
0
Helped
49131
Points
1199
Acutually you dont need to wory much about the failed updates. it wiil come again next time when your system automatically updates. ther is no harm if you update failed.most of them are security updates. a good antivirus will work fine.dont wory,
good luck
Top HP Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
