A pin processor have the pins at its bottom which merges in to the motherboard!
A pinless processor has no pins.pinless processor has a flat bottom with around an extra 297 connections to the motherboard. You cant fit one to a pinned socket.
vote me if it is helpful
this is correct but that is not enough, pineless can not work like pined processor there three types of pined processeor 70 pins 40 pins 80pins
Processers these days tend to have more than 70, 40 or 80 pins. Also if the pins aren't on the CPU they will be on the motherboard, with a ball grid array on the CPU. Incidentally this is the most concentrated load of gibberish I've ever had the misfortune to read. Is this just random computer generated garbage or something?
There
are many reasons to why Intel moved from a pinned processor package, to
pinless. The skeptics will say that Intel wanted to stem the flow of
RMA's from processors with broken pins, but if you do a little digging,
the real reasons are somewhat more complicated. The introduction of
Socket 775 addressed a variety of issues with Socket 478; like excessive
pressure from heatsinks which flexed the motherboard, not enough
power-related pins to deal with high power consumption of emerging
cores, and a few other points slightly more technical in nature.
If
Intel had decided to introduce a higher pin density, it would have had
to use a substantially larger substrate, which would have taken up more
real estate on an already space deprived motherboard. Furthermore, if
you divide the number of pins by the area of the processor you'll find
that Socket 775 chips are among the most dense ever. A 775-pinned
solution would have posed another problem; packing all those pins into
the same small space would have meant even more fragile pins than used
with the socket 478 design.
On
the power front, next generation processors are drawing much more
electricity and die shrinks aren't helping the situation as they once
could. So the question arrises of how to feed future generation
processors with the power requirements of yesterday's CPU socket
architecture? According to Intel, Socket 478 Pentium 4's allocate 85
pins for power, 180 for ground. This is intended to power single core
processors that chew up around 100W of power. Socket 775 on the other
hand has a total of 523 power related contacts, 250 for power, 273 for
ground! More contacts means more stable power for the processor, so you
can bet that this form factor was designed with future generations in
mind. If the roadmaps continue unchanged, socket 775 should be the
defacto Intel desktop standard for the next two years.
One
point not to be missed in all of this is that the socket 775 retention
mechanism is a precision piece of engineering, and proper installation
and care is important. To help alleviate potentially problems, MSI have
included a small plastic installation tool to make inserting the socket
777 processor a little easier, and foolproof. It's a handy tool for
people who avoid instructions manuals.
