Dell 5100cn Laser Printer Logo
Anonymous Posted on Jul 26, 2012
Dell Printer problem
I have a Dell 5100cn and went to print something and error code: 009-362 Restart Printer. Well, powered off, unpluged ...no go. Called Dell and they believe it is the Cyan toner causing the problem because I put in an empty Cyan toner and the error message went away, then I put in the NON-DALL Cyan toner and the error message was back. I called the place where I got the toner and they are coming out Friday with a nrew Cyan toner. Hope that works. Any ideas??
  • Anonymous Jul 26, 2012
    Robert, thanks for the response. Yes it was supposed to be a "machine compatible" toner.
  • Anonymous Jul 28, 2012
    GOOD NEWS! The vendor brought out a new Cyan Toner and instantly the printer worked. Thank all of you who responded.
San Diego Copier Repair
Level 2:
  • Expert 128 Answers
  • Posted on Jul 26, 2012
Expert
Level 2:
Answers
128
Questions
0
Helped
74237
Points
353
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
  • San Diego Copier Repair
    I would stick with the factory origional toner if I were you if you. Obviously the compatible is the source of your trouble. Or try a compatible from a completely different supplier to see if you can find one that works with your Dell 5100.
Smith William
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Dell Expert 241 Answers
  • Posted on Jul 29, 2019
Smith William
Dell Expert
Level 2:
Legend:
Answers
241
Questions
0
Helped
327664
Points
856
Efficacious Solutions to Troubleshoot Dell Printer Error 007-340 & 007-341:
Step 1:- Cycle Power on the Dell Printer §First, turn OFF your Dell printer.
§Then wait for some time at least 15-20 seconds.
§Next, turn the Dell printer ON.
§Determine if the issue still occurs. If yes, then go to the next step.
Step 2:- To Remove PHD Unit You should try to Remove PHD Unit, by the following way to fix instant fix this issue.
For More Info Get In touch with professional to get proper solution: Fix Dell Printer Error 007-340 Toll-Free No: +1-888-633-7151
L Pfaff
Level 3:
Top Expert:
  • Dell Master 11,573 Answers
  • Posted on Jun 26, 2016
L Pfaff
Dell Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3653328
Points
181716
1 Related Answer
Anonymous
  • Posted on Jul 17, 2008
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Rommel Balcita
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
