Computers & Internet Logo
yawovi ada Posted on Feb 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken monitor
Anonymous
Level 2:
Sergeant:
  • Expert 378 Answers
  • Posted on Feb 06, 2013
Anonymous
Expert
Level 2:
Sergeant:
Answers
378
Questions
Helped
79989
Points
816
Pyshically broken or?
Broken samsung 740BF pedestal
The way computer monitors are made today, there is no extra runs for repair parts. You could use a monitor stand whereby you detach the broken stand and attach to a new stand.
1helpful
The stand of my E173FPs monitor is broken. What can I do?
Sorry to hear that the stand had broken on your monitor.
many times there is a mounting in the center of the monitor back that accepts a standard 4 screw mounting, which almost any brand monitor will fit on, many of these type stands will adjust in height and also sometimes rotate to a portrait if you should like to read documents with the narrow side to the top.rotated 90 deg. some monitors do not have this option the mount is called (VESA mounting holes, 100mm (Behind attached base plate) but eBay is a great course for this type of part. I should have one of the Dell original mounts in my older parts area. but i see (Problem with Dell E197FP LCD Monitor) and (E173FPs) both in this unsolved problems, and knot knowing exactly the broken area, not sure of all you need to repair the broken area in question. Sprint6@zoominternet.net for personal help with this unit.
My screen is black nothing shows up 3 months old
-check the cables on the monitor and disconnect and reconnect it
-if issue still persist you can check the cable of the monitor for broken pins (vga cable the one with blue connector)
-if there are broken pins then the cable could be the problem
-if not you can try to connect the monitor to another computer or connect the computer to another monitor
-if you connect another monitor to the computer and it works fine then the first monitor you have is broken
-but if you connected the monitor to another computer and it works then it could be the video card of the computer.
No back light
If your backlight is broken, then your monitor is broken beyond economical repair. Unless your monitor is still under warranty, you should seek out a replacement monitor.
Stand for the monitor on a samsung syncMaster 940n broken
It depends bad the parts are broken, this is 2007 model, you may have hard time getting replacement parts, details pictures will help.
http://s807.photobucket.com/home/budm/allalbums
Lcd Screen Broken
is the display is broken or the screen is physically broken,if display is broken we can check the and isolate that some part is gone bad in the computer or the issue is with the monitor.If screen is broken physically then nothing can be done...really sorry the monitor needs to be replaced
4answers
My power light is on but the monitor is black. Is
your moniter is not broken your moniter's data cable is not correctly pluged.
BROKEN MONITOR BASE
The 4 holes on the back are standard and you may find on the web, a monitor mount. You could also search ebay for the exact same monitor with a broken screen and get it very cheap and use the base off it.
Where I can get part for 216bw Samsung
thanks but The monitor was checked, the technician told me that he tryed to get the video card of the monitor Samsung 216 BW but they don't know were buy a part like this to replace it the broken.
If you can please, let me know where I can buy parts of Samsung monitor 216 BW.
Thanks.
Top Belinea Computers & Internet Experts
jdthefixer
Bud Martin
Bud Martin
Anonymous
Are you a Belinea Computer and Internet Expert? Answer questions, earn points and help others
