Kenmore 41392 / 41394 / 41399 Electric Double Oven Logo
Anonymous Posted on Jun 04, 2013
Code F01 What does this code F01 mean? It keeps on flashing on the panel. How to make my oven function again?
4 Related Answers
Powerman
Charlie Popeck
  • 68 Answers
  • Posted on Mar 22, 2008
SOURCE: Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
hutchipop@yahoo.com
Regards,
Powerman
Anonymous
  • 4 Answers
  • Posted on Apr 30, 2008
SOURCE: message panel keeps flashing F10 error
Code F-10 indicates a temperature runaway. There are two possible problems. 1) The oven temp sensor has failed. This can be checked using a standard multimeter. The sensor is located behind the rear access panel of your oven. The sensor should read about 1100 ohms at room temperature. 2) The oven control board needs to be replaced. There are no FRU's (field replaceable units) on the control board. Check the sensor first. Even a new control board is cheaper than a new oven.
Deepwater
Anonymous
  • Posted on Nov 13, 2008
SOURCE: F01 code on the oven
we have the same problem
Anonymous
  • Posted on Apr 04, 2010
SOURCE: My wall oven keeps giving me an error code F3. I
my mp4 has freze
Top Kenmore Ovens Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
