SOURCE: F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition
Check/Repair
F0 or F1
Failed transistor in control
If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked
If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F3
Open oven temperature sensor circuit
Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
F4
Shorted oven temperature sensor circuit
Same as above; check for melted connector or both leads shorted to ground
F8
Component failure within Electronic Range Control (ERC) effecting temp processing circuits
Replace Electronic Range Control (ERC)
F9
Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch
Check wiring and test operation of switch
SOURCE: F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
SOURCE: My GE oven gives error code of F3 and F5
Thank you for contacting Fixya.
It's possible it could be the senser, just two screws hold it on and the wires unplug with a connector.
As to understand it in details whether the sesor is the bad part you can use a ohm meter to test the sensor, it should read about 1100 ohms at room temperature, if so, then your oven sensor is good.
You can get a cheap ohm meter at Radio Shack or any hardware store. If your oven sensor tests good, then your control board would need to be replaced.
That would help to resolve the issue.
God Bless.
SOURCE: we have a gas maytag gas wall oven that is getting
F3
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
SOURCE: kenmore wall oven keeps showing error codes f5 and f3
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
