Your System may be slow due to following reason
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
So Follow these steps to fix computer freezes problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
SOURCE: Processing gets slow when several
While RAM is an important factor in how fast a computer runs, Processor Time and Usage is also important. That would be your problem, your processor is not able to handle all that info at the same time. So ask yourself. Do you really need several web browsers open at the same time? Or perhaps would it be better if you saved all those pages to favorites and only had one or two open at a time and used the favorites to switch between browser pages.
