The E4 error code is a result of a malfunctioning defrost sensor. If
the error code is on the right then it is the defrost sensor in the
upper chamber.
Attached is a link to Avanti service and parts. Provide them with
the model number of your wine cellar and they will be able to provide
you with a price and information on the part needed for repair.
http://www.avantiproducts.com/index.php?page=contact
If you have the owner's manual or are able to speak with a service technician through Avanti, then this can be a diy repair.
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
