Hi
The error message you are receiving "Inquiry command failed Using IBM-PC ServerRaid Host adapter" makes me think you are attaching the tape drive to the ServerRaid Controller, which is only for Hard Disks. There should be a normal SCSI interface for attaching tape drives, etc. It's possible that the ServerRaid card is a PCI (or older) plug in card, and the normal SCSI interface will be on the main motherboard. If you look on the IBM website for the Hardware Maintenance Manual, it should hopefully make things clearer.
The reason you may not be seeing the hard drives in CMOS, is because you will need to use the IBM ServerRaid Utility to view and configure the disks.
