Computers & Internet Logo
f
franco dirks Posted on Apr 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Biometry software disable - 3Com Computers & Internet
Mike M
Level 3:
  • 3Com Master 3,349 Answers
  • Posted on Apr 04, 2014
 Mike M
3Com Master
Level 3:
Answers
3349
Questions
0
Helped
704741
Points
16707
Press F2 on start up. Change BIOS settings
Google not working internet stop working
Method 1 : Reset Internet Explorer
  • Open Internet Explorer.
  • Click on Tools menu (Press "alt" key to active menu bar).
  • Click on "Internet Options". a configuration window you will appear
  • Click on advanced tab.
  • Click on "Reset" Button. You'll get an another box, here check a box named as "Delete Personal Settings", then click on Reset button on it.
Method 2 : Disable Software Rendering. Disable Hardware Acceleration option in IE 9 & IE10
  • Un-check a option named as "use software rendering instead of GPU rendering". it is located under "accelerated graphics".
Method 3 : Disable 3d in "NVIDIA Graphics driver" Disable "stereoscopic 3D" option into "NVIDIA Graphic driver" application. (If you have Nvidia Graphics Drivers & Software, If you don't have the you can leave that step)
  • Open Nvidia software from system tray.
  • Disable the option named as "stereoscopic 3D" from NVIDIA Drivers (NVIDIA driver is a computer Graphics drivers their software runs on system tray. )
How do i Disable software
Which computer are you working with? Most times you can either go to task manager then services, Or type MsConfig into the search and go to startup items.
Scansnap error 0x80210026
Hi There
1.Have you logged in with an administrator account?
2.Was it working fine earlier?
3.Were there any recent changes made on the computer prior to the issue?
You may receive this error if you don't have the appropriate permissions to use the scanner.
Let's try these methods and check if it helps.
Method 1: Install ScanSnap Manager Update (S1500) and check.
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
Method 2: Disable security software and check.
http://windows.microsoft.com/en-IN/windows7/Disable-antivirus-software
Warning: Antivirus software can help protect your computer against viruses and other security threats. In most cases, you should not disable your antivirus software. If you do have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you are connected to the Internet or a network during the time your antivirus software is disabled, your computer is vulnerable to attacks.
Method 3: Uninstall and reinstall ScanSnap and check.
http://www.fujitsu.com/downloads/IMAGE/manual/trouble/p3pc-3792-03enz0.pdf
HP Pavilion a6110n PC won't update windows driver KB2761494
Method 1: Disable the security software temporarily. Note: Antivirus software can help protect your computer against viruses and other security threats. In most cases, you should not disable your antivirus software. If you do have to temporarily disable it to install other software, you should re-enable it as soon as you're done. If you are connected to the Internet or a network during the time your antivirus software is disabled, your computer is vulnerable to attacks. Method 2: Place the computer in a Clean Boot state to see if there is any software conflict as clean boot helps to eliminate software conflicts. Note: After performing the troubleshooting steps in clean boot, follow Step 3 from the article to start the computer to Normal startup mode. Method 3: You can also install the updates (KB number) manually by downloading from Microsoft download center. http://www.microsoft.com/downloads/en/default.aspx Method 4: Follow the steps from the article. How do I reset Windows Update components? Hope this helps
How do i get spyware off my computer? I keep being keylogged and am unsure how i have avg and norton scan daily could you please suggest a better anti spyware/malware
Although anti-spyware and anti-virus software are intended to protect your computer from advertisement pop-ups, slow performance and security threats, they can prevent some of your computer programs from running properly. This is especially true for anti-spyware software. This is why you may chose to disable them. If you disable either your anti-spyware and anti-virus software, take into consideration that you are making your computer more vulnerable to security threats like viruses, worms and trojan horses.
Disabling Anti-Spyware
  • 1Open the anti-spyware program on your computer. Sometimes there is an icon for the software located either on the desktop or in the toolbar on the lower right-hand corner of the computer, next to the clock. Double-click to open the software if it's on your desktop. Right-click on the icon if it's in the toolbar.
  • 2 Turn off the anti-spyware software by removing the check mark from the "on" button. If you have Ad-Watch Anti-Spyware, you will need to uncheck the word "active" and "automatic" to disable the software. If you are running SpyBot Tea Timer, click on "advanced mode" and then uncheck the teatimer.
  • 3 Click "yes" for the anti-spyware software to be disabled.
2helpful
2answers
I want to instal a web cam and I am told to disable spy ware and anti virus does this mean I have to deleteit?
Is the software what came with the web cam ? or is it downloaded software. if its an instalation cd then yes disable whilst it installs and then re enable them. all disable does is deactivates the software temp - you have no need to remove or delete.
Can not update software
Most likely the firewall on you security software is causing the problem. If you know how to disable it open your security software and turn off the firewall. After updating the software, turn on the firewall again.
If you are not able to do the above steps. We will have to disable it from MSCONFIG.
Click start – Run – Type “msconfig” – Hit enter
Click on the Tab “Startup” on the top, Click “Disable All” button
Click on the Tab “Services” on the top, Put a Check on “Hide All Microsoft Service” , Click “Disable All” button
Click OK.
Restart the computer and try updating the software now. It should work. Once updated, open msconfig again and select “Normal Startup” to reset it back to the default settings again.
2helpful
Installation
hello jonesyb,i am nichu .i, have a solution for your problem.is it necessary to disable anit virus software before installation because your antivirus software blocks the installation thinking it as a virus.though the software gets installed it might get corrupt.
to disable a antivirus software go to the system tray which is at the bottom right of your screen,right click on the antivirus software icon,then click quit or exit .............problem solved
take care
bye.
3answers
Cant download kodak easyshare software
If you have a firewall up, disable it than try to download the software.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
