O2 Samsung SGH-E250 Cellular Phone Logo
A
Anonymous Posted on Apr 10, 2014
Enter unlocking code - O2 Samsung SGH-E250 Cellular Phone
WHERE DO I TYPE THE CODE NUMBERS
How to enter unlock code : The common way to enter unlock code as follows:
Dear Customer,
How to Enter Unlock Code
1. Insert SIM card from a source different than your original Service Provider
(i.e. if you have a Rogers phone, use a non-Rogers SIM card),
2. Phone will ask you to enter Sim unlock pin
3. Enter unlock code
4. Phone will be unlocked
for more info about how to unlock a phone go to any code provider like unlockninja
Unlock Your Cellphone Use Any Network in The World
Oct 11, 2017 • Cell Phones
2answers
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
2k 13 cheat codes on xbox 360
    +3 Ball Handling Enter "spriteeffect" as a code to get +3 Ball Handling for your player in MyCAREER mode. 2013 All-Star uniforms Enter "mwpzoslqov" as a code to unlock the 2013 All-Star uniforms. Christmas uniforms Enter "mnspxuwmdy" as a code to unlock the Christmas uniforms. Heat White Hot uniform Enter "kqpxmzodqb" as a code to unlock the Heat White Hot uniform. Secondary road uniforms Enter "ypzbnwolaw" as a code to unlock the secondary road uniforms. Under Armour Tourch shoe Enter "underarmour" as a code to unlock the Under Armour Tourch shoe. ABA ball Enter "payrespect" as a code to unlock the ABA ball.
    At the main menu, select the "Features" option, choose the "Codes" selection, then enter one of the following codes
1helpful
Can you give me the cheat codes for nba 2k13 for ps3
  • Enter "spriteeffect" as a code to get +3 Ball Handling for your player in MyCAREER mode.
  • Enter "mwpzoslqov" as a code to unlock the 2013 All-Star uniforms.
  • Enter "mnspxuwmdy" as a code to unlock the Christmas uniforms.
  • Enter "kqpxmzodqb" as a code to unlock the Heat White Hot uniform.
  • Enter "ypzbnwolaw" as a code to unlock the secondary road uniforms.
  • Enter "underarmour" as a code to unlock the Under Armour Tourch shoe.
  • Enter "payrespect" as a code to unlock the ABA ball.
Cheers,
Tom
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Steps for unlocking LG gs170
You can use unlock code to unlock LG GS170 model mobile.Visit the site
Classicunlocking.com get unlock code and follow the unlocking instructions below and unlock it step by step...
LG GS170 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your LG GS170 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG GS170 mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1. Switch ON your LG GS170 ORIGINAL SIM Card.
2. Then compose : 2945#*170# to enter unlock menu.
3. The LG GS170 will prompt you to enter the unlock code twice.
4. Enter the unlock code and the phone is successfully unlocked.
[Or]
Method 2:
1. Switch ON your LG GS170 with the Original SIM Card.
2. Then compose : 2945#*71001#.
4. Enter the code, the handset is now successfully unlocked.
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
1helpful
2answers
Forgot my security code please help for razr v3 motorola
If you want to unlock your Motorola phone to use it on another network, consider unlocking by entering a code. Code unlocking is the easiest way to remove the SIM lock of your handset. Just enter the code with the instructions below and it's unlocked. If you don't have a code yet, you can get one in my eBay store here:
How to Enter Unlock Codes on Motorola phones:
  1. Switch ON your phone with a not allowed SIM Card,
  2. Phone should show "Enter Special or Subsidy Code",
  3. Enter unlock code.
WARNING: if any of these messages appear :
- "Contact Service Provider"
- or "Tamper Alter"
- or "Wait Before Enter Special Code"
- or "Contact Service'
It's because you or somebody else has already entered too many wrong codes. You just have to leave the phone ON on the error message and after 1hr - 8hrs the message "Enter Special Code" will appear again!
Note: If your phone is on a 3G network enter **057*, then another window will appear to enter the unlock code.
How to Enter Unlock Codes on all Motorola L6i & L7i:( not L6 and L7 without i )
  1. Press and hold "*" key by dialing code 787090
  2. The mobile displays: "Menu. Network"
  3. Choose 'yes' and then press OK
  4. The mobile ask you for code
  5. Enter the code for unlocking.
How to Enter Unlock Codes on all Motorola A1000 and other A models:
  1. Click on the icon Phone
  2. Enter the following keys: **057*
  3. Mobile displays "locking enter personalization"
  5. Click Ok
Forgot my unlock code for nokia 6500c
Your UNLOCK CODE is: #pw+278475507636076+7#
Take the SIM-card out. It's important that the SIM card IS NOT in the phone, during the following steps!!
Now you have to enter the whole code on your phone
1.gif Enter "#"
2.gif Enter "*" three times to write "p"
3.gif Enter "*" four times to write "w"
4.gif Enter "*" twice to write "+"
5.gif Enter the 15 numbers 278475507636076
6.gif Enter "*" twice to write "+"
7.gif Enter "7"
8.gif Enter "#"
Your Nokia phone is now unlocked.
If your phone isn't unlocked by typing the shown code, try this instead: venstrehvid.giffirka.gifp.gifw.gifplust.gif7.gif7.gif7.gif8.gif6.gif0.gif6.gif0.gif2.gif5.gif7.gif0.gif7.gif6.gif6.gifplust.gif1.giffirka.gifhojrehvid.gif
If the unlock code has been entered incorrectly 4 times or more then only a professional unlocker can help you by using an expensive cable solution.
for more details click this link
http://www.peters1.dk/unlock/nokia/online.php?sprog=en
and for any other mobile nokia phone unlock code click on this link
http://www.xcess.info/unlock_your_nokia_phone_online_for_free_aen.aspx
Jan 07, 2009 • Nokia 7610
Top O2 Cell Phones Experts
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
